Limited running boards?
Discussion in '5th Gen 4Runners (2010-2024)' started by Duckintennessee, Dec 7, 2020.
  1. Dec 7, 2020 at 5:12 PM
    Duckintennessee
    Duckintennessee [OP] New Member
    2021 magnetic grey limited
    New here and new to the 4runner family. Just picked up the 2021 limited in magnetic grey and I was looking for some running boards/nerf bars. It looks like the only ones that are available are the flat ones from the factory( or very similar). Has anyone modified a set with those brackets so I dont have to remove the factory rocker panels?
  2. Dec 7, 2020 at 6:12 PM
    AGS92
    AGS92 New Member
    '19 SR5 Premium
    Duckintennessee[OP] likes this.
  3. Dec 7, 2020 at 7:15 PM
    Jemplyr77
    Jemplyr77 New Member
    Brian
    Oklahoma
    2019 MGM Nightshade
    Tinted windows. USR tail lights.
    There are also these in chrome for the non Nightshade version.upload_2020-12-7_21-15-24.jpg
  4. Dec 7, 2020 at 8:08 PM
    Duckintennessee
    Thank you. I was looking for something more aggressive. Something like the tyger auto star armor. Screenshot_20201207-220636_Amazon Shopping.jpg
    AnchorCop likes this.
  5. Dec 8, 2020 at 6:53 AM
    Jemplyr77
    Brian
    Oklahoma
    2019 MGM Nightshade
    Gotcha. That I’m not sure about.
  6. Dec 8, 2020 at 7:11 AM
    dimag333
    dimag333 New Member
    steve
    2021 4rnr Nghtsd
    I am in the process of confirming the toyota rock rails will work, I dont need sliders but need a step for the kids & wife, I also want something that in deep snow I can kind of see whats happening under them
    steve
    deslpwr and Duckintennessee[OP] like this.
  7. Dec 8, 2020 at 11:45 AM
    Duckintennessee
    Steve, I would like to know how that turns out. Please keep me updated.
  8. Dec 9, 2020 at 8:53 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Aggressive Limited. Does not compute.
    lol j/k.. good luck and let us know!
    Does the limited have different factory mounting points for the steps?
    I'll be surprised if the Toyota Rock Rails fit since I'm pretty sure they fit pretty tightly against the TRD rocker panels, no?
    ruiz4251 likes this.
  9. Dec 9, 2020 at 2:30 PM
    Duckintennessee
    The limited has larger rocker panels. But I think the mounting points are the same. The factory boards are just a little too small IMO. I like the features of the limited but was looking for some style points on the outside.
  10. Dec 9, 2020 at 6:07 PM
    Agent_Outside
    Built 2011 T4R Limited
    For what it’s worth I cut my panels on my limited to do sliders. 897FC407-033A-4CC6-B038-4D3EB7F7E6B9.jpg
    Klinsman55, SnakeDoc, GoSlow and 4 others like this.
  11. Dec 9, 2020 at 6:23 PM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    My Limited has the automatic running boards that come out when you open the door. Can those still be removed and swapped out for something like this that’s permanent?
    newtotoyota likes this.
  12. Dec 9, 2020 at 6:40 PM
    nm_t4r
    nm_t4r New Member
    2018 Barcelona Red 4runner LE
    As I recall, N-Fab makes a step/ nerf bar that will fit the Limited.
  13. Dec 9, 2020 at 9:41 PM
    Duckintennessee
    Agent outside that looks good. How did you cut it? Die grinder/ sawsall?
    Nm t4r thanks for the heads up. I will check them out.
    a47chuck likes this.
  14. Dec 10, 2020 at 8:21 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Right on. Heh, I think the limited looks better than TRD. If I wasn't planning on beating up my truck in the woods I'd be driving a Nightshade fo sho.
  15. Dec 10, 2020 at 8:33 AM
    Automatic running boards are fancy on the Limited but I hate when they get stuck due to ice build up. I have to remind wify to turn them off when it snows.
    https://youtu.be/YA_w-7zEkcY
  16. Dec 10, 2020 at 8:58 AM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    How do you turn them off? I would not have thought of that...
  17. Dec 10, 2020 at 9:00 AM
  18. Dec 10, 2020 at 9:02 AM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    Oh cool I was wondering what that did. Just got our 4Runner Limited on Monday and still learning!
  19. Dec 10, 2020 at 9:07 AM
    I know its off topic, let me give you another tip for limited. When unlocking the doors using door handle keep holding the door handle, after couple of seconds it unlocks all doors. You will find more fund stuff.. :):)
  20. Dec 10, 2020 at 9:12 AM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    That's actually very useful! I saw online I can order an OBD2 or something like that and it connects to the truck so I can change stuff like that. I actually asked my dealer to modify it so the door unlocks all 4 doors on the first grab (they said they could) but they didn't do it.
    Another question, with our Limited I get a little bit of vibration if i'm turning sharp at slow speeds, is that normal? This is my first vehicle with AWD.
  21. Dec 10, 2020 at 9:24 AM
    There is a teeny tiny hesitation when taking sharp full lock turns at slower speeds on H4F mode compared to 2wd mode on other trims. That's normal. BTW its little unfair to call it AWD as I feel its way better than previous AWD Toyota's I had when there is ice on my driveway. I'm lazy so only clean the walkway so people won't slip and fall on ice and don't clean snow in front of the garage.
    If you want to change vehicle settings you can buy the OBD device "Carista". I haven't used it or change any of my default settings. Here's an article about it -
    https://trail4runner.com/2018/08/16/carista-for-5th-gen-4runner/
  22. Dec 10, 2020 at 9:59 AM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    Ok gotcha. Yeah I've referred to it as "full time 4wd" to a couple people and they say to me "that's AWD" so i've just started calling it that... lol
    The Carista is what I looked at buying but the only thing I wanted to change was door locks so figured i'd try the dealer first.
  23. Dec 10, 2020 at 1:36 PM
    Jemplyr77
    Brian
    Oklahoma
    2019 MGM Nightshade
    It is my understanding that they can be removed. I would be interested in purchasing a set if I could find one in really good condition. I have the fixed nightshade boards and they are perfectly fine but I really wanted the auto set. Purchased my rig used.
  24. Dec 10, 2020 at 2:16 PM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    Well ours are in great shape as the truck only has 34,000 miles and was just certified by Toyota. If my wife wants to get rid of them maybe we could sell them to you or work out a trade? I have no clue what they’re worth.
  25. Dec 10, 2020 at 3:19 PM
    Jemplyr77
    Brian
    Oklahoma
    2019 MGM Nightshade
    Yea, I would definitely be interested in seeing if we could work something out. I’ll shoot you a PM to discuss.
  26. Dec 11, 2020 at 6:17 PM
    newtotoyota
    newtotoyota New Member
    Geoff
    Philadelphia area
    2014 4Runner Limited
    Blacked out grill and rear emblem. More on the way!
    I have the chrome running boards above. I wish mine had the power running boards like yours
  27. Dec 11, 2020 at 6:21 PM
    newtotoyota
    Geoff
    Philadelphia area
    My 2014 was just simply programming the keys to do this. Now, anytime I touch the drivers door,it unlocks all 4 doors
    kmeeg[QUOTED] likes this.
  28. Dec 11, 2020 at 6:22 PM
    cchopan
    cchopan New Member
    Collin
    New England
    2017 Limited
    How did you do that?
  29. Dec 11, 2020 at 6:27 PM
    newtotoyota
    Geoff
    Philadelphia area
  30. Dec 13, 2020 at 6:25 PM
    a47chuck
    a47chuck New Member
    Central Oregon
    '19 Limited Nightshade, Midnight Black Metallic, front leveling kit, 265/60-20 KO2's and Magnuson Supercharger.
    They be ignent. LOL! Gen 4 Limiteds had a badge on the door that said "Limited 4 Wheel Drive". Ours be "full time 4 wheel drive". Says so right on the console switch, "4HF" not "AWD". That's 4 wheel drive free, center diff is not locked. That's my story and I'm stickin' to it. HAH!
