Limb Riser/Do it Yourself
Discussion in '5th Gen 4Runners (2010-2024)' started by JosephMehta, Jun 12, 2018.
  1. Jun 12, 2018 at 10:10 AM
    JosephMehta
    JosephMehta [OP] New Member
    Zombocalypse
    Shrockworks Front Bumper, CBI Rear Swing Away with dual Jerry Cans and full size spare, Full Shrockworks Armor, Warn 9.5 Synthetic, PIAA Lighting on roof rack and front bumper, Rear lighting wired to vehicle's reverse gear, Dobisons dual slide out rear bay storage with sliding top and refrigerator tie-downs, Limb Risers, Gobi Rack w/mounted Powertank, Fire Extinguisher, Jack, Axe, and Shovel, 33" Nitto Grapplers (295/70/17), Body Mount Chop, Icon Stage 7 Billet w/S2 Stage 3 Secondary adjustable front suspension, 3.5 inch Icon Stage 7 Billet with Billet Upper and Lower Links, Icon Bump Stop, 3.0 inch Icon Overland Rear Coils, ARB Front and Rear Air Locker with ARB Differential Breather (relocated to engine bay), ARB Twin Compressor mounted in engine bay, 360 degree, 4-camera system with DVR with monitor mounted on the dash, Dual Rear Headrest Monitors w/DVD and gaming capability Future mods in 2019: Magnusson Supercharger w/Catback system and possibly an roof mounted, solar heated shower and water storage
    I've searched much for 4Runner Limb Riser kits; the best I could come across was an outfit out of Australia, but I reached out to them and never heard back. The kits they have are not for 4Runners, but I thought I could still use one of them.
    However, I decided to do it myself. Here's my parts list (all from Amazon) and an unbelievably awesome, self drawn schematic with some of the words cut off--sorry but thank you very much--and, yes, I misspelled ferrule:
    1. Two Nilight NI-KIT01 LED Mounting Bracket Kit for Horizontal Bar Tube Clamp Roof/Roll Cage Holder; these will be used on the Shrockworks Brush Guard top tube
    2. Two Handster Work Light Mounting Clamps 0.75’’/ 1’’/ 1.2’’ Universal Tube Mounting Brackets; these will attach to the GOBI Rack
    3. Black Vinyl Coated Steel Aircraft Cable 1/8" VC 3/16" 7x19 Wire
    4. 2 of 3/8" x 6" - Jaw & Jaw Galvanized Turnbuckle
    5. A 2.3 Inch Stainless Carabiner Clip Heavy Duty Snap Hook
    6. IWISS Wire Rope Crimping Tool for Aluminum Oval Sleeves,Stop Sleeves,Crimp Ferrules
    7. Glarks 210Pcs 6 Size Aluminum Double Barrel Ferrule Crimping Loop Sleeve for Wire Rope
  2. Jun 18, 2018 at 12:15 PM
    JosephMehta
    Zombocalypse
    I finished my limb riser installation project last night; pictures to come soon. Here's what I've learned:
    1. The large crimping tool was absolutely necessary (see the list above)
    2. Buy extra ferrules, they are really cheap, and when you mess up (yep, messed up--twice), there is no fixing it. You will have to bin the mistake and start again.
    3. While I do have the risers installed, it would have been far easier if I put another D-ring (Carabineer) on the top clamp (on the Gobi rack), and then attached the crimped cable to the carabineer versus crimping the ferrule over the vehicle. Meaning: do the crimping on the ground, or on a work table, it'll be a whole heck of a lot easier than trying to crimp the ferrule while attached to the clamp.
    4. Open the turnbuckles all of the way (meaning: extend each threaded side of the turnbuckle as far out as it will go without it coming apart).
    5. Make the riser cord as tight as possible through proper length cutting before attaching to the turnbuckle, very little slack is necessary; the length should be long enough to create a crimped loop on each end. The turnbuckle will tighten the cable. Make it taut or the buckle will bounce all over the place when driving
    6. You will not need to buy #7 on the list above; buy the ferrules from Home Depot, they come in packages of 2 for $1.79 (1/4 inch). Suggest 4 packs, giving you 8 ferrules. You'll need only 4 to do the job, but best to have extras on hand.
    7. On my list in the previous post, #1, and #2 will vary depending on the kind of rack and brush guard you have (or don't have). The nice thing is each clamp comes with a number of different sized inserts for differing tube diameters.
    8. For those that don't have a brush guard mounting option, see me post below on brackets to use in lieu of the clamps.
    That's it for now on lessons learned; if I think of any more, I will update the post. As well, I'll post pictures soon of the final outcome. Overall, I'm very happy with the looks (and hopefully the function).
    Joseph.
    djwantke and Han4Run like this.
  3. Jun 18, 2018 at 6:38 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    2017 TRD OFF RD PREM
    oh the list....!
    PICS!!!
    Bob likes this.
  4. Jun 18, 2018 at 8:33 PM
    JosephMehta
    Zombocalypse
    71C5809C-3ED2-440A-90BA-0B8B3F1CBB73.jpg 2EA17370-6988-4444-8656-B0E862C398D7.jpg C358F202-EDA5-4EA7-8BEC-1900AA945896.jpg 94EB6C1E-B9E5-4122-9523-6805B9621E8E.jpg C358F202-EDA5-4EA7-8BEC-1900AA945896.jpg 2EA17370-6988-4444-8656-B0E862C398D7.jpg CF5737B2-C104-4310-BAD0-68F74CA02006.jpg
  5. Jun 19, 2018 at 6:25 AM
    57buick
    57buick New Member
    David
    2018 4runner Off Road premium
    33" Duratracs, TRD Wheels, Addicted Off-Road front Bumper
    So what is this the purpose of a "riser" ?
    jester243 likes this.
  6. Jun 19, 2018 at 8:25 AM
    JosephMehta
    Zombocalypse
    To keep tree branches (limbs) off of the vehicle, the windshield, etc -- hence the name: limb riser
    Hope this helps. Best.
  7. Jun 19, 2018 at 10:30 AM
    Caltech90
    Caltech90 New Member
    '19 TRD OR
    Can you open the hood with them attached?
  8. Jun 19, 2018 at 10:32 AM
    jester243
    Dan
    Spokane, WA
    ahh I was drawing a blank on what it was too, nice work :thumbsup:
  9. Jun 19, 2018 at 10:34 AM
    JosephMehta
    Zombocalypse
    With mine I can, but I purposely installed them with a carabineer at the turnbuckle (and front clamp), so that I could have a quick release on them for that very reason.
    Caltech90[QUOTED] likes this.
  10. Jun 19, 2018 at 4:41 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    oh the list....!
    Very NICE!! Think I might modify the front hardware with some sort of boot? (only while in the woods) to help minimize damage to my truck when the cable gets destroyed by some overzealous limb, or (more likely) my overzealous approach.Thanks for the pics as well!! How do you like the Schrockworks bumper? Mine only has the center tube, so I would have to figure out another approach for any limb risers. hmm..
  11. Jun 19, 2018 at 5:19 PM
    JosephMehta
    Zombocalypse
    Love the bumper. Great approach clearance and well-mounted steel. I really like the hidden winch, too.
    Good suggestion on the boot.
    For your bumper with no tubing, perhaps look for a bracket to screw into the crack between the hood and the quarter panel.
  12. Jun 19, 2018 at 5:40 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    oh the list....!
    Cool! think I like the lower right one the best. The one in the upper photo seems like it could REALLY ruin your day with a big limb. On the bumper, did you install it yourself, and were there any 'gothcha's' while assembling?
  13. Jun 19, 2018 at 5:41 PM
    JosephMehta
    Zombocalypse
    The bumper was installed by the 4x4 shop I use. (High Country 4x4)
  14. Aug 18, 2018 at 8:44 PM
    WallyT4R
    WallyT4R New Member
    Awesome mod! Only thing I would do different is modify the rear hardware to have the end of the cable on the bottom. Limbs could hang up on the cable the way you have it currently. Or am I missing something???
    Ric likes this.
  15. Aug 19, 2018 at 7:45 AM
    Ric
    Ric New Member
    Ric
    thats what I was thinking.
    WallyT4R[QUOTED] likes this.
  16. Aug 19, 2018 at 7:35 PM
    JosephMehta
    Zombocalypse
    Turnbuckle is a closed loop, and can’t really hook something; although, I concede anything could happen with respect to limbs.
    As well, you’ll need a quick(er) release for engine access; Having the quick release at the top makes it a bit harder to do so (but again I concede not off the charts difficult).
    Short version: a bit of a personal choice really; but I am an advocate for the buckle at the bottom as are most users of limb risers.
    Be well, and good luck to those adding the mod.
  17. Apr 6, 2020 at 6:37 PM
    Brother708
    Brother708 New Member
    Austin
    Memphis
    2019 4Runner Off road premium
    *Kings Suspension* Gobi Rack*Shrockworks Bumpers & Sliders*ARB Compressor*Warn Winch* Baja Design lights*
    Question:
    im eyeing up this bumper... what is the distance between the top of the bumper and the bottom of the tubing (where your lights are) does the bumper already have a hole to mount lights where you did?
    Han4Run likes this.
