Lights on my 2024 4Runner should be illegal
Discussion in '5th Gen 4Runners (2010-2024)' started by craftech, Mar 6, 2025.
  1. Mar 6, 2025 at 7:24 PM
    craftech
    craftech [OP] New Member
    For the life of me I don't know how anyone can stand them. I have never owned a vehicle (I'm 80 now) where the headlights had a cutoff line in the middle of my road vision.
    Literally everyone who rides in my 4 runner at nights asks me how I can see to drive with headlights like that. If I pull up to my garage door I can see the cutoff smack in the middle of my door. Black above and bright below. On top of that within that disturbing black shadow line are the outline of the LED headlight housings on each sign.
    The only way I can drive with "normal" headlight illumination is with the brights on all the time.
    I cannot believe Toyota made headlights this dangerous. I live in an area with a lot of deer which makes the situation even more dangerous.
  2. Mar 6, 2025 at 7:31 PM
    Starkhaus
    Starkhaus New Member
    2023 Lunar Rock ORP
    Don’t want to say your experience isn’t correct, but for me I’ve never had a clearer vision of the road with my LEDs on a ‘23. They light up the whole road ahead of me much further than any halogen or half ass LEDs ever have
    LCJ77, TrailSpecial22, Toy4X4 and 5 others like this.
  3. Mar 6, 2025 at 7:35 PM
    They are designed to work on engineered roads.
  4. Mar 6, 2025 at 7:35 PM
    craftech
    Mine definitely do not light up the road as far ahead as my 2005 Camry. I can't see beyond the floating black line and as I said literally everyone who has ridden in it at night asks the same question plus, "What are those two rectangles floating under the black line?
    ZOOMA-LOOM likes this.
  5. Mar 6, 2025 at 7:41 PM
    craftech
    If you mean only roads with street lamps they aren't sold with that disclaimer.
  6. Mar 6, 2025 at 7:41 PM
    They started installing them on the Corolla in 2014. And If the road is not designed right, you will have problems with your cut off.
  7. Mar 6, 2025 at 7:42 PM
    The cutoff is certainly stark in these but that and some artifacts from the headlight housing are normal, make sure they are also properly aligned.
    I aimed mine down farther since them being right at the legal guideline means blinding a lot of folks in non-flat situations, bumps, etc.
    I explored the option of a nicer-for-others halogen headlight swap but don't know if it's been done. (plus warmer color temperature and replaceable bulbs.)
    TrailSpecial22 and Toy4X4 like this.
  8. Mar 6, 2025 at 7:47 PM
    craftech
    No one ever flashed their lights at me.
    Certainly, if I aim them down farther it will make the problem even worse in terms of road illumination. If anything maybe higher would help since the illumination only looks normal with the brights on.
  9. Mar 6, 2025 at 7:52 PM
    craftech
  10. Mar 6, 2025 at 7:53 PM
    aim them higher
    mine were facing the ground about 100ft out in front of me
    i turned them up so the cutoff is about 200ft in front of me
    if you can find a good dark flat stretch of road, stop in the road pop the hood and adjust the headlights up where you can see farther ahead of you.
    The cut-off is made to keep the lights out of oncoming traffic eyes.
  11. Mar 6, 2025 at 7:57 PM
    craftech
    Thanks for the suggestion. I think I'll do that. It's over a year trying to get used to it and I still can't.
  12. Mar 6, 2025 at 8:15 PM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    In all honesty my low beams seems like it lights up the whole damn street compared to the high beams.
    I do have the darked out spots when I pull in front of garage, but they’re symmetrical, and same length apart, but on the road you can’t tell at all. I think I get flashed at lol.
    maybe being to dealer and see if they can’t adjust them somehow?
  13. Mar 6, 2025 at 8:15 PM
    I’m with you John. I don’t like the sharp cut-off.
    Pentangler likes this.
  14. Mar 6, 2025 at 8:39 PM
    S8ULATR
    S8ULATR New Member
    CA
    2 Germans & a Beast
    To each his own. In my opinion, the best factory headlights I've ever had on a car, and I've had alot of cars. Personally, I love the sharp cutoff line, and cutoff lines are designed so as to not blind oncoming drivers.
    We all live in different areas with different street lights, environments, and preferences, so I get it. But, I love them and wish my other cars had these headlights as well.
    eurowner, Redwood, cuse93 and 4 others like this.
  15. Mar 6, 2025 at 9:03 PM
    HuskyMike
    HuskyMike New Member
    While I like the brightness/ clarity of these headlights more than any other car I've own, I'd rather have more spillover above the line on the low beams. It sometimes feels like you're over-driving the headlights.
  16. Mar 6, 2025 at 10:32 PM
    I hate the oncoming vehicle anti-blinders (those little things some called artifacts in the reflectors) with a passion. They make shadows where the light on the ground should be.
    As far as your cut off, maybe your headlights need adjusting. I’ve heard of some 4Runners headlamps being off a lot and mostly too low.
    Level ground, 25’ from wall, measure center of headlight projector, mark 2” lower on wall, cut off line should be adjusted to the mark on the wall.
    TrailSpecial22, Toy4X4 and icebear like this.
  17. Mar 7, 2025 at 5:16 AM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Sorry to say this, but the issue OP has is age-related and not headlight related. Perhaps it is time stop driving at night?
    These lights are bright, and I agree there is an issue with brightness for OTHER DRIVERS. The cutoff is actually both useful in reducing blinding of other drivers and it is also mandated by law. However, when you have age-related vision degradation, your night vision goes first. With less bright lights you will be as vision impaired, but due to lack of contrast it would not be as obvious.
  18. Mar 7, 2025 at 5:19 AM
    Sin4R
    Mall crawling kit.
    If you aim your lights above spec height, you will be badly blinding other people. Get them aligned to spec by the shop in case they are off and aimed too low.
  19. Mar 7, 2025 at 5:30 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I was hoping I wasn't the only one thinking this. It's something we're all going to deal with at some point in our lives.
    steelevo, Toy4X4, Kezin and 1 other person like this.
  20. Mar 7, 2025 at 6:02 AM
    UncleShorty
    UncleShorty New Member
    I'm 72 & drive a '15 SR5. It doesn't have the cutoff headlights. I'm an Infantry vet and had excellent night vision... 50 years ago...
    I HATE to drive at night. I cannot see well enough to feel entirely safe. I keep my trips short, slow down, drive extra defensively and only drive after dark when I absolutly have to.
    I can't imagine why anyone in my age group and older would routinely drive at night.
    By the way, in '74 I had a buddy on his motorcycle who got run over by an 80 year old driver in DAYLIGHT. He dragged the poor guy 200 yards up the road before he even realized he killed him. He told the cops, " I didn't see him."
  21. Mar 7, 2025 at 6:32 AM
    Sin4R
    Mall crawling kit.
    I don't have perfect vision (need driving glasses at night), but in my 2024 4Runner headlights are one of the best (for driver) out there. They are blinding, but only to OTHER DRIVERS. I have/had some high end cars with HIDs, etc. and they are not nearly as good at clearly illuminating the road.
    When you drive a car with poor headlights, but over familiar roads you COULD BE vision impaired but not enough to realize it. This is because your mind can compensate for the lack of visual signal with memory, the same way you can walk to the toilet in your house at night without having to turn on lights. This DOES NOT mean you can see in such conditions.
    To summarize - if you can't see at night with 4Runner LED lights, you probably can't see at night period.
    TrailSpecial22 and BC Hunter like this.
  22. Mar 7, 2025 at 6:54 AM
    I'm guessing you weren't expecting a medical diagnosis after your initial post...
    Saker and BC Hunter like this.
  23. Mar 7, 2025 at 8:54 AM
    I didn’t realize how my night vision was being affected until after my cataracts were removed & new clear lens were installed.
    just sayin’
    I just call it my “Lens Mod”
  24. Mar 7, 2025 at 8:03 PM
    Disagree strongly with this! There is complete lack light spill above the cutoff on my 21 stock LED. This combined with the bright (admittedly very good) lighting below the cutoff, makes the lights horrible on dark roads that aren’t perfectly flat.
    I actually prefer dimmer halogen lights that have a more natural light fall off with distance, and don’t blind other drivers on rolling roads.
    The only way I’ve grown to accept them is by adjusting and readjusting until it’s high enough to see reasonable far, but low enough that I don’t get flashed by other drivers on the hilly roads I drive at night.
    It’s not just the 4runner, most newer cars go for the “perfect cutoff” without any thought for the real world of roads with hills.
  25. Mar 7, 2025 at 10:56 PM
    I’ve been pondering for a while now that with newer styles of headlights, as the reflectors become smaller and smaller the light presented to oncoming drivers is condensed into comparatively brighter point sources that are an issue for drivers with night vision issues. As one drives at night against opposing traffic it is readily apparent when comparing oncoming headlights with smaller sources with those of larger ones that the smaller sources are brighter.
    Saker and McSpazatron like this.
  26. Mar 8, 2025 at 3:55 AM
    The headlights on our 2020 are excellent. They are halogen, they light up the road just fine. After the lift went on the truck we had the headlights re-aimed, because of opposing traffic flashing high beams at us. Somehow in our quest to find "brighter", "bigger", "better" things we sometimes goof. Excess is NOT always best, bigger is NOT always better. I have led lights on my tractor, when working in the dark it's like working during the day. I somewhat agree with OP on light dispersion, however I also agree with Sin4R. I've driven commercial vehicles for 43 yrs., during this time seen many changes in headlights, never used to bother me driving at night, night vision was cat like, but in my mid 60's, the cat like thing isn't there anymore. Granted, everybody is different, you may be 25 and the night vision thing isn't there, maybe you're 75 and have night vision like a cat. I would get the headlights aimed at Toyota and go from there, that's my 2 1/2 cents, thankyou.
  27. Mar 8, 2025 at 4:10 AM
    time to adjust up. Could be off some
    Toy4X4 likes this.
  28. Mar 8, 2025 at 9:54 AM
    Do you wanna trade up for some halogen lighting?
  29. Mar 8, 2025 at 10:07 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I drove shit boxes for many years so I am happy with the light output, however the cut off is very odd. My aunt has a 2019 Equinox with LED headlights and the projection on the road is much nicer. You would think a company such as Toyota could have done a bit better with this, especially considering the quality of Lexus lighting.
  30. Mar 8, 2025 at 10:15 AM
    I just swapped in better lights.
