2024 Headlight Issue
Discussion in '5th Gen 4Runners (2010-2024)' started by MrShamrock, Jan 4, 2024.
  1. Jan 4, 2024 at 6:12 PM
    MrShamrock
    MrShamrock [OP] New Member
    Al
    2024 4Runner Limited
    Just traded my 2020 4R for a 2024 and so far I am not impressed with the headlights. They seem to float going down the road. I am not sure if it’s the definitive line between the lit area and the dark area or what, but it’s definitely different from my 20 model and reminds me of riding in a boat. Also there are 2 rectangular shadows in the lights that make it look like something is chasing the truck on dark roads at night. I see it’s a fairly common complaint, has anyone found a remedy?
    Horsemom1326 likes this.
  2. Jan 4, 2024 at 6:36 PM
    That is totally normal. You can adjust the headlights, or..........you can swap them out for aftermarket.
  3. Jan 4, 2024 at 6:37 PM
    The clip blocks a certain part of the light to prevent glare into oncoming drivers. There is no fix.
    raimieb likes this.
  4. Jan 4, 2024 at 6:53 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    The only fix is to pull the headlights apart and cut the tab off the shutter that causes the dark spot. Or swap to less performant aftermarket headlights
    FourBelugas likes this.
  5. Jan 5, 2024 at 2:34 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    I noticed and complained about the sharp dark cut off when i got my 2022.
    Unfortunately, its by design. If aimed any higher. The high beam would completely blind oncoming vehicles or shine right into mirrors of vehicles in front.
    Tried local light installers.
    Just switch to auto high beams. Helps.
    joshdub and icebear like this.
  6. Mar 3, 2024 at 5:07 PM
    herc
    herc New Member
    2024 4 Runner limited
    I just upgraded from a 2013 4runner to a 2024 and was looking forward to having LED lights but the 4Runner lights are dangerous. Going to hill the lights project 8 car lengths and there is a flat line. Toyota needs to do something. I know a lot of people with LED lights that do not have an issue.
    jc2all likes this.
  7. Mar 3, 2024 at 5:09 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    If you don't like the sharp cut off, you are not gonna like 99% of OEM LED headlights. Adjust the aim if you need to but that's just how projector headlights work.
  8. Mar 3, 2024 at 6:59 PM
    steelevo
    Utah
    Welcome. All hid and led projector headlights will have a sharp cutoff line. Some are sharper than others. Halogen headlights have so much light bleed, which is why you’re noticing the difference. Give it some time for you to adjust.
  9. Mar 4, 2024 at 4:36 AM
  10. Mar 4, 2024 at 7:53 AM
    Sin4R
    Distant land called Timbuktu
    Mall crawling kit.
    While I like 4Runner lights, I agree they are dangerously blinding for a such high-riding car. I have no idea how they managed to get it certified without self-leveling. Anything of comparable brightness (HIDs/Xeons) I had on other cars always had self-leveling feature so you don't blind oncoming traffic.
    Generally, aftermarket lights are either cheap chinesium junk or prohibitively expensive. I have retrofitted HIDs in the past into cars, and parts alone (from a wrecked car with HIDs) would be about $500. Then labor and install (you can't safely use regular wiring harness to supply startup current for HIDs and need to run a separate line).
    I recommend not messing with the lights for road driving and just aim them down a bit more.
  11. Mar 4, 2024 at 8:03 AM
    Sin4R
    Mall crawling kit.
    This is not a good idea. In my younger and foolish days I had too-bright Xeon lights on a car. When you drive at night and blind people, some retaliate and turn on high beams. This creates unsafe situation all around.
    icebear and Slopemaster like this.
  12. Mar 4, 2024 at 8:48 AM
    frios
    frios New Member
    2021 4Runner TRD Off Road Premium
    ノーマル
    I am not 100% convinced that they are there to block glare, but I agree with Kezin that the only fix is to pull the headlights apart and cut the tab off.
  13. Mar 4, 2024 at 9:16 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Speaking of blinding people, last week I met an oncoming Jeep with a 4-row light bar wired to his high beams. He switched to low beams the instant he saw me coming, but the damage was done. I had to stop where I was and wait until I could see again.
    You won't be that bad if you cut the tab or aim the lights up, but you'll be partway with just the low beams, without any mitigation for oncoming drivers.
    TimGinCentralNJ likes this.
  14. Mar 4, 2024 at 3:26 PM
    Kezin
    Didn’t say it was a good idea. Just that’s the only solution to the problem OP is having
    frios likes this.
  15. Jul 8, 2024 at 3:41 PM
    PotobacRunner
    PotobacRunner New Member
    Matt
    Southern Maryland
    2024 ORP Underground
    TRD Black Wheels, Trail Running Boards
    The dark rectangles in the middle of the beam path are not enough to reduce glare to incoming traffic. Mine are just 2 little rectangles, the driver's side more pronounced, that just distract me on dark roads.
  16. Jul 8, 2024 at 3:47 PM
    legend1011
    legend1011 New Member
    Glad I'm not the only one who recognized this. I was slightly concerned that my truck had a manufacturing defect, but now this thread eases my mind that this is normal
  17. Jul 8, 2024 at 3:50 PM
    PotobacRunner
    Matt
    Southern Maryland
    That said, these are still way better than the dim yellow OEM headlights on my 2015.
  18. Jul 8, 2024 at 3:51 PM
    PotobacRunner
    Matt
    Southern Maryland
    I'm now seeing there are many threads on this issue.
  19. Jul 8, 2024 at 3:54 PM
    LT Smash
    LT Smash New Member
    2023 4Runner
    Does anyone have pictures of what you’re talking about? I have a 2023 and can only see the tabs at the top when I’m pulling up in the driveway and the beam is on the garage door. I don’t notice it while driving at all. Is it just a 2024 phenomenon?
  20. Jul 8, 2024 at 3:55 PM
    Imdav2u
    23 TRD PRO
    I went from a 2019 MDX, I would get bright lighted a lot, to a 2023 TRD Pro and have yet to be bright lighted. I'm very happy with the 4Runner led headlights and I love the auto features. I hate the jeep owners who are too ignorant to adjust their aftermarket leds and blind all other traffic.
  21. Jul 9, 2024 at 10:19 AM
    I’d say this is debatable. My eyes adjust better to dimmer light with generous spill, than it does to fantastically bright low beams with a cutoff that leaves everything above it unlit. I seriously doubt the human eye has enough dynamic range to see anything above the cutoff on a moonless night.
    The stock 4runner LEDs are quite good otherwise. But it’s It’s the worst on rural roads that have a lot of traffic because you can’t use high beams to fill.
    It’s not a toyota problem exclusively. If the laws don’t make manufacturers change anything, they wont.
    I’ve made my low beams bearable by adjusting them as high as I could before I got flashed. Then I lowered them to the point that I felt comfortable the cutoff didn’t sweep eye level on sedans in most situations. Oncoming cars will always get swept by the cutoff on rises and dips in the road, unless you make yourself blind by going excessively low.
    Adjusting them high enough will make the angle they hit the road shallower, and stretches the cutoff over more area, making them less apparent.
  22. Jul 9, 2024 at 10:38 AM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    I have a '24 and the only time I can see them is when I pull up to a wall or garage door. They are not visible otherwise. Not sure why people freak out about these so much. As for their purpose, I don't know for sure but I'm not buying into the theory that they block glare for oncoming drivers. I'm very happy overall with the factory headlights, very bright yet I don't get flashed by oncoming traffic.
    LT Smash[QUOTED] likes this.
  23. Jul 9, 2024 at 2:42 PM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    I hear you. This has become a big problem here in New Jersey too...ever since they did away with standard vehicle inspections. Now the state only tests emissions....no brake system inspection, and no physical inspection which used to address things like the 20-times-brighter-than-the-sun light bars you speak of.
    TimG.
