Lifting to rotate tires?
Discussion in '5th Gen 4Runners (2010-2024)' started by rsimi72, Apr 5, 2018.
  1. Apr 5, 2018 at 9:16 PM
    rsimi72
    rsimi72 [OP] New Member
    2017 SR5 Premium - Gray
    Hi all. I know there are recommended lifting points at the front center and rear center of our 4Runners. I simply want to rotate my tires front to rear. Do I need to lift the entire front or rear at those recommended spots or can I simply lift one side at a time? The manual shows support positions for jack stands under the frame. Does anybody ever place a floor jack under the frame to lift one side only for tire change or rotation? Or should I just put the 4Runner on 4 jack stands for tire rotation? Thanks.
  2. Apr 6, 2018 at 4:59 AM
    4X4Runner
    The left coast
    One side at a time works just fine and I usually jack from the frame and put jack stands under it.
  3. Apr 6, 2018 at 11:11 AM
    SnowroxKT
    SnowroxKT New Member
    Alaska
    2018 T4R TRD Offroad
    2018 T4R Offroad SAS 1995 Tacoma
    I'll lift the whole rig off the ground and put jack stands under the frame and or rear axle .
    rsimi72[OP] likes this.
