Lift recommendation to run 33" tires?
Discussion in 'Wheels & Tires' started by Mhamo77, Jun 25, 2020.
  1. Jun 25, 2020 at 10:44 PM
    Mhamo77
    Mhamo77 [OP] New Member
    Matt
    2018 4Runner TRD Off-Road
    None yet. Just switched out factory tires for A/T.
    I have a 2018 4Runner TRD off-road and want to upgrade to 33" tires.
    What lift is recommended? Would I still need to trim or chop with a lift?
    And would I need to regear?
  2. Jun 26, 2020 at 9:30 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    you might need BMC to fit these, but snickel is right about the lift.
  3. Jun 26, 2020 at 1:11 PM
    I'm running 285/70/17 (32.9") tires. I have the BMC, buy I don't know if it was necessary. Lift doesn't necessarily clear big tires if you're actually flexing the suspension, as mentioned above.
    As @Snickel Fritz mentioned, a tall skinny tire will clear more easily, and they're very popular for off-roading. A 255/70/17 is actually taller than my 285's and fits better (from what I've read, no guarantee).
    I haven't re-geared mine, and I don't intend to unless I go bigger (34-35"). You can always regear after the tires if you feel it's necessary. Buying lighter tires and wheels will help.
    Mhamo77[OP] and 7385 like this.
  4. Jun 26, 2020 at 1:38 PM
    Mtbpsych
    Mtbpsych New Member
    I have 295/70/17 which measures out to 33.3” tall, and minimally you’ll need a body mount chop and fender liner work. I did a minor front bumper cut to avoid any rubbing, and at full flex with the tires turned all the way, I’m rubbing on the pinch weld so I need to bring out the ol hammer and hammer that weld flat. And after that, it depends how wide you’ll want to go and what specs you get your wheels in. You’ll also want to consider upper control arms to dial in your alignment and minimize the rubbing.
    gunsnob and Mhamo77[OP] like this.
