Lexus GX470 suspension kit compatible for 5th gen T4R?
Discussion in '5th Gen 4Runners (2010-2024)' started by Amerxon555666, Oct 17, 2020.
  1. Oct 17, 2020 at 6:16 AM
    Amerxon555666
    Amerxon555666 [OP] New Member
    Paul
    Red 2021 4runner TRD off-road
    Hello! buddy of mine bought these Eibach Pro part# E80-59-005-01-22 for a Lexus GX470.
    he never ended up using them on his Lexus, I was thinking if these would fit a 2021 trd off-road 4runner. I know the rear coils are way different but I could probably re use my stock coils and add rear leveling kit. but front coil overs and rear shocks looks similar! the lift is around 2.75 front and 2 inch rear
    I need your opinion , thanks in advance!
  2. Oct 17, 2020 at 6:43 AM
    Mtbpsych
    Mtbpsych New Member
    I’m pretty sure the gx470 is on a different platform as the 5th gen, so they wouldn’t work.
  3. Oct 17, 2020 at 7:03 AM
    It might be compatible with a 4th gen 4runner, but probably not a 5th gen.
    You could always check with the manufacturer. Or, check the actual part numbers against the equivalent 5th gen 4runner kit.
    Amerxon555666[OP] and 7385 like this.
  4. Oct 17, 2020 at 7:10 AM
    ForRun
    ForRun 4Runner
    2020 orp
    Some the lift companies put it small print, the foam cell one was 1st I saw that lists it up front. Should fit but they say 460 not 470..is there a difference?
  5. Oct 17, 2020 at 7:46 AM
    The GX470 was the previous generation to the 460. It shared the 4th gen 4runner chassis. The GX460 is the Lexus brother to 5th gen 4runner.
  6. Oct 17, 2020 at 8:00 AM
    Amerxon555666
    Paul
    that make sense
  7. Oct 18, 2020 at 1:40 PM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    LOVE my stage 2 FCP. Suspension is beastly
    Amerxon555666[OP] likes this.
