Leveling kit tire rub????
Discussion in '3rd Gen 4Runners (1996-2002)' started by walton3434, Dec 28, 2015.
  1. Dec 28, 2015 at 5:56 PM
    walton3434
    walton3434 [OP] New Member
    So I installed new leveling kit 3” left shocks they were new. I put 285/75/16BFG mud terrains on it with 1.25 spacers. I have some front tire rub on sharp or rough dips. This is just from turning in a steep driveway. I just installed arb bumper which I had hoped would alleviate some issues. It has more clearance than stock. However it still rubs my God if I take this off road it will eat the tires off of it. Any suggestions????
  2. Dec 28, 2015 at 9:10 PM
    T-Rex266
    T-Rex266 Moderator Staff Member
    Cab mount chop? Fender liner trim? Any way you can check to see where it's exactly rubbing so we can narrow it down?
  3. Dec 29, 2015 at 3:54 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    Find where it is rubbing, cut and smash.
  4. Dec 29, 2015 at 9:17 AM
    calminitruck
    calminitruck New Member
    Hass
    97 4Runner 4x4 3.4L Auto
    i just put a set of aftermarket front coilovers on the front of mine so im gonna try and see what is the biggest size tire i can fit (yes minor trimming and bashing of the fire wall is acceptable in my opinion)
  5. Dec 29, 2015 at 9:58 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    A coilover lift, basically any lift, will clear the same tire as stock suspension when off-roading. You can use longer bumpstops to keep the tire from stuffing as far into the fender well, otherwise suspension compression and tire clearance will be the same.
  6. Jan 5, 2016 at 6:34 PM
    walton3434
    Ok I cut smashed and beat the cab mount took care of my immediate problem but not overall concern. Is there something I'm missing I see small lifts for 3rd generations but nothing bigger than 3. Should I add body lift??
  7. Jan 7, 2016 at 10:54 AM
    Bad4runner
    Bad4runner New Member
    Black 2007 4runner Toytec 3 inch lift BOSS suspension
    Toytec 3inch lift Boss Suspension, Nitto Grappler 285/17/R17, Hidden Winch Reciver, Smittybilt Winch, Baja Roof Rack
    I have a 4Gen 4runner with 3inch Toytec Lift. I had tire rub problems and had to fix with body chop, local 4x4 shop completed. Tires Nitto Grappler 285/17/R17. Works great, no rubbing
  8. Jan 10, 2016 at 8:07 AM
    T-Rex266
    CMC can do wonders.
    ajohnson likes this.
