Let's talk about Viper Cuts!
Discussion in '5th Gen 4Runners (2010-2024)' started by Borracho Loco, Jan 1, 2025.
  1. Jan 1, 2025 at 11:40 AM
    Borracho Loco [OP] My 4Runner identifies as a Prius!
    Okay, so we're all well aware of my dumb-ass driving and the result of it! I was able to clean up and mitigate the damage so it looks very minimal.
    I was looking at Viper Cuts and found out they aren't all the same. One online shop said there were 3 levels of cut. I like the look of the extreme (see picture below) and this will remove the exposed damage I have.
    So, tell me about pro's and con's, cost and tips. If I go this route, I'll pay someone to do it. I can't bring myself to take a saw to my ride. Oh, and if you can recommend a shop in the Fort Worth/Mansfield/Arlington area that'd be awesome too.
    This is what my bumper looks like now:
    And this is the cut I think I want to go with:
  2. Jan 1, 2025 at 11:44 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Thacrow and MeefZah like this.
  3. Jan 1, 2025 at 11:54 AM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
    check out Tread Depot
    Jynarik and Borracho Loco[OP] like this.
  4. Jan 1, 2025 at 11:56 AM
    Will do! They're very close. Thanks bro.
    Knarf[QUOTED] likes this.
  5. Jan 1, 2025 at 12:04 PM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Not sure on pricing in your area, but Apex Overland (NC) that has done work for me charges I believe $85 for a viper cut. I will be going there later this month to get plus weight front coils installed, along with a BMC, as I'm getting ready to have my SSO Slimline installed with larger tires in my hopefully near future. Good luck with it.
    djwantke likes this.
  6. Jan 1, 2025 at 12:21 PM
    West Coast, Sierra Mountains
    Waiting to see a post where
    Viper Cuts = Raptor Lights
    :popcorn:
    Thacrow likes this.
  7. Jan 1, 2025 at 12:22 PM
    Charlievee
    Charlievee Not new member.
    Viper cuts = high clearance?
    Jynarik likes this.
  8. Jan 1, 2025 at 12:28 PM
    Only approach right at the wheels, no improvement to the vehicle’s centerline. Works well for bouldering but AFAIK not necessary for general trails.
    If you think about it, having that kind of clearance to get a tire up onto a boulder that large you’ll most certainly be dragging a slider.
  9. Jan 1, 2025 at 12:29 PM
    cuse93
    cuse93 Ice Station Zebra
    Viper cuts??? Pfffftt… Bunch of pikers.
  10. Jan 1, 2025 at 12:32 PM
    That is hilarious, awesome and disgusting at the same time. Well done sir.
  11. Jan 1, 2025 at 12:34 PM
    @Borracho Loco
    I did virtually that exact cut in the photograph there, extreme clearance cut. I may be the only person who painted the bottom portion of the “curve” black so it disappears. No bad ideas.
    these photos may be of use to you, and the shop.
    Tips:
    *Fender liners do differ from each other. You will have to cut off /or melt decent amount of fender liner, and deal with partially exposed pink reservoir (I just painted it instead of adding a skid cover /or relocation kit)
    *Fog lamp assembly has a black plastic cover on the passenger side only. I ordered a spare from Toyota and fastened with hot glue and tie-straps (looks and works good actually).
    Gigi, Thacrow, MeefZah and 2 others like this.
  12. Jan 1, 2025 at 12:36 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    ha no
  13. Jan 1, 2025 at 12:48 PM
    Hi Loco. Excellent rehab on that fender!
    if you want to have a viper cut because it would be of benefit on the trails you frequent then by all means go for it. But if your main motivation is to cut off the damaged portion of your bumper, I’d skip it. I respect the viper cut for its functionality, but I think they are ugly. YMMV.
    I remember reading about a plastic filler panel that covers the hole in the underside of the fender left by the viper cut. It potects the fog lights and wiring and gives the whole affair a more finished look. I can’t remember the name of the company that makes it. Anyway, if I were to do a viper cut I would choose the particular style of cut that accommodates those finish pieces.
  14. Jan 1, 2025 at 1:01 PM
    Thanks!
    I don't wheel that much or at all, so the cut would be for looks only.
    I'm considering the following:
    1) Leaving it as is. I put some touch up paint on it and, to be honest, I haven't noticed the damage at all. Even before I cleaned it up. This is obviously the cheapest, because I'd do nothing, and that costs nothing.
    2) Viper cut it. Very high. Again, purely for looks and to hide the damage. This is kind of cheap because it may be $100 or less. (Maybe a bit more)
    3) Go all in and get a full steel bumper. I found one from CBI that I really like. It can be seen here. If I went this route I would get it powder coated or rhino lined to color-match my 4Runner. If I'm going this route, I'm going to do it right. I also know this will cost me $2500+ with parts, painting and install.
    I'm weighing all my options right now. I'm in no rush at all. The truck is drivable, no drive train components were damaged.
  15. Jan 1, 2025 at 1:16 PM
    You left out the option of having a body shop repair it. Have you priced that out? Or just not interested in going that route?
    Thacrow likes this.
  16. Jan 1, 2025 at 1:21 PM
    im torn about this mod. If it helps clear stuff go for it!
  17. Jan 1, 2025 at 1:24 PM
    Nah. That would be very costly.
  18. Jan 1, 2025 at 2:25 PM
    Okay fine. Phony up some pinstripes to disguise it as a badge of honor instead of an oh-no moment.
    Thacrow likes this.
  19. Jan 1, 2025 at 2:35 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Only other thought is being the Anniversary Edition would you want to keep stock or limit to reversible mods?
    Stoney Ranger likes this.
  20. Jan 1, 2025 at 2:51 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Doesn’t look like much damage. I’ve got something similar on my rear fender from rubbing a canyon wall.
    Some touch up paint, 2500 grit sandpaper, buff and polish and it’s basically gone if you’re more than 3 feet away
    Sorry for the sh*t giant photo. Ran downstairs to take a pic of this for you Borracho
    icebear, Harringbr99 and djwantke like this.
  21. Jan 1, 2025 at 2:56 PM
    Beachguy
    2024 TRP ORP
    Get some of that anniversary model striping tape and stripe from the fog lights over to the wheel well. Cover the boo boo and add something distinctive.
    Or ask the insurance company to total it.
  22. Jan 1, 2025 at 3:01 PM
    Number 3. It will ride better since you’ll have to get all new suspension to support the added weight. Might as well get a winch… and 285s to keep everything proportional. Re-gearing is optional with 285s, but it’s not a bad idea, so you probably should have that done too. The gearing also gives you an option to bump it to 34s at some point in the future. :D
    :boink:
    Or just keep things as is, it’s almost invisible anyway.
    Harringbr99 likes this.
  23. Jan 1, 2025 at 3:29 PM
    Charlievee
  24. Jan 1, 2025 at 4:20 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I would leave it, but I am not really a fan of ye olde viper cut, and minor scrapes and such don't really bother me.
    nimby and 1SilverRunner like this.
  25. Jan 1, 2025 at 4:30 PM
    Any interest in a paint-matched replacement bumper cover?
  26. Jan 1, 2025 at 5:52 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I get you scuffed your bumper. Why not just get it touched up or repaired?
    1SilverRunner likes this.
  27. Jan 1, 2025 at 6:01 PM
    Cutting the fender liner in the area on the passenger side exposes the washer fluid reservoir to road/tire debris. Anyone doing a full high-clearance bumper needs to deal with the same problem. You can either get a shield for it, or get a replacement reservoir kit that mounts in the engine compartment. Examples:
    https://optoffroad.com/products/sca...servoir-relocation-kit?variant=43619856089346
    https://www.expeditiononestore.com/Washer-Fluid-Kit_p_52.html (far more expensive)
  28. Jan 1, 2025 at 6:04 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    Grenadier Trialmaster
    Rock Sliders, Bull Bar
    IDK, I’d just get the bumper you really want. I like C4
  29. Jan 1, 2025 at 6:35 PM
    mac1usa
    mac1usa New Member
    If I were you I would go see “Shorty” right in your area of DFW. This guy is a class act and I have watched him work on many classic vehicles and restorations. His reputation in the classic vehicle painting is excellent. I would trust him 100 percent.
    He started off working for Martin Brothers and then started his own shop. I almost sent my 4R to him for a repair then ended up getting a 2024 instead.
    https://shortyscustompaint.com/
    I have the utmost confidence if anyone can match that red paint it’s him.
  30. Jan 1, 2025 at 6:40 PM
    mac1usa
    mac1usa New Member
    He would also be a great contact to be correct any brewing issue with the rear garnish on the rear hatch pinching the paint.
