LED lights affecting DRLs
Discussion in 'Lighting' started by Dnomad63, Jan 30, 2020.
  1. Jan 30, 2020 at 5:08 PM
    Dnomad63
    Dnomad63 [OP] New Member
    Darrell
    West Haverstraw, NY
    2020 forerunner night shade
    Does anyone know of an LED brand that will work with my 2020 4Runner nightshade edition without disabling the DRLs. I purchased Xenon high and low beams had them installed and the DRLs were flickering. The company said that their product works only when you disable the DRLs. They said that the anti flicker doesn’t work. Thanks!!
    hossler1788 likes this.
  2. Jan 30, 2020 at 6:33 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I saw pictures of owners installing LED lamps and the OEM lamp illumination looked very close to the LED change. they had to install the anti flickering kit for toyota.
    because I dug into this I will not change the OEM lamps.. the other PITA is lamp adjustment setting.
  3. Jan 30, 2020 at 8:46 PM
    celaw309
    celaw309 New Member
    Chris
    NY
    2020 MGM TRD ORP
    I bought Xtreme LED Pros from Xenondepot for my high/low beams in my 2020 TRD ORP. They sell a driver for the high beams so that you can use the DRLs without the flickering. Love the lights, they're super bright!
  4. Jan 31, 2020 at 3:41 AM
    adrtoy
    adrtoy New Member
    I just ordered a set of these for my high beams for this exact reason. Went with HID's for the projector low beams.
  5. Jan 31, 2020 at 10:02 AM
    DBGW5
    DBGW5 New Member
    19 T4R ORP Icon 2.5 CDCV, 74Weld UCAs, Icon Overland rear springs w/ Icon 2.0 Resi, 285’s KM3, Icon rebounds, 4:56 Yukon gears, YOTAWERX AD Prem tune, Sumo Springs Blue bumps, magnaflow side exit, S&B intake. KC hidden bumper Rough Country 20”LED, RIGd tire carrier, frontrunner full roof rack, RIPP coil packs, victory ladder, BD Fogs, DRT hitch skid, MORE CO2 bracket, Rigid DSS Pro ditch lights
    3/2 lift new springs w/bilstein, 285’s, icon rebounds, magnaflow side exit, Pedal CDR
    I have DDM Tuning Saber 50w Pro in 3k (yellow) and they don’t flicker. Not to mention the color is awesome!!
  6. Feb 1, 2020 at 10:40 AM
    h4yd3n
    h4yd3n New Member
    Hayden
    2021 Limited
    Pics? While drl dimmed and high beam pls. I’m interested since these apparently don’t require a separate drl driver
  7. Feb 1, 2020 at 3:44 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    I had the XD DRL drivers that allow them to dim for DRL use. I'm back to halogen now though, 9011 bulb has much higher performance and better focus. I might try to sell these dumb LED bulbs now.
  8. Feb 2, 2020 at 8:50 AM
    DBGW5
    DBGW5 New Member
    I’ll try and get some today. Will probably be tomorrow. I’m going to covert to there HID kit soon.
  9. Feb 2, 2020 at 9:25 AM
    RuGGid Runner
    RuGGid Runner New Member
    Carl
    New Jersey
    2020 Metallic Grey 4Runner TRD Off Road Premium
    King 2.5 with Remote reservoirs. Nitto Ridge Grappler 285/70/17. OEM stereo, JL Audio FIX 86, Alpine PDX-V9, Taco tunes 12” Sub box, Kenwood excelon 6x9 components FR/Dash and 6.5 Coaxial Rear/Tailgate. HR revolution SV-4 LED headlights.
    I picked up the Headlight Revolution SV-4 LED Headlights Hi and Low Beams. The High Beams come with an additional resistor unit that eliminates the flicker issue. My only complaint is I need to adjust the beams down on the Lows. There plenty bright though.
    DBGW5 likes this.
  10. Feb 2, 2020 at 6:26 PM
    PandaKyle
    PandaKyle New Member
    2019 Toyota 4Runner SR5
    I know this isn't the solution you were looking for, but I figured it wouldn't hurt to mention.
    I had this problem when I upgraded my lights to LED as well. Toyota uses auscultating voltage on the stock halogen high beams which creates half the intensity of the normal light output of the halogen high beams. But, this auscultating voltage is too rapid for LEDs to register a brief moment of no power, resulting in the high beams being at full power all the time. I first noticed the issue when I would go from lights off, to normal low beam on, the high beams would flash as I passed through DRL... That got annoying fast. I was shown how to disable the DRL headlights by means of pressing a pin out of the way on a relay in the fuse box under the hood. This turns off ONLY the headlights while running on DRLs, it does not affect the normal high/low beam when used at night. It also does not affect the Amber side markers, which was perfect because I ended up installing Amber grill lights and used the side markers as the power source for them. Here is a picture of which pin to press down, if you decide to do it this way. It's reversible, and free.
    Dnomad63[OP] likes this.
  11. Feb 2, 2020 at 9:18 PM
    mynameistory
    Tory
    All of these problems go away when you get rid of "upgraded" LED bulbs and use performance halogen bulbs. Plus you'll get actual distance vision again, instead of just near-field brightness.
  12. Feb 2, 2020 at 9:23 PM
    PandaKyle
    Never had a "near-field" issue with my LEDs. I can see clearly up to about 100' or so. The light is much clearer than the stock halogens, in my opinion the LEDs are the best bang for the buck.
    White runner likes this.
  13. Feb 2, 2020 at 9:33 PM
    mynameistory
    Tory
    I disagree, but only because headlights are supposed to reach further than 100 feet. At 70mph, 100 feet passes by in less than a second.
    There is a large body of comparative research that shows the performance of various popular bulb upgrades here:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    It includes discussion on why LED bulbs trying to emulate halogen filaments perform poorly (they're certainly bright enough but they lack focus).
  14. Feb 2, 2020 at 9:36 PM
    PandaKyle
    Ok, I thank you for the link. I assure you that your opinion has been noted. I am not the best judge of distance, but I can see far enough with my head lights to not be worried about something coming up on me without enough time to react. Everyone likes different things, and everyone is entitled to their opinion.
  15. Feb 2, 2020 at 9:48 PM
    mynameistory
    Tory
    Everyone is certainly entitled to their opinion, but opinions do not change facts. Halogen housings work best with halogen bulbs. I do encourage everyone to do their research, and that thread is a great start. I went through the whole "upgraded LED" phase myself, and spent a significant amount of money doing so. Now I use H9 and 9011 halogen bulbs, which cost approximately $7 and $15 respectively at any auto parts store.
  16. Feb 3, 2020 at 8:35 AM
    j cat
    j cat New Member
    massachusetts
    if your driving at night a lot with halogen lamps,, the lamps need replacing.. new bulbs should provide a brighter view.
    I have LED lamps in my house save cost on the electric bill.. but as time passes I have to replace the LED lamps because the brightness reduces over time..
  17. Feb 6, 2020 at 6:59 PM
    DBGW5
    DBGW5 New Member
    Sorry it took so long... first pic is DRL... second is high beam. DDM Tuning 3000k Saber 50w
    here are the pics.
    AAC69591-7321-4F1B-9EEC-DD5949FA5E93.jpg CE51D26F-06DA-4718-BE1B-9289626092AF.jpg
    The high beam doesn’t really show how bright they are.
  18. Feb 6, 2020 at 8:06 PM
    h4yd3n
    h4yd3n New Member
    Hayden
    2021 Limited
    Oh they look better than I thought. I may need to spring the $95 on Amazon for them.
  19. Feb 11, 2020 at 9:14 AM
    adrtoy
    adrtoy New Member
    I installed these and they're still kind of bright for DRL's IMO plus mine have a slight flicker. I'm on the fence about them right now.
  20. Feb 11, 2020 at 9:23 AM
    h4yd3n
    h4yd3n New Member
    Hayden
    2021 Limited
    I have read about this same flickering issue from multiple people who bought the DRL driver set ($60) for the Xtreme LED 9005 ($120). Don’t waste any more mental anguish. Just go back to halogen Highs or get the $95 DDM Saber Pro 9005 LED (3000k or 6000k), which are built-in dimmable 50W with no flicker as a result, and thus do not need a DRL driver.
    DBGW5 likes this.
  21. Feb 11, 2020 at 11:21 AM
    2016Pro
    So glad I got HIDs, zero issues and much better performance than halogen or LEDs
  22. Feb 11, 2020 at 11:48 AM
    adrtoy
    adrtoy New Member
    These dim for DRL's?
  23. Feb 11, 2020 at 12:13 PM
    mynameistory
    Tory
    Only if you get the DRL modules (purchased separately). If you use what's in the box, you get full high-beam brightness with flicker.
  24. Feb 11, 2020 at 1:30 PM
    adrtoy
    adrtoy New Member
    Given the amount I actually use the high beams, I think I'm gonna part way with LED's in the high beams, and go back to halogens.
  25. Feb 11, 2020 at 1:51 PM
    mynameistory
    Tory
    Smart. Halogen housings work best with halogen bulbs.
  26. Feb 11, 2020 at 1:58 PM
    adrtoy
    adrtoy New Member
    I'm now thinking about a 9011 swap.
  27. Feb 11, 2020 at 2:01 PM
    mynameistory
    Tory
    I have the 9011 bulbs in. They fit right in after a simple trim tab with a pair of sharp wire snips. H9 in the low beams work great too.
  28. Feb 11, 2020 at 2:17 PM
    White runner
    White runner New Member
    Andy
    South Dakota
    2017 SR5 Premium
    I thought this Halogen, HID and LED d*ck size comparison died several post ago. I guess some still think there’s is bigger.
  29. Feb 11, 2020 at 2:41 PM
    mynameistory
    Tory
    "I used to think a dick measuring contest was a contest to see who could measure the most dicks." :D
