Led lighting 2016 4 Runner Limited
Discussion in 'Lighting' started by Freebird773, Nov 30, 2022.
  1. Nov 30, 2022 at 6:41 AM
    Freebird773
    Freebird773 [OP] New Member
    Larry
    2016 Limited
    Added Auxiliary rear back up lights, and a remote start.
    I am trying to increase my lighting while maintaining a stock city slicker look.
    I dont want to mount big off road lights or light bars outside the body panels.
    I would like to something behind the grill if possible.
    1) want to start with upgrading stock fog/driving lights to LED.
    2) would like to upgrade headlights to an "LED" set up if there is a "plug and play" option out there
    3) behind the front grill auxiliary lights.
    I am brand new at this,any recomendations ,pictures off completed projects and links to companies that provide what I need would be so much appreciated!
  2. Nov 30, 2022 at 6:56 AM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
  3. Nov 30, 2022 at 7:06 AM
    Freebird773
    Larry
    2016 Limited
    Can you send the info on the led fog lights?
  4. Nov 30, 2022 at 8:31 AM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
  5. Dec 19, 2022 at 5:00 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    There are actually a pretty good number of "upgraded" LED fog light options out there. The best of them replace the entire "pod" as opposed to just the bulb (if you have halogen fogs). These are still pretty much "plug and play" except that you have to remove and replace the whole pod - which isn't a huge deal. Trust me, if you get the right LED pods, the increase in lighting is dramatic. Here's a really good (if a bit exhaustive) review of what's out there:
    The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
    Spoiler Alert: The best bang for the buck is the Diode Dynamics Sport or Elite and the flat out most powerful are the Diode Dynamics Max or the Morimoto HXB. (I have the Max and my son has the HXB's.)
  6. Dec 19, 2022 at 5:41 AM
  7. Feb 20, 2023 at 3:54 PM
    Keith E.
    Keith E. New Member
    Searching
    I installed LASFIT LED high beams in my '16 Limited ~6wks ago and have been very pleased.
    Keith
  8. Feb 20, 2023 at 6:50 PM
    steelevo
    Utah
    The number one upgrade that made a difference was going with OEM LED headlights from a 2021MY. Swapping the connectors on the plugs was the easiest part, less than 10 minutes. It took me longer to get the bumper off and swap the lower headlight brackets. You don't need a harness unless you go with the OEM LED headlights that have the high beam shutter. Just make sure to get the ones that have LED low beams and halogen high beams, usually from a non Pro or Limited and MY2021-2022. The halogen high beams help with headlight icing in the winter.
    If you are not wanting to spend the money or time on the LED headlights, then I would at least do the H9 low-beam conversion. This is the second best and cheapest light mod that you can do.
  9. May 30, 2023 at 2:09 AM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    So you didn’t use an an adapter to switch to the newer (2021) headlight housing?
  10. May 30, 2023 at 6:19 AM
    steelevo
    Utah
    No adapter needed for 2021 led low beam/ halogen high beam headlights, just swap the plugs. Swapping the plugs literally takes less than 5 minutes. The problem will be trying to find a used set of these headlights.
    An adapter will be needed for 2021 Limited and Pro headlights or any 2022 + led headlights.
    donnermel[QUOTED] likes this.
  11. May 30, 2023 at 8:51 AM
    donnermel
    dita.yota
    Truckee/Tahoe
    Thanks! Seems doable, but I’d hate to mess it up. I watched that video on switching the plugs. It seems like buying an easy adapter would work too?
  12. Mar 11, 2025 at 9:09 AM
    MontanaMarine
    MontanaMarine New Member
    Dave
    2016 SR5
    Bumping this, as I have a 2016 as well I want the same plug and play replacement led bulbs as the OP.
    Has anyone done just the bulb swaps, and what brand do you recommend?
  13. Mar 11, 2025 at 9:34 AM
    My current setup on 2019 is;
    Low beams - Hikari Titanowa (Has really good light output and good cut-off line)
    Highbeam - Xenon Depot LED PRO with included DRL driver (Best DRL mode I have ever experienced and decent high beam performance. But highbeam is not bright as high power LEDs with fans and external drivers)
    Fog lights - Amazon LED light housings that look like 2021+ TRD Pro factory LEDs.
    Below are Amazon links -
    Low beams - https://amzn.to/43CAFUd
    Fog lights - https://amzn.to/3DzvGJy
    High beams - (purchased at Headlight Revolution site)
    ** 1. Sadly now they charge whopping $68 for the driver. When I purchase it was free.
    ** 2. Sorry the link is too long
    https://www.headlightrevolution.com...n7Ca2JjkJmdpiUUf4FM7YwI-jhqibeDxoCtOEQAvD_BwE
    MontanaMarine[QUOTED] likes this.
  14. Mar 11, 2025 at 10:21 AM
    MontanaMarine
    Dave
    2016 SR5
    Super helpful-thank you!
    How is the fog light install-plug and play? Or does it require any modding?
  15. Mar 11, 2025 at 10:23 AM
    Little scary not to break any tabs. Need to be careful. Here's the video I created to show my experience.
    https://youtu.be/QHOHQY8ASZQ?feature=shared
