Led headlights lows highs drls and fogs
Discussion in '5th Gen 4Runners (2010-2024)' started by Narbeh, Feb 9, 2019.
  1. Feb 9, 2019 at 10:38 AM
    Narbeh
    Narbeh [OP] New Member
    Narbeh
    La Canada Flintridge
    2019 4Runner TRD Off Road Premium
    Can someone whose done this before tell me which led lights are the best and where to purchase from?
    Does the dust cover need to be changed or do I retain the factory one?
    Thx
    Strandskov likes this.
  2. Feb 9, 2019 at 2:40 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
  3. Feb 9, 2019 at 2:56 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    look up DDM tuning i use their HID 5k in low beams ,LED 3k in fog and DRL and HIGH beam 55w. i absolutely love my lights
    they have the option of 55w or 35w for your lights
    After you install make sure you lower or adjust your low beams just a tad
    Strandskov and WallyT4R like this.
  4. Feb 9, 2019 at 3:03 PM
    Hyper15125
    Hyper15125 Headlight Retrofitting Hobbyist
    NJ (609)
    ‘14 SR5 T4R, ‘13 Taco TRD Sport DCLB, ‘02 SC430
    Dont buy LED, buy HIDs.
  5. Feb 9, 2019 at 4:17 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    I wish the ddm came in 5000k
  6. Feb 9, 2019 at 5:25 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Did ddm also for lows. Dig em Doin the dust cap, and mounting the ballasts took all of about 17 mins to be completely done. With adjusting them down some turns. Never get flashed and its night and day over the OEM low beam turds
    Strandskov and jgcaps like this.
  7. Feb 9, 2019 at 7:07 PM
    Hyper15125
    NJ (609)
    DDM stuff is mostly all of the same generic stuff you see on ebay with a fancy box or sticker.
    Strandskov and 2016Pro like this.
  8. Feb 9, 2019 at 7:32 PM
    Hyper15125
    NJ (609)
    I have installed this set in a bunch of 4Runners. You need H11b bulbs and I recommend 5000k for the color temp.
    Ill put these up against any of the big names out there. The only other thing you need is a 1” paddle bit to drill a hole through the dust cover on the back of the light housings.
    https://www.ebay.com/ulk/itm/282591853710
  9. Feb 9, 2019 at 8:36 PM
    2016Pro
    That's the one i purchased I believe it was $78 for the whole set. I went with 4300k bulbs. No complaints
  10. Feb 9, 2019 at 8:42 PM
    4StunnerSrq
    4StunnerSrq New Member
    2013 4Runner SR5
    Led swapped everything, custom Truck vault Sliding drawers, 5% Tint all the way around, 3 Inch lift kit
    Has anyone done the 6 High Mod? Did it when I had a GMC Sierra wasn’t sure if it was able to be done on the 4 runners.
  11. Feb 10, 2019 at 2:36 AM
    Charlievee
    Charlievee Not new member.
  12. Feb 10, 2019 at 1:04 PM
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    following
  13. Feb 11, 2019 at 9:18 AM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    An expensive but top quality kit from Xeon Depot. Only brand to have a ballas that accomidates our drl and hi beam
  14. Feb 11, 2019 at 11:31 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    LEDs for low beams are really starting to come into their own. They're still not as bright as HIDs, but they are a WHOLE lot more robust because they are solid state. No jiggling light beams when driving over bumps, or ballasts that quit working for no reason (talk to ten people with HIDs and half of them will have burnt a ballast or two, regardless of brand).
    Here's what I got:
  15. Feb 11, 2019 at 3:06 PM
    Charlievee
    You can get the modulator other places as well. It's no big secret, just saying.
  16. Feb 12, 2019 at 5:02 AM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    [QUOTE="Charlievee, post: 74656,
    https://m.youtube.com/watch?v=4Mn-0xS9h84&feature=youtu.be[/QUOTE]
    This is what I have for the high and low beam. I don’t use the DRL’s so the fact they don’t dim isn’t a problem for me. I did the OEM fog light swap instead of just a bulb replacement. So far I haven’t had any issues
  17. Feb 12, 2019 at 10:39 AM
    Kyblack76
    Layton, Utah
    18 TRD O.R
    Welp, the ones you linked, were the same price I paid for mine And, I'm sure they will last,.not worried about it,.... and hell, if they dont, that life long warranty will help.
    Edit- and a hole saw, I prefer .. over a paddle bit But, hey,.. again .. to each their own
  18. Feb 12, 2019 at 1:26 PM
    Hyper15125
    NJ (609)
    Cool.
    Id like to see output pics comparing both. My guess is the DDM ballasts don’t put out as much power but to each there own, at least you got some improvement.
    jgcaps and Strandskov like this.
  19. Feb 13, 2019 at 3:00 PM
    Charlievee
    Installed the supernova perfect fit last night. No issue with install. About the same brightness of the high beam, but only throw about 50 meters down the road. Very distinct cut off line and light up two lanes of traffic and the shoulder. I need to replace the driving lights as the color is way yellow by comparison.
    Crossfit4Runner likes this.
  20. Feb 14, 2019 at 2:20 PM
    Charlievee
    Will give it a try when I can (I'll be installing the Eibach lift this weekend).
    nimby likes this.
