KDSS 3” Lift HELPP
Discussion in '5th Gen 4Runners (2010-2024)' started by 4runnnernewbie11, Feb 6, 2019.
  1. Feb 6, 2019 at 10:01 AM
    4runnnernewbie11
    4runnnernewbie11 [OP] New Member
    new england
    16 4Runner Trail
    Getting ready to pull the trigger on a 3” lift. Trying to decide between The Toytec Unlimited, ToyTec/bilstein 5100, or EMU. I’ve seen a lot of threads talk about 6112/5160, toytec unlimited, dobinson, the lean on the passenger side, and the rake look. Being new to the 4Runner world all this can get pretty confusing. Just when I make up my mind I see another thread telling me to do other wise. I won’t be doing much wheeling as my 2016 TEP is my daily driver. Also any tips to level it out as much as possible after lift. Putting on 33’s, not adding any weight, and decided to order spc ucas. Also trying to stay under $1,500. THANKS.
  2. Feb 6, 2019 at 12:54 PM
    4X4Runner
    The left coast
    I’ve been hearing SPC may not be the best course of action and to stick with Total Chaos or Camburg.
    There is a thread on TW about issues people have had with SPC and the weld breaking
    If you’re looking to level and not have the rake you may have to go less in the rear.
    Once you do get the lift installed you can also do the KDSS calibration per the attached.
    Beef Nachos, MattMo, SlvrSlug and 2 others like this.
  3. Feb 7, 2019 at 5:02 AM
    billnourse
    billnourse New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    I have a Toytec Ultimate with 5100's and 650# front springs. It seems to work good. Dealer said it did not need UCA's to align. Ride is good, handling is good, and it is under 1,500. 20170819_063407_001.jpg
  4. Feb 7, 2019 at 7:26 AM
    elnip
    elnip New Member
    Scott
    LC,NM
    2016 4runner Trail P
    I have SPC's on both my 5th Gen T4R and my 1st Gen Taco. No problems on either. Yes SPC had the weld issues but that was on the previous design and I also like the fact that I don't have to deal with uni balls. The T4R has the newer version and I have the caster set to 5 deg., I haven't seen anyone that can get to 5 degrees with Total Chaos or Camburg.
    4runnnernewbie11 [OP] likes this.
  5. Feb 7, 2019 at 8:59 AM
    Braves95
    Braves95 New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    What is the stock weight for the front springs? Limited NON KDSS
    550
    600
    650
  6. Feb 7, 2019 at 9:34 AM
    4X4Runner
    The left coast
    I am not entirely sure
  7. Feb 7, 2019 at 1:15 PM
    ManBeast
    ManBeast New Member
    Zach
    Jax FL
    2014 TRAIL
    I have a lift for tacoma, is that the same stuff as 4runner, got 887s and 5100s and which stuff would be a good match for rear
