K02 min. thread depth for a trip?
Discussion in 'Wheels & Tires' started by Scarif_1, Apr 15, 2024.
  1. Apr 15, 2024 at 2:32 PM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    Bilstein 2.5" 6112s w/ 5160s & Dobinsons 1.5" rear springs. SPC UCAs. 285/70R17 BFG KO2s
    Hey All,
    Doing the Toyota Roundup in the San Juans in July. Will be the first time there.
    How much tread depth on a KO2 would you deem good for running those trails?
    I've got a KO2 set w/ just 30k. Don't have their depths offhand but the knobs aren't as tall anymore and they do appear less "grippy". Wondering if purchasing a new set is warranted. I do know a fresh set would inspire more confidence.
    Thanks
  2. Apr 15, 2024 at 2:32 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    sorry for the sp. I mean tread vs. thread
  3. Apr 15, 2024 at 2:54 PM
    Dillusion New Member
    KYle
    Never going to get the same answer.
    I doubt anyone measures thread depth before they hit the trails. Maybe check air pressure. Plus its gonna depend on what trail.
  4. Apr 15, 2024 at 2:59 PM
    30k is just over the half way point for KO2's. I think they usually last 60k miles. The answer is all about the trails you'll be on.
    If you're going to do actual rock climbing, you'll slip a lot and I probably wouldn't risk it.
    If you're just going on dirt/loose gravel or climbing a grade that isn't too steep, you should be fine.
  5. Apr 15, 2024 at 3:20 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Ha! I have the same issue. In June, I'm taking a trip up to Idaho from San Diego. Likely around 3,000 miles in total. I have 4/32s on the rears and 5/32s on the fronts. Obviously, a rotation is needed. I won't be putting a lot of miles on it before then, so I think I'll risk it, but still thinking about it.
  6. Apr 15, 2024 at 3:46 PM
    One other thing to consider is how old are the tires? I like to have good rubber on trips like this, and would switch them out, then if you felt bad about having a lot of rubber left switch them back and burn the rest off when you get back home. JMHO
    icebear and Schlappesepple like this.
  7. Apr 15, 2024 at 11:40 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    I won't be doing anything super technical, just a lot of fear inducing shelf roads. Some off camber. For those familiar these are the trails I've signed up for. In order for that Wed, Thurs. and Friday: Bullion King and Clear Lakes "rated easy", Stony Pass to Kite Lake "also easy" and the "hardest" on the last day Friday Imogene (Ouray to Telluride) rated medium. I've already purchased a set of -10 offset SCS F5s to widen the track over stock Off Road wheels to help w/ the tippy-ness off my moderate lift.
  8. Apr 15, 2024 at 11:42 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Good idea and yeah I do feel bad of just wasting the KO2 tread. Do you know if I need alignments between switching wheels? I am getting one done with the new wheels I'm installing. Do I need another to go back to the old wheels and tires?
  9. Apr 16, 2024 at 12:25 AM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I would get brand new KO2s and in the E load. A flat or two would ruin your fun trip, don't take even a small risk. Imogene and Black Bear are rough. Keep the old KO2s at home and use them when you are back from this fun trip. 4 tires don't take a lot of space.
  10. Apr 16, 2024 at 6:28 AM
    You do not need to get an alignment when you swap back.
    Scarif_1[QUOTED][OP] likes this.
  11. Apr 16, 2024 at 9:06 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    Thanks All. New tires it is with the old in storage.
