Jacking point for tire rotation
Discussion in 'Wheels & Tires' started by 4Runner22, Aug 12, 2020.
  1. Aug 12, 2020 at 12:00 AM
    4Runner22
    4Runner22 [OP] New Member
    2019 VooDoo Blue 4Runner TRD Pro
    I want to rotate my tires, if I start on the passenger side can I jack up the vehicle in the center of the passenger side frame and place two jack stands on each side? Or will that damage the frame? I know the center of the frame is not a jacking point. How do you guys rotate your tires?
  2. Aug 12, 2020 at 12:22 AM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I was surprised when I installed my lift last week and crawled under the front of the vehicle to jack it up. Really no good points in the center. I ended up using a 1"x6"x12" piece of wood to distribute the weight and placed the jack on the radiator support/skid plate. Pretty sure I still bent the skid plate a bit.
    The frame is always the best point to place a jack.
  3. Aug 12, 2020 at 12:47 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Use the jack points as shown in the manual.
    The front ones are hard to tell, but here’s a photo of a lift positioned at the proper points, on the frame near the cross member. That’s where you place your jack or stand. BTW, I just rotate front to back, no crossing. There are several different patterns, pick one and stick with it.
    djwantke and masamitsu like this.
  4. Aug 12, 2020 at 6:58 AM
    BestGen
    BestGen Member #57
    Paul
    Haunted Turnbull Canyon, CA
    masamitsu likes this.
  5. Aug 12, 2020 at 7:08 AM
    MAXIM
    MAXIM New Member
    This is not recommended by Toyota in our 4 Runners, same side rotation only. Do not reverse direction by flipping sides.
    doublewide likes this.
  6. Aug 12, 2020 at 7:30 AM
    BestGen
    BestGen Member #57
    Paul
    It is for mine. Maybe not for yours. :thumbsup:
  7. Aug 12, 2020 at 9:07 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Looks like you’re both correct. Up to and including 3rd gen, Toyota specified the 4R pattern as crossing sides, then at 4th and 5th gen they went to same side.
    Here’s an interesting thread on tire rotation, including rotating in your spare tire.
    BestGen[QUOTED] likes this.
  8. Aug 12, 2020 at 9:25 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Here’s the page from my 2018 manual.
  9. Oct 13, 2023 at 7:36 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    Getting ready to rotate the tires for the 2nd time tomorrow, and I did not like where I had everything placed last time. I'm just doing front to back rotation, like the manual indicates, so I need to lift one side at a time.
    Would it work to put the jack on the point between the red circled points in the diagram (not the picture of the lifted vehicle), and put the stands on those circled points?
    djwantke likes this.
  10. Oct 13, 2023 at 8:52 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    G'mornin, good question. I have to do the same rotation asap. I think you're good to jack anywhere along the side frame rails between the wheels (shown in green, swing arm type lift specified). I understand that jacking in the centre would allow the jack stands to be placed under the red circles together, quicker and easier. I guess if we stick to the red circle jack points only, then you'd slip the jack stands in on the frame directly inside the red circle points. But in going with that method, I worry about the stability of the first jack stand that's in place, as you lift up the opposite end for the second jack stand, as you attempt to lift the entire side up evenly.
    Thoughts folks?
    Thanks
    RumHamRunner73 likes this.
  11. Oct 13, 2023 at 12:44 PM
    Don’t jack in the center of the frame. You’ll have to go extremely high to actually get the rear wheel to lift…it will be unnecessary unstable. That’s if your jack can even get that high.
    The rear needs to be lifted at the pumpkin. It tires will come up immediately since the suspension doesnt need to compress. Then lift high enough to get the stand under at minimum height notch.
  12. Oct 13, 2023 at 1:21 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    Instructions unclear, used three jacks no stands. Tripod stability!
  13. Oct 13, 2023 at 1:26 PM
    Genius
    Then Jack the front point and slip a stand right behind it?
  14. Oct 13, 2023 at 1:58 PM
    Well, it probably wont be that simple because if you use the frame lift point to jack, you wont have the ground space to accommodate the jack stand in the proper place.
    What I usually do is lift both front wheels at the front crossmember (or the circle nub in the stock skidplates), the put jackstands under the stand points on the frame rail. This gets the entire front up. Then also lift the rear at the pumpkin, and jackstands at the axle tubes. Any time that you lower a vehicle onto stands, do it slow! If your jack can’t lower slowly…just get another one. The car will shift and pull on the stands in odd ways due to the arc travel of the jack, and the amount of suspension travel that it has. These will be different motions depending if you lift the front first or the back first. That’s why you want to lower it sloooowly onto the stands. Keep an eye on them as you do, to verify they are not tilting onto two legs.
    For me, lifting all 4 corners in this manner is the most safe feeling way as it seemed the motions as I lowered were more predictable. I guess you could also try lifting the entire front end, but just lowering it onto a jackstand on one side, and repeat for the back. But if I recall, I didn’t like how things looked as they settled.
    Whichever way you do it. Have the proper rating jack and jackstands, I use 6ton stands for the front because i needed the height. I have a shorter 3ton set for the back, but they need to extend fully, which I don’t like, so I’ll probabably get 6tons for there too.
    Even if you decide to raise all 4 corners onto jack stands, it’s good to only remove the wheels you absolutely need to for a particular job. That way you can use your jack as backup to the jackstands near the area you are working. There’s almost no reason ever to remove all 4 tires.
    And remember, not only can stands break, but the vehicle can roll off them too. Don’t think that a vehicle will always fall straight down… the entire vehicle can move forward, laterally, or twist in a fall. So don’t put yourself between the vehicle and a hard place.
    cbrake and djwantke[QUOTED] like this.
  15. Oct 13, 2023 at 1:58 PM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    You are not wrong, that is what Toyota recommends in their manual. You also have to remember Toyota writes their manuals assuming you do not deviate from factory specs, perform 100% of services at the dealer and use the same tires that come on the vehicle from the factory. That pattern works for street tires, but if you are running AT tires with larger lugs you will develop heal/toe wear unless you cross the tires side to side and wear them the other direction.
    I highly recommend any one who questions this to do a little research on the physics behind heal/toe wear. If you do, you will understand why the back to front, front cross to rear is the better rotation pattern for rear wheel drive vehicles with all terrain/mud terrain tires.
    TrueTexas and djwantke like this.
  16. Oct 13, 2023 at 4:08 PM
    Thank-sir, super useful information. I've carefully read that all. I think I'll have to come up with a hybrid plan to lift one side fully at a time, since I just have two 6-ton jack stands. I'm confident I can safely do that and will certainly keep my body out from under the truck!
  17. Oct 13, 2023 at 4:38 PM
    Having the 6 ton jack’s height on the rear axle tube will be nicer than my short 3 ton jack. Take your time, enjoy the the work!
  18. Oct 16, 2023 at 8:49 AM
    Lou
    Lou New Member
    I should probably clarify some things:
    I have factory wheels & tires. I have a floor jack and 2 stands. I only want to lift one side at a time.
    The reason for my question was to see if there is a way to only use the jack once per side, rather than lifting the front side & placing a stand then lifting the back side and placing a stand. That way involves using the jack 4 times for the whole process instead of 2. Just looking for the most efficient, safe and correct way to do it.
  19. Oct 16, 2023 at 9:14 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    At least you have a floor jack. I recently used the OEM screw jack to rotate my tires, which must have taken a thousand or two revolutions in each direction.
    gomiami likes this.
  20. Oct 16, 2023 at 10:56 AM
    auspilot
    auspilot DustRunner
    2020 TRD OR
    Dobs IMS, lots of small stuff
    Jack the rear diff and put jack stands under the rear axle. Pull the jack around to the front and jack at the reinforced point in the middle of the front skid. All 4 wheels are now in the air. Rotate in your preferred manner.
    raimieb likes this.
  21. Oct 16, 2023 at 11:12 AM
    Lou
    Lou New Member
    I only want one side off the ground, and I definitely don't want 2 wheels off the ground only supported by the jack.
  22. Oct 19, 2023 at 9:09 AM
    To me it seemed more shifty (literally) to get it on jack stands on only one side. You should NOT do it by jacking in the middle of the length of the frame rail. Not only is the weight probably higher lifting one side vs front or back, but you will need to jack excessively high in order to actually raise the rear tire due to the axle’s articulation.
    And suppose your jack could go that high, the stands would rest on an angle to the frame, making it possibly less stable and it might dent the frame from the pressure points.
    this is why i lift all 4 corners…but only remove wheels on one side to reduce risk.
    ElectroBoy and djwantke like this.
  23. Oct 19, 2023 at 3:57 PM
    I mean @auspilot isn't wrong, his suggested method would cut the mount of jack steps, like you want. Because there isn't really another way to jack up one side properly other than what McSpaz described. I put this to the test last night performing a rearward cross, it's true (my jack is only placed in the centre of frame after jack stands are installed, just extra safety - like putting a tire under which I did too).
    But I do agree @Lou, it would be nice if it could be less jacking, but McSpaz makes a good point about vehicle side weight compared to end weights. I actually found jacking up the rear axle pumpkin is the safest and quickest. It raises tires quickly and doesn't need to go very high before you can quickly kick 2 stands under.
    Also, the centre front jack point works well too when done correctly.
    Jacking up one side at a time, one wheel at a time, ended up not being too wild of a frame angle for the jack stands, it was stable too.
    I also only have two 6Ton stands, and a 3Ton floor jack.
  24. Oct 19, 2023 at 4:35 PM
    backpacker
    2023 TRD ORP
    If you have E-load tires, it really helps to lift them no more than an inch off the ground. It's hard to line up the holes while fighting the weight. At about 3/4", it's not hard at all.
  25. Oct 19, 2023 at 7:19 PM
    Very true, yes sir, my load E tires on 9" wheels are 89lbs!
  26. Oct 23, 2023 at 8:55 AM
    Lou
    Lou New Member
    I actually ended up doing this, even though I'm not a fan of only the jack supporting the front. I used the jack at the rear differential, put stands under each side of the axle, then used the jack at the point on the front end. Just took tires off one side at a time. It was definitely more efficient than what I did last time, but I might end up buying 2 more jack stands for my peace of mind.
    auspilot and McSpazatron[QUOTED] like this.
  27. Oct 23, 2023 at 1:14 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Before you jacked anything you broke free the lug nuts on each tire?
  28. Oct 23, 2023 at 2:01 PM
    Lou
    Lou New Member
    I actually do that when it's partially jacked and the tires are barely contacting the ground. Broke the back ones first then jacked the rest of the way for stands, then the front. But only completely took off one side at a time.
