IT'S HERE!!
Discussion in '5th Gen 4Runners (2010-2024)' started by JBTRD, May 15, 2018.
  1. May 15, 2018 at 11:50 AM
    JBTRD
    JBTRD [OP] As usual, saying something stupid
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    My SSO bumper is finally here after waiting 2 months. I will be installing it hopefully this weekend or next. I will have pics of the final product.
    I do have one question, what size D-ring shackles fit, so i can get those orederd?
  2. May 15, 2018 at 12:57 PM
    jester243
    Dan
    Spokane, WA
  3. May 15, 2018 at 5:20 PM
    LostHusker
    LostHusker New Member
    South TX
    2015 SR5
    ....:worthless:
    BassAckwards likes this.
  4. May 15, 2018 at 7:48 PM
    JBTRD
    Jeremy
    Ohio
    Here is what I have, it is the plain one with no light bar, but i am waiting for KC to release their roof rack when i add light bars. I am going to order some shackles once i figure out the size while i wait for a time that i am off and can install.
    jerodsand, Backslider and LostHusker like this.
  5. May 15, 2018 at 8:43 PM
    LostHusker
    South TX
    2015 SR5
    Nice, will be watching to see the final results. :thumbsup:
  6. May 16, 2018 at 8:48 PM
    JBTRD
    Jeremy
    Ohio
    D-ring shackles orderd and i am picking up a floor jack from a friend and try to install Friday :bananadance:
    LostHusker likes this.
  7. May 18, 2018 at 4:42 PM
    JBTRD
    Jeremy
    Ohio
    Its done!! Took me 12 hours.
    Two questions:
    1) where do i get a winch plate for the outside instead of the rollers?
    2) what is a good way to combat the little bit of front sag and heavy steering?
    Chiefcrunchy and Bob like this.
  8. May 18, 2018 at 6:39 PM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
  9. May 18, 2018 at 7:10 PM
    Rguest3
    Rguest3 2018 TRD Off-Road Premium
    Lakewood Ranch. FL
    That front bumper is one of my options as well.
    If you are keeping the cable for the winch then keep the rollers as well.
    If you are going to switch to Synthetic Rope then change to a Fairlead.
    I prefer a Synthetic Rope with Fairlead and a winch thimble from Factor 55 instead of a hook.
    DrewMan and LostHusker like this.
  10. May 18, 2018 at 7:30 PM
    JBTRD
    Jeremy
    Ohio
    Will a fairlead not work with the standard cable, and why do you prefer sunthetic?
  11. May 18, 2018 at 9:53 PM
    4X4Runner
    The left coast
    You have two options. Roller fairlead or hawed fairlead. Hawser fairlead is the solid steel or aluminum. Traditional think was to avoid synthetic on a hawse and stick with a roller due to the heat build up from friction against a hawse fairlead. I ran synthetic on a roller for many years and never ever reached an angle where it would have been “pinched” in the rollers.
    Synthetic is much better all around. It’s lighter, easier to work, if it breaks it can be spilled together (Chinese finger cuffs), it doesn’t whip back when it snaps and it floats.
    Hawse fairlead
    Roller fairlead.
    Bob likes this.
  12. May 19, 2018 at 4:35 AM
    LostHusker
    South TX
    2015 SR5
    Looks good, what mods have you done to the front suspension?
  13. May 19, 2018 at 6:30 AM
    JBTRD
    Jeremy
    Ohio
    I havent, i want to maybe upgrade to the EMU traditinal 3” lift with medium springs hopeing that solves the sag and heavy steering
    LostHusker[QUOTED] likes this.
  14. May 19, 2018 at 6:58 AM
    JBTRD
    Jeremy
    Ohio
    Thanks for all the anwsers, so i have seen there are hawyse faileads that are bilt for steel lines if i decide to stick with steel or convert, not sure there yet.
    However for the added weight and heavy steering will an EMU standerd 3” lift with medium coils help solve the problem while still being good for off road?
  15. May 19, 2018 at 7:12 AM
    LostHusker
    South TX
    2015 SR5
    I can't speak to the steering but that will definitely help with the sag you have on the front, who ever you buy the shocks from just tell they what weight you have already added to the rig so they can take that into account. I put EMU on the tacoma with soft riding struts and it rides really well. The wife T4R is still in the what she wants mode...
    JBTRD[QUOTED][OP] likes this.
  16. May 20, 2018 at 6:46 AM
    JBTRD
    Jeremy
    Ohio
    Ive heard that OME tend to be a little stiff is there other options you know that tend to be as good as the OME
  17. May 20, 2018 at 6:48 AM
    LostHusker
    South TX
    2015 SR5
    I believe several people install 5100's and they like that fitment, it depends on the budget you willing to pay for. Seems like several people install the Eibachs (sp) found them on Toytec after reading it in several threads.
  18. May 20, 2018 at 6:51 AM
    JBTRD
    Jeremy
    Ohio
    Ive even heard with 5100s with OME coils dont know if it works, and i like the Toytec boss setup but that is expensive. The eibachs i looked at i dont think come with a medium duty coil.
  19. May 20, 2018 at 6:53 AM
    LostHusker
    South TX
    2015 SR5
    Ya have only done some research on that in regards to the eibachs, will do some more as this may be the way I do the runner, but would prefer to just put the OME on there.
  20. May 20, 2018 at 6:58 AM
    JBTRD
    Jeremy
    Ohio
    So far i am leaning to the OME i messaged a youtuber with a similar set up running the OME to see what his thoughts are, and if the ride is like pre bumper.
  21. May 21, 2018 at 12:18 PM
    JBTRD
    Jeremy
    Ohio
    Have done some research looking at Bilstine 5100s with ome medium duty coils, wounder if this would work and if this a good setup while not breaking the bank?
  22. May 22, 2018 at 2:41 AM
    LostHusker
    South TX
    2015 SR5
    I would talk to a couple of different vendors to see what their thoughts are about it, this would give you a better understanding towards what your needs are.
