Issue with 285/70/17 on 3" lift?
Discussion in '4th Gen 4Runners (2003-2009)' started by jrunner86, Jul 14, 2019.
  1. Jul 14, 2019 at 1:41 PM
    jrunner86
    jrunner86 [OP] New Member
    Has anyone run 285/70/17 on a 4th gen with a 3” lift and stock wheels. I installed the lift but the tire guy wouldn’t install the tires. Said I needed new wheels. Is uca rubbing a problem and will after market wheels fix the problem or will wheel spacers on stock wheels work? Rc said they recommend 285 with 3 in lift with no problems. Please help I need wisdom
  2. Jul 14, 2019 at 2:10 PM
    Dark Knight
    Dark Knight Get off my lawn
    Get the tires installed somewhere else. They will likely rub on the UCA at full lock of the steering wheel. New wheels will likely cause rubbing on the body mounts. Choose your poison.
    jrunner86 [OP] likes this.
  3. Jul 14, 2019 at 2:14 PM
    jrunner86
    Thanks brother. Much appreciated. Will wheel spacers cause the same body rubbing?
  4. Jul 14, 2019 at 2:20 PM
    Dark Knight
    Wheel spacers will cause the same body mount rubbing. Sometimes worse then if you get aftermarket wheels due to the exaggerated “offset”.
  5. Jul 14, 2019 at 3:42 PM
    jrunner86
    Thanks again for the advice. I took it to another shop and they mounted and balanced the tires. Like you said I’ve only had slight rubbing when I’m at full crank. Thanks!
    Dark Knight likes this.
