Is KDDS worth the money?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Mar 8, 2023.
  1. Mar 8, 2023 at 6:07 PM
    KDSS replaces the standard front and rear sway bars with thicker ones. The mounting points are different, also. On one side, the mounting link is a hydraulic ram. The sway bar mounting points are completely different than the standard sway bar setup, and are welded to the frame. It is installed in Japan, during manufacturing.
  2. Mar 8, 2023 at 6:08 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    I guess that makes it of good quality then, better than Fox stuff
  3. Mar 8, 2023 at 6:22 PM
    Apples and oranges.
  4. Mar 8, 2023 at 6:24 PM
    Yotaholic
    Olympia, WA
    I meant build quality. Like I have more fate in Made in Japan 4Runner than Made in Mexico Tacoma
  5. Mar 8, 2023 at 6:25 PM
    Yotaholic
    Olympia, WA
    There have been some Lemon Tacomas out there.
  6. Mar 8, 2023 at 6:40 PM
    Like @Captain Spalding said; apples and oranges. I did see that you're referring to overall build quality, though. But, the Fox suspension on the PRO is good stuff.
    True. The 3rd gen has certainly had some issues. But, they're still pretty solid. I hang out with a bunch of Taco drivers, and really don't hear about any problems.
    Yotaholic[QUOTED][OP] likes this.
  7. Mar 8, 2023 at 8:01 PM
    Cleazy
    Cleazy New Member
    San Diego CA
    2021 TRD ORP MGM
    KO2 285/70/17 FN FX Pro Wheels Dobinsons Suspension 2.5/1.5 OME UCAs Sherpa Roof Rack Alpharex Luxx Tails
    I think 1750 is way worth it especially if you get Dr. KDSS. The KDSS hydraulic ram is active and stiff after 12mph and can be very jarring on bumpy roads. With Dr. KDSS you can turn it off on forest and washboard roads. Game Changer. I use it all the time.
    https://drkdss.com/
  8. Mar 8, 2023 at 8:27 PM
    Yotaholic
    Olympia, WA
    I test drove this and hated the interior. 4Runner is way more spacious and comfortable. 4Runner feels more solid too
    Gharddog03 and jester243 like this.
  9. Mar 8, 2023 at 9:09 PM
    RunningBear
    RunningBear New Member
    2023 TRD ORP, Lunar Rock, KDSS
  10. Mar 8, 2023 at 11:37 PM
    QuocDat
    QuocDat New Member
    4runner
    More moving parts, more issues. If you want a smooth driving and willing to do the maintenance, then go with kdss. I was disappointed when my 4runner did not have it, but over time, I refer the simplicity, and I do want to get an sr5 instead orp. The a good engine and a 4wd system and that enough.
    Yotaholic[OP] likes this.
  11. Mar 9, 2023 at 2:10 AM
    Matt83
    Matt83 New Member
    Northeast
    I have it, I like it. Dr KDSS is going in this spring though. Too much time on washboards and dirt forest roads where I want it off. My one recommendation is to remove the skid plate twice per year, clean it out and apply your choice of corrosion preventative to the valve box.
  12. Mar 12, 2023 at 8:56 AM
    CO1224
    CO1224 New Member
    I have it and I like it. I originally didn't want it and was on a waiting list for one without it. Frankly, I just didn't want to spend the extra money. One was coming into the dealer with everything I wanted including the color I wanted but it had KDSS. The dealer was awesome and offered me a deal to split the cost with them (half off the KDSS cost) if I wanted it. I went for it and I am really glad I did. In addition to the other benefits mentioned like it handles well, there is a 360 camera system that I love! I'm glad I ended up getting it.
  13. Mar 12, 2023 at 9:40 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Deliberately got KDSS on my 4Runner since I do a lot of highway driving but also like to do some off roading. I also came from a little sporty car to my 4R so the potential for better highway handling was nice.
    In the end KDSS provided some great benefits on my multi month overlanding adventures and some really nice handling since I drive a little spirited still.
    As for the price, everything is all messed up. A 3k increase over old prices is not bad, hell my 4 R increased in value so much in 2020 I could have sold it for more than I bought it for in 2019 and things aren't getting better.
  14. Mar 12, 2023 at 10:56 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @Thatbassguy learned quite a bit going back reading your posts, I gotta full Dr. KDSS kit arriving soon up in beautiful British Columbia. Best of both worlds after this mod. Thank-you
  15. Mar 12, 2023 at 11:12 AM
    aesthetics
    aesthetics New Member
    Great setup! Make sure to inspect your bushings to see if they have moved and get the clamps if necessary. If you are lifted the sway bar adapters to fix the geometry in front and the BOTCK to fix the rear track bar.
    Yotaholic[OP] and Thatbassguy like this.
  16. Mar 12, 2023 at 11:18 AM
    I'm glad I could help!
    I must admit, I was very biased early on. I think I have a better outlook after having experienced the pros and cons firsthand for a few years.
    The DR KDSS mods/accessories will definitely help you get the most out of it. :)
    Most of what I know, I learned here. There are some very smart people on this forum.
  17. Mar 12, 2023 at 4:38 PM
    Do you have the DR KDSS setup?
  18. Mar 12, 2023 at 5:43 PM
    Actually, no. But, it seems like a good concept. I think if I did more high speed stuff, I'd get the controller.
  19. Mar 12, 2023 at 6:06 PM
    #49
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i learned through chatting with drkdss is that the sway bar clamps are the most important correction needed for the KDSS system. lifted or not the sway bar may begin to shift and can result things like the ram making contact with the frame.
    5six and Yotaholic[OP] like this.
  20. Mar 12, 2023 at 7:27 PM
    #50
    turfboy
    turfboy New Member
    I test drove KDSS and Non-KDSS rigs back to back on street/highway. There was such a difference I was sold on the thicker bars and KDSS. After watching Tinkerers Adventure on youtube I added Ironman CellFoam Pro shock and replaced my bushings (mine were squeaking). My rig handles like a sports car on the highway and drives off-road just fine. Next up is a Dr.KDSS switch for the fire roads in my area. I have the KDSS clamps but have not installed them yet. Since I am mainly on road and the pistons are locked up I don't see the clamps as uber important. Once the weather improves and I start wheeling more I can see the need to limit the lateral movement.
    Yotaholic[OP] and Old Tanker like this.
  21. Mar 18, 2023 at 11:24 AM
    #51
    Yotaholic
    Olympia, WA
    What does this thing do?
  22. Mar 18, 2023 at 11:35 AM
    #52
    Mine doesn't have it, and when I was looking for a used one, two different Toyota techs told me to avoid KDSS. There are two recent threads on here where some owners have been hit with some very expensive repair bills over KDSS issues. I'm sure it's great when it works, but to me it takes away from the simplicity of the 4Runner and I would not pay extra for it. I'm happy that I do not have it.
  23. Mar 19, 2023 at 10:34 AM
    #53
    Are these the same Toyota techs that are so distrusted that nobody wants to take their 4Runner to the dealer for service?
    Ripper238, 2Toys, Mickeyblue and 3 others like this.
  24. Mar 19, 2023 at 10:47 AM
    #54
    If one followed this line of reasoning, it would be advisable to not buy any 4Runner newer than 2019, due to the addition of more sophisticated electronic safety systems, which, if they stopped working, would also result in hefty repair bills. If you don't have 'em, they won't quit working, so better to not have 'em.
    That hasn't stopped too many from buying 2020 - 2023 4Runners with increasingly complex electronics.
    But, to your point, if I was shopping used 4Rs, I would actually stay with <2019. Used buyers can be more selective
  25. Mar 19, 2023 at 10:52 AM
    #55
    It allows you to manually open the valves, allowing the fluid to flow freely at higher speeds. Some say that this improves the ride quality in high speed off-road situations.
    I think it really comes down to how you drive it. But, I definitely agree that it's probably not worth it for most buyers.
    I honestly still think it's awesome for weekend warrior types, who plan moderate modifications and mild to moderate off-roading. It's definitely going to become a limitation for those more hardcore wheelers, though.
  26. Mar 19, 2023 at 1:29 PM
    #56
    Mickeyblue
    Mickeyblue New Member
    2022 TRD ORP
    Just for fun. I keep files on my vehicles and still have the file for my 2015 Trail that my husband totaled in November 2021. The KDSS was $1750. Guess how much the KDSS was on my 2022? You got it! $1750. Seven years later. What a deal!
  27. Mar 19, 2023 at 1:32 PM
    #57
    Yotaholic
    Olympia, WA
    Any problems with KDSS all those 7 years?
  28. Mar 19, 2023 at 1:39 PM
    #58
    Mickeyblue
    2022 TRD ORP
    Nope, none. Of course, in all fairness, it only had 86k (or close to that) when it was totaled.
  29. Mar 19, 2023 at 1:41 PM
    #59
    Yotaholic
    Olympia, WA
    A totalled 4Runner. WHAT happened?
  30. Mar 19, 2023 at 1:55 PM
    #60
    Interesting. What's ya'll thoughts on Dr. KDSS kit with dash switch?
