Is it worth it? Head Gasket, 2005, 180,000 miles
Discussion in '4th Gen 4Runners (2003-2009)' started by jdav, Aug 12, 2017.
  1. Aug 12, 2017 at 5:39 PM
    jdav
    jdav [OP] New Member
    2005 Toyota 4runner
    My 2005 Toyota was running perfectly when suddenly the engine vsc lights went on. I took it to my mechanic and he thought it was spark plugs, did some repairs and it stayed on. Car sounds rough when it is started in the morning, but seems to be running fine. I took it back and he said it seems like it could be a head gasket which could cost around $2000. The car has 180,000 miles. I was hoping to keep it going, but am not sure it is worth it. He said it wasn't looking to good and it could last 6mo to a year...but he can't be certain unless he opens up the engine which could be pricey. What do you think? Is it worth it, or should I look into getting a new vehicle.
    Thanks for you input!
  2. Aug 13, 2017 at 1:51 PM
    thefatkid
    thefatkid New Member
    OldManTan
    4th Gen 4Runner life
    You should post pictures of the current condition of the vehicle and your location. Is it 4wd? Good oil change history? Good service history?
  3. Aug 13, 2017 at 9:14 PM
    jdav
    2005 Toyota 4runner
    It has been well maintained, but the top coat is peeling on the top and the hood. I was actually thinking of getting it re-done. It's a 6 cylinder sr5.
  4. Aug 16, 2017 at 12:47 PM
    F250
    F250 New Member
    Alabama
    Searching for 4th Gen 4Runner
    The problem is that it's not worth much at this point unless the head gaskets get done.
    Bob likes this.
  5. Aug 16, 2017 at 2:13 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Cummins repower 2.8L Diesel !
    OvrlandNoob likes this.
  6. Aug 17, 2017 at 10:31 AM
    F250
    F250 New Member
    Alabama
    How well does the 4R drive line marry up with the 2.8L power source?
  7. Aug 17, 2017 at 3:15 PM
    jdav
    2005 Toyota 4runner
    I don't understand what that means. It is driving fine just when I first start it it's putters a little then is fine.
  8. Aug 18, 2017 at 5:24 AM
    Toyotayoda
    Toyotayoda New Member
    Atlanta area
    1997 SR5 4x4, 302k and counting
    Tacoma whip, 99 console box, tru trac., steering wheel, PWMS and HVAC control out of a 99.
    Cylinder head gaskets are a common failure for the 1GR(4.0L V6) yes it's an expensive repair, but with quality parts and proper repair procedure it will last a long time. I've done a couple and have never had to do machine work, never had a warped cylinder head, nor leaking valve seals(although it's not a bad idea), as a bonus the front cover gets re sealed which is very common to leak oil. Also, that sputter your experience on cold start is because of coolant in the cylinder.
  9. Aug 18, 2017 at 6:39 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Probably not well, just throwing useless ideas or hopeful dreams out there :) Someone has to go first!
  10. Aug 21, 2017 at 12:32 PM
    4Paw
    4Paw Don't Tread On Me
    Paul
    Watertown MA
    2017 T4R prem
    Viper remote starter, Carista fob mod, Aries mats, Rhino Rack mast holder, BLACK Fluid Film, TRD forged billet oil & radiator caps, LED puddle mirror cargo & reverse bulbs, Kat's battery wrap, Bilstein 5100 level lift, OEM hitch cover, glove box organizer, ARB Scuba mod, Lamin-X yellow w/ Calais yellow LED, lift gate stickers, dipped emblems, and the fake Pro grill
  11. Aug 25, 2017 at 6:25 AM
    Caltech90
    Caltech90 New Member
    '19 TRD OR
    I would get a second shop to take a look, if they come to the same conclusion then get it fixed. It will be cheaper than buying a new one. You might even be able to get a good used engine installed for a little more.
  12. Aug 25, 2017 at 6:28 AM
    Caltech90
    '19 TRD OR
    Have you tried to do a zero point calibration on it? My vsc lights came on after plugging in my code reader, I performed a ZPC and the lights have not came back on.
  13. Sep 12, 2017 at 6:44 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    2017 TRD OFF RD PREM
    oh the list....!
    at 180K, if all else was in good shape, I would either replace the head gasket myself, or pay to have it done, AND enjoy not having a new car note for another 150k miles....?
  14. Sep 3, 2019 at 10:26 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    2005 4runner head gasket set is $55 https://www.amazon.com/SCITOO-Gasket-Replacement-4Runner-Gaskets/dp/B07BFTGZNJ/ref=sr_1_7?keywords=Gasket+2005+Toyota+%2F+4Runner+Head+Gasket+Set&qid=1567531513&replacementKeywords=gasket+%2F+head+gasket+set&s=automotive&sr=1-7&vehicle=2005-76-1005------------&vehicleName=2005+Toyota+4Runner
    Find a good mechanic or shop with tools and experience, and it's fixable. Dealers want $3 grand.
    The set at this link says it fits my 2005 V6 SR5 (gas) engine. Guaranteed. You need to tell Amazon exactly what you drive, and they guarantee the parts will fit (on line - immediately).
    Before I'd sell my 2005 4runner with HG issue, I'd pour a can of this in there. https://www.amazon.com/Bars-HG-1-Blown-Gasket-Repair/dp/B003RGIWO0/ref=sr_1_1?crid=26AEAAEAU4TA1&keywords=head+gasket+sealer&qid=1567531944&s=automotive&sprefix=Gasket+sealer%2Cautomotive%2C201&sr=1-1
    Drain after 6 months if it fixes HG or if it doesn't.
    BTW.. my runner's HG is AOK at 150,000 miles.
  15. Sep 3, 2019 at 10:45 AM
    2016Pro
    You are two years too late I'm afraid...
  16. Sep 3, 2019 at 7:36 PM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    I did it on my Tacoma at approximately same miles. Yes, you will end at around $3000, but that is cheaper than buying another ride.
    If was you, I would use OEM parts.
  17. Sep 13, 2019 at 5:55 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Wow! Doesn't sound good. I'd take it to a good local mechanic like Scotty Kilmer (in Houston unfortunately). coolant test by scotty kilmer - Bing video
    There's a kit you can buy to check the coolant for HC leak.. https://www.amazon.com/Block-Tester-...gateway&sr=8-7
  18. Sep 13, 2019 at 6:25 AM
    2016Pro
    scottalot and Dark Knight like this.
  19. Sep 13, 2019 at 4:01 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    :notsure: maybe op hasn’t made up his mind yet :laugh:
    2016Pro[QUOTED] likes this.
