Inverter upgrade
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Sep 19, 2023.
  1. Sep 19, 2023 at 4:42 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    Kinda wanna upgrade the stock inveter. Right now I can charge my 1,000 watt ecoflow at 85 watts from the rear cigarette lighter. The AC plug doesn't seem to work I'm guessing because maybe the power is dirty.
    I'm thinking this 500 watt victron. That way if I have to run a new power cable to support the extra 100 watts it won't have to be too thick. Additionally the low watts won't kill the 4runners battery. And if I get a fridge, the economy flow can quickly charge from the car when driving rather than 85 watts.
    Any gotchas or holes in the plan. Bad idea in any way?
    https://www.amazon.com/Victron-Ener...mzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
  2. Sep 21, 2023 at 8:43 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    Grenadier Trialmaster
    Rock Sliders, Bull Bar
    djwantke and Thatbassguy like this.
  3. Sep 21, 2023 at 9:09 PM
    Thacrow
    2021 ORP
    Speed holes
    Well shoot. If nothing else I feel smart that I picked the delta 2 for the same reasons he did (from the next video he links in the video you linked).
    That's cool. Let's you run smaller wire because the DC-DC charger runs on higher colts therefore less amps, if, as he points out, you mount it under your hood.
    He's slightly mistaken actually. I think. He says that you can over run your AC inverter because when charging AC the delta 2 bypasses it's batteries and pulls power from the AC outlets if you have anything plugged into the delta 2 while charging. This is true. However, in the phone app you just need to manually limit the AC draw from the charging source.
    So as long as you do that, I think an AC inverter is more versatile. Because then you can use the AC outlet. Even add another one maybe.
    I've been looking at the victron spec sheets and looks like I'll probably go with the 800 watt one as it actually does like 650 watts or something continuous. The 500 watt one I like I think does 350.
  4. Sep 21, 2023 at 9:30 PM
    If you decide to upsize the inverter, make sure the existing wiring can handle the increased DC amperage to the new inverter.
    Do the math and if need be upsize the wiring.
    Thacrow[OP] likes this.
  5. Sep 21, 2023 at 9:40 PM
    Thacrow
    2021 ORP
    Speed holes
    So I would have used a thicker cable than the victron spec sheet has. But excellent point. I'm always afraid of a short.
  6. Sep 22, 2023 at 1:29 PM
    nova
    nova New Member
    mike
    Yep, make sure your truck is hot stuff, not your wiring :eek:
  7. Sep 22, 2023 at 6:40 PM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    Trouble24 and djwantke like this.
  8. Sep 22, 2023 at 10:41 PM
    Thacrow
    2021 ORP
    Speed holes
    You got a very cool setup there and I've always thought dual battery setup were bad ass. I don't think I have the necessity. The delta 2 does a good job and can be moved around within camp.
    Spare Parts likes this.
  9. Feb 10, 2024 at 3:17 PM
    Thacrow
    2021 ORP
    Speed holes
    I'm about to pull all my interior so sound deaden, do some stereo stuff and (hopefully) install this inverter. Anyone know how much space there is under the plastics where the stock inverter is? This thing seems a little large. It's about 10Lx7Wx3.5H
    djwantke likes this.
  10. Feb 11, 2024 at 5:38 PM
    Thacrow
    2021 ORP
    Speed holes
    Aint guna fit. Maybe if the top shelf thing were replaceable with a flat plastic instead of whats on there now which is indented. Additionally, why the F would Toyota put screws on the inside for the top panel. Seem alike it should be easily removable to service the "inverter" but no, you gotta take EVERYTHING apart to get in there.
  11. May 29, 2024 at 8:46 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    How are you liking this inverter @Thacrow ?
    A smallish pure sine that comes on with the ignition for 3-400w while driving sounds ideal for supplementing my solar automatically, since the Delta 2 can manage separate AC and DC inputs on its own.
  12. May 29, 2024 at 11:42 AM
    Thacrow
    2021 ORP
    Speed holes
    It wont fit where I want it so It was not installed. I'm going to remove the interior next weekend so I'll take a look at modifying plastics and what not and see if I can make this thing fit. As it stands it's a no go.
    Maybe I'll look at other quality brands and see if there's anything smaller.
    kojak[QUOTED] likes this.
  13. May 29, 2024 at 12:49 PM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Thacrow-
    just wanted to say that the Victron is a first class unit. I have a Phoenix 1200 watt in my hobby trailer. These things are tanks and having real power transformers in them can handle much bigger startup surges than the cheap Chinese units. I’ve run power tools and even a heat gun on mine that by rights shouldn’t even power up on something less than 1500w.
    if you are looking for something smaller and lighter the brand Giandel came up a lot in my research as one of the best of the inexpensive Chinese brands sold through Amazon. The DIY solar YouTube guy recommended them.
    Thacrow[OP] and kojak like this.
  14. May 30, 2024 at 2:20 AM
    Thacrow
    2021 ORP
    Speed holes
    I was pretty set on Victron because exactly that, its super high quality. I was looking at Giandel and about the equivalent inverter is...no surprise...almost the exact same size....probably because both are quality brands with good components. I'm going to have to remove the plastics and see what I can cut or modify to try to make it work
  15. Jun 9, 2024 at 6:56 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    Small update--swapped the Bluetti PS72 for a Delta 2 and I don't think this is a very good battery for my use case.
    It's packaged better, charges much faster on AC, has cooling fans that actually work, and a big inverter, but the DC cig output (barrel plugs are current limited) seems to have voltage sag under load. Had to switch the fridge to eco mode (which lets it get a little warmer than I prefer), otherwise the compressor runs nonstop at 75w indicating 11.5v while on the Bluetti it would happily cycle to colder temps pulling 40w or less with the fridge displaying a solid 12.7v. Weird.
    The sun is just starting to shine, so we'll see how it does on a hot day. I have a 300w inverter on the way to try out dual charging, but I'm thinking that a big dumb second underhood battery would have been smarter from the start.
  16. Jun 14, 2024 at 12:29 AM
    Thacrow
    2021 ORP
    Speed holes
    anyone know if you need to upgrade the AC outlet if you have a slightly bigger inverter?
  17. Jun 14, 2024 at 12:06 PM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I don’t know why I didn’t think about this before, but I should’ve used the wiring to the existing inverter to a DC/DC 12/24V converter, and kept the power draw to 34 amps. Then I could use the existing dash switch to turn it on or off, and also removed the inverter plug and just had an Anderson connector. Use that to plug into the Delta 2 with the solar cable end. Damn, why do I think of it now?!? The 6awg wiring I bought cost a pretty penny.
  18. Jun 14, 2024 at 3:48 PM
    Thacrow
    2021 ORP
    Speed holes
    So.....that's a really good idea. Like, excellent.
    Would that work though? Solar panels are typically 24 or 48 volt. Would the 12 volt work or does the delta 2 not care? I also have a delta 2.
  19. Jun 15, 2024 at 3:04 PM
    Thacrow
    2021 ORP
    Speed holes
    hey if anyone here knows the answer to this one....otherwise I'm going to probably make an account on some solar off grid forums.
    The green on the back of the inverter plugs into the switch right there. Looks like they also sell these adapters presumably to use your own switch. Anyone know if and why these adapters would be necessary? Or can i just plug 12v into the correct green connection off a push button factory style switch? or if the adapter is necessary I guess the push button switch into that adapter into the inverter.
  20. Jun 15, 2024 at 3:06 PM
    Thacrow
    2021 ORP
    Speed holes
    looks like this got answered in another forum wow was I being lazy. I mean it was more work typing stuff here than just adding "forums to a search I already had open. And now I'm just talking to myself probably trying to avoid this tedious stereo and inverter install..
  21. Jul 2, 2024 at 6:47 PM
    brockj
    brockj New Member
    2019 4Runner TRD OffRoad
    Why not use an under seat air compressor mount (or something similar) for the new inverter and keep both?
  22. Jul 2, 2024 at 7:19 PM
    Thacrow
    2021 ORP
    Speed holes
    I put amps under the sears. So I did this. Finishing wiring right now.
  23. Jul 2, 2024 at 7:55 PM
    Thacrow
    2021 ORP
    Speed holes
    If anyone comes upon this, per the manual and my confirmation, 12v in the left green will turn this on so you can use any switch you want.
  24. Jul 6, 2024 at 4:32 AM
    5six
    5six New Member
    55_4Runner
    2022 Black TRD ORP
    Sorry for late response. The Delta 2 will charge (solar port) with an input at 24V.
  25. Jul 6, 2024 at 4:35 AM
    5six
    5six New Member
    55_4Runner
    2022 Black TRD ORP
    I’m about to start pulling stuff apart in the hatch area to set up a baseboard for drawers. Regarding the stock inverter, what gauge is the wiring to it? How is the 400W disable (reduced 100W) modified for when you drive? Is that controlled within the stock inverter?
  26. Jul 6, 2024 at 9:19 AM
    5six
    5six New Member
    55_4Runner
    2022 Black TRD ORP
    Looks like the wire is 8 awg, so that should be fine to handle 350-400W 12.8V (27-32 amps). I’m hoping (fingers crossed) the inverter power cuts down to 100W while driving based on input signal wires. I’ll test them to see what is giving some mA’s as a signal, and hopefully use that with the dash button to turn on the Victron step up converter. Fits well in this spot, I’ll just 3D print a better way to use existing mounts if stock wiring works well
    wild.runner likes this.
  27. Jul 6, 2024 at 9:39 AM
    Thacrow
    2021 ORP
    Speed holes
  28. Jul 6, 2024 at 9:44 AM
    Thacrow
    2021 ORP
    Speed holes
    Isn't orion DC to DC? are uiu charging a lithium battery with that?
  29. Jul 6, 2024 at 10:11 AM
    5six
    5six New Member
    55_4Runner
    2022 Black TRD ORP
    Correct. Going to remove the AC outlet, and just have wires for a solar wire connection to charge my EcoFlow Delta 2 Max.
    As per your above note, I guess the wire is only pushing full amps at idle, and maybe voltage at idle is 13.3V? Trying to understand Toyota’s thinking on using 10awg.
  30. Jul 6, 2024 at 11:09 AM
    Thacrow
    2021 ORP
    Speed holes
    400 watts divided by 13 volts is about 30 amps. Per some chart you can run 10gauge for 16 feet at 35 amps, so a little further at 30 amps.
    Toyota just trying to save money.
