Intermittent Sputtering
Discussion in '4th Gen 4Runners (2003-2009)' started by Jax4x4, Feb 19, 2019.
  1. Feb 19, 2019 at 5:09 PM
    Jax4x4
    Jax4x4 [OP] New Member
    2008 White 4Runner Sport Edition
    Hi Everyone! This is my first post so I hope I am able to get some good help. So my 2008 Sport Edition 217K is starting to sputter on occasion. But I have noticed that it is happening more frequent. I tried fuel injection cleaner and changed the spark plugs. Seems like those repairs helped a little but are there any other issues I should try to check?
    Thanks,
  2. Feb 19, 2019 at 6:08 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Fuel filter since it seems to be fuel related if the cleaners help
  3. Feb 24, 2019 at 3:34 PM
    Jax4x4
    Changed the air filter, that helped a little but when I cleaned the MAF Sensor that did the trick. My 4Runner got a great tune up in the process. Thanks for your help!
    HoBoDanny and (deleted member) like this.
  4. Feb 25, 2019 at 4:44 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    What's the "MAF" sensor?
  5. Feb 25, 2019 at 5:30 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    MASS AIRFLOW SENSOR, it is mounted on the intake tube prior to the throttle body. It measures the amount of air so the ECU can send the correct amount of fuel to the engine.
  6. Feb 25, 2019 at 7:59 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Oh thanks...
  7. Mar 5, 2019 at 7:10 PM
    Jax4x4
    I'm still having the same issue after new air filter, spark plugs, injection cleaner and cleaned MAF and throttle body. The issue seems to happen around 1500 rpm. Slight stutter but if I accelerate the problem goes away. It is does not happen every time but in getting worse. Thanks again
  8. Mar 6, 2019 at 6:18 AM
    Jax4x4
    No codes, no warning lights.
  9. Mar 12, 2019 at 9:48 AM
    Jax4x4
    Denso spark plugs. I will try to clean the MAF sensor again. The last time I used 4wd it seemed like my 4Runner was stuck in 4L and took several minutes for it to release back to 2H. Have you ever had this issue?
  10. Mar 18, 2019 at 7:52 AM
    Jax4x4
    How difficult is it to replace the fuel filter? I think this is the next step in my diagnosis.
  11. Mar 20, 2019 at 7:34 AM
    Jax4x4
    I replaced the PCV valve and it almost seems like the sputtering is worse. It only does it around 1000-1500 rpms
  12. Sep 22, 2020 at 3:39 AM
    Iunek808
    Iunek808 New Member
    4th gen sport
    Howzit. Did u ever figure this out? Same thing i dealing with
  13. Mar 21, 2021 at 8:08 PM
    k1ng_Snoopy
    k1ng_Snoopy New Member
    Paul
    2004 4Runner SR5
    Having same issue. Did you ever replace the TB?
  14. Jul 23, 2021 at 7:16 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    Check it with a computer for codes/data.
  15. Jul 23, 2021 at 8:08 AM
    iamincrediboy
    iamincrediboy New Member
    Central MD
    Revive an old ass thread here. If you never found the issue, ideas:
    Stuttering going away with acceleration absolutely sounds like fuel filter. Probably replace that if you haven't.
    Other ideas to throw up... Check upstream and downstream O2 sensors voltage. Check ignition coils. Don't think you need to jump to replacing throttle body but maybe spray some more cleaner in there, sometimes it can just be built up. Maybe a can of Seafoam, upper cylinder cleaner, or other gas tank additive.
    As for being stuck in 4Lo, could also be a few things. Faulty switch, faulty transfer case actuator, loose electrical connection in the plug from the ECU, contaminated oil, loose chain...
  16. Apr 18, 2023 at 10:41 AM
    Ruiz1978
    Ruiz1978 New Member
    2007 4Runner SR5
    Hello new here :) I'm having the same issue with my 07 SR5. Stutters around 35 -40 mph. Acceleration makes it go away but it started happening more often. I've had a tune up, fuel cap replaced (major vacuum seal leak), codes all cleared. She's running great other than that damn stutter that came back. Any ides for my next step?
  17. Jun 10, 2024 at 9:31 AM
    Naynesh
    Naynesh New Member
    I am having the same issue where the car stutters at 1200-1500RPm and goes away once I hit the accelerator. Reading this thread looks like I need a new fuel filter along with cleaning the MAF. I will try these and keep everyone posted on the results. fingers crossed.
    Attached is my 06 4Runner SR5 with 2019 Tacoma TRD Off road suspension for a 2.5" lift on the front. No more rake.Picture1.jpg
  18. Oct 8, 2024 at 10:15 AM
    Naynesh
    Naynesh New Member
    Following up in my repairs,
    I replaced the fuel sending unit. I had ot drop the tank and after one broken bolt and hours of inhaling fumes, I got it done.
    Sadly, that did not fix the issue. It is still sputtering. Looks like a fuel starvation issue which only happens at 1300-1600 RPM and the car jutters.
    Anyone else have faced similar issue and willing to help?
    thanks
  19. Oct 8, 2024 at 7:50 PM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5 2wd
    Do you have access to a code reader? What do your short term and long term fuel trims look like?
  20. Oct 8, 2024 at 8:37 PM
    Naynesh
    Naynesh New Member
    Yes I do have a code reader and I am getting no codes. I am using FIXD so not a toyota specific code reader.
    I don’t understand what you mean by short and long term fuel trime
    thanks for the reply
  21. Oct 9, 2024 at 9:56 PM
    If it has a hesitation but revs out, then I don't see how it's a fuel starvation issue. Sounds more like the TPS has a worn spot in it.
  22. Oct 10, 2024 at 6:03 AM
    grumpy 02
    grumpy 02 New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
  23. Dec 13, 2024 at 9:10 AM
    Naynesh
    Naynesh New Member
    Turns out it was my transmission shuttering. I put in a tube of shudder fix and that has solved the issue. The car has 276k Mike's and probably on it's original torque converter. I did do a tranny fluid change before shudder fix but that did not help. Shudder fix only costs $10 and it's worth the money. Hopefully it stays fixed otherwise time for a new torque converter.
    BassAckwards likes this.
  24. Jan 12, 2025 at 7:08 AM
    2010 4Runner
    2010 4Runner New Member
    2010 4Runner
    Hey guys first post here, I have a 2010 Toyota 4Runner with 320,000 miles on it. Recently is starting to slightly shutter when in low gears. I have never changed nor flushed the transmission and with this many miles I’m hesitant to even try I don’t want it to get worse. I have no check engine light on not sure if it’s a solenoid that’s needs replacing and or to use this shutter fix lube that is only temporary. I do all the maintenance on this 4Runner and I really don’t want to have to replace the transmission. Torque converter maybe who knows have to take it to a shop and have them diagnose it for me. Anybody here with a similar dilemma? Thanks for your help
