Intake passages in heads
Discussion in '3rd Gen 4Runners (1996-2002)' started by CoolToyota, May 12, 2024.
  1. May 12, 2024 at 5:03 PM
    CoolToyota
    CoolToyota [OP] New Member
    98 4Runner 1A5
    Tore down my engine to fix some oil leaks and pulled the intake and wonder if I should be concerned if anything to do about the buildup !
  2. May 13, 2024 at 10:30 AM
    there is pretty much nothing you can do for it except the fancy media blast walnut shell machines. They hook over the intake and blast walnut shells in the intake runners and vacuum it out as it sprays to clean the gunk out of the intake runners. I have seen videos of it but honestly unless you put the crankcase vent on a catch can, its going to continue to gunk up again. 99.98% of drivers have no clue about gunk in an intake and dont know how to fix or prevent it, so nobody does anything about it. Its not hurting anything other than cosmetics at the point where you are at.
  3. May 13, 2024 at 6:24 PM
    CoolToyota
    98 4Runner 1A5
    Ok sounds good !
  4. May 13, 2024 at 6:26 PM
    CoolToyota
    98 4Runner 1A5
    Is this what a catch can is ?
    https://www.amazon.com/dp/B08LN4GHLP
  5. May 13, 2024 at 7:05 PM
    yes that is a catch can
    what its job is, is to catch the offgassing fumes and vapors from the crankcase and let it collect in the can, rather than going down the throat of your engine.
    Lotta people dont realize how or why the vapors happen so i'll try to enlighten you.
    1) Any and every oil, or petroleum based product offgasses as it gets hot. Depending on what the product is, the offgas temp changes. I dont know the exact temp for engine oil but i would bet around 150 degrees its offgassing. As the molecules get hot, the produce a gas, that gas has to go somewhere otherwise it would build up inside the crankcase and blow seals out. Interesting solution, they plumb it back into the intake so your engine can breathe it and hopefully burn it to meet emissions.
    2) engines with age and lots of miles have poor compression, as the piston nears TDC TopDeadCenter, and the piston is compressing the air in the cylinder, with poor cylinder walls or rings you can lose some of this compression "pressure" past the rings where it gets pushed down into the crankcase. This causes crankcase pressure which has to find a way out, and it does thru the crankcase vent tube routed into your intake.
    When you combine an offgassing oil in the crankcase plus some compression / blow-by in the crankcase, you get a crap ton of fumes and oil vapor blown up into the intake. A catch can helps collect this oil and allows it to drip down into the can so you can drain it later. I typically put a small valve on them and run a hose down by the oil pan so the catch can is easy to drain every oil change. The catch cans have a baffle where as the vapor is coming in, the vapor hits a small wall inside the can, this causes the oil vapor to hit this wall and stick, and then drip down. Its pretty simple but it works. Older engines with a lot of blow-by will puke up a bunch of oil. Boosted engines also puke up a bunch of oil and need a catch can.
  6. May 13, 2024 at 8:49 PM
    It may increase air-flow by constricting it a little. Thats how a venturi wotks. And anyways the metal is not smooth undrr there. Its rough to get a proper fuel-air mixture.
    CoolToyota[OP] likes this.
  7. May 14, 2024 at 12:39 AM
    CoolToyota
    98 4Runner 1A5
    That is very helpful and clear - thanks everyone
  8. May 14, 2024 at 10:00 AM
    I was thinking of that same thing. Sand blast this somehow....but but be very careful else you will chip edges and create other issues.
  9. May 14, 2024 at 10:03 AM
    CoolToyota
    98 4Runner 1A5
    Leave well enough alone !
    negusm and backpacker like this.
