Installing TRD Roof Rack
Discussion in '5th Gen 4Runners (2010-2024)' started by Texas4Runner, Aug 1, 2023.
  1. Aug 1, 2023 at 11:16 AM
    Texas4Runner
    Texas4Runner [OP] New Member
    Dallas/Fort Worth Texas
    2023 4Runner ORP+ CSM and Ice Cap
  2. Aug 1, 2023 at 11:22 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Elka 2.5, Apache Offroad UCA, durobumps, RCI full skids, RSG sliders, 10 lb Powertank, Maxtrax, Hi lift jack, Westscott Designs modular roof rack and ladder, ARB rear diff breather relocate, ECGS bushing upgrade, c4 low profile bumper, Baja designs S8 lightbar, warn evo winch, factor 55 ultrahook
    No experience with the pro rack. I think removal of the factory rack bolts applies to all racks.
    Carefully unscrew couple turns at a time moving around between bolts. You don't want to unscrew completely and have the plate under roof move so you can't attach new rack. If this happens I think the headliner needs to be removed to correct.
    https://youtu.be/vmeWSQBTUZE
    Good luck
  3. Aug 1, 2023 at 11:43 AM
    beedee
    beedee Member
    Use caution when prying off the roof rail caps. Fold over a towel or shirt a few times and lay it on the body next to the rail caps to help absorb the pressure from the leverage used to pry them off. That rounded portion of the body next to them dent rather easily.
  4. Aug 1, 2023 at 2:13 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    I saw a video of somebody removing the caps by prying them away from the crossbars on the inside of the rack bars where the slot for the crossbars meets the cap- uses the rack bars as the fulcrum and not the roof. And don't use an impact driver or other power tool to remove the bolts- slow and steady, alternating a few turns for each bolt with a standard ratchet wrench.
  5. Aug 2, 2023 at 4:19 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    I'm sure you already know this, but that rack is the weakest choice for carry loads. Thee are so many other options that easily double or triple the load capacity of it.
  6. Aug 3, 2023 at 1:14 PM
    Amen. I saw a poster here who dented his roof. As you mentioned fold a towel and put the towel between the roof and the pry tool.
  7. Aug 3, 2023 at 4:24 PM
    The part about switching between bolts when loosening them is spot on. Do a couple turns on one bolt then do a couple on the other side. Do 5x ratchet turns on each bolt until both bolts are out. I guess if you do one bolt at a time you run the risk of the “clip” falling down. Then you’re screwed. All the videos I’ve watched emphasize this point. Also make sure you use a towel folded when prying on the cap. For the cap you pry up not out to get it off. I saw a post here where someone didn’t use a towel and they dented the roof
  8. Aug 4, 2023 at 8:35 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    I've had several racks on and off, but one other tip I would pass on is to get a few M8 threaded studs to put in the factory holes while you are messing around with whatever mounting point you are using.
  9. Aug 4, 2023 at 11:00 AM
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    You'll want to also make sure you have the brackets that go between the roof rack and the roof: part #63185-42020 (quantity: 4).
  10. Aug 4, 2023 at 11:35 AM
    Resist the urge to over tighten
  11. Aug 7, 2023 at 1:07 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
  12. Aug 7, 2023 at 1:35 PM
  13. May 19, 2024 at 6:05 PM
    Coffee748
    Coffee748 New Member
    I wish I read this sooner. I just purchased a 2024 trd off road. I wanted the trd pro rack and found one for cheap on FB market place. Watched a video of removal install. The video mentioned placing towel down ( which I did) but assumed it was for scratches not dents it’s a plastic cover after all. Anyway trd pro rack installed super easy. But roof now has small dents. No one would ever see them, but it want to see it they can be hammered out without a repaint. The paint is not cracked at all
    on another note, does anyone know the torque specs and has anyone siliconed where the bikts mount for extra waterproofing?
    thanks
  14. May 22, 2024 at 2:45 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    Why do some want a Pro rack?
  15. May 22, 2024 at 3:00 PM
    Coffee748
    to be completely honest, it’s purely esthetics. If I didn’t get it cheap I would not have bothered.
