Ignition issue
Discussion in '4th Gen 4Runners (2003-2009)' started by Matt2005_4Runner, Jun 24, 2024.
  1. Jun 24, 2024 at 12:21 PM
    Matt2005_4Runner
    Matt2005_4Runner [OP] New Member
    2005 4Runner SR5 V6
    Hello all, I went to start my 4Runner the other day and when I went to turn the key to the right there was no resistance and didn’t stop at the ACC location or activate and of the electronics. When I entered the key it binged at me for an open door but that was it. I can turn on the dome lights and headlights. Any help would be greatly appreciated
  2. Jun 24, 2024 at 3:04 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Almost sounds like your ignition switch is broken or not recognizing the transponder chip in the key.
  3. Jun 24, 2024 at 3:24 PM
    Matt2005_4Runner
    2005 4Runner SR5 V6
    I tried my spare key and valet key with no luck. Just happened out of the blue with no warning or signs whatsoever. Any idea what the next steps would be?
  4. Jun 24, 2024 at 3:33 PM
    1SilverRunner
    Tejas
    Are there any locksmiths in your area that do vehicle work? They might be able to take a look and see if the ignition just needs to be replaced/ programmed.
  5. Jun 24, 2024 at 6:20 PM
    Matt2005_4Runner
    2005 4Runner SR5 V6
    I reached out to a couple prior to posting this and really didn’t get much except check the electronic transmission and see if it somehow became disconnected
  6. Jun 26, 2024 at 10:28 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    This is too funny, I drove home from work yesterday, got home, checked the mail, went inside and put my stuff away and went back out to check my Air Conditioner since it wasn’t blowing cold as I am used to. Opened the door, pull the hood release and raised the hood. Went to start my 4Runner and got one light beep when installing the key and when I turned the key nothing….. not even a click. So I used my power pack, hooked it up to the battery and it started but only stayed running for about 10 seconds and shut off. No “Check Engine” light nothing. I put a meter on my battery and it reads 12.61 volts. I did notice that my radio memory was erased along with the time on the clock. I just shut the hood and decided to look at it later. I will report what I find when I start troubleshooting. I am suspecting a dead cell in the battery. My alternator is only a year old but still a possibility.
  7. Jun 26, 2024 at 12:35 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    Update- my daughter pulled the battery and had it tested and the battery is good. Time for more troubleshooting.
    1SilverRunner likes this.
  8. Jun 26, 2024 at 3:34 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    My daughter re-installed the battery and started it and everything is now working, I believe my starter is going bad since it is hot here and it’s original with 283k miles. Since I have other vehicles to drive I will drive them and test the 4Runner close to home in case the problem re-occurs.
