If you've installed an add-on fuse panel, where did you put it?
Discussion in '5th Gen 4Runners (2010-2024)' started by vthoky, Jan 30, 2025.
  1. Jan 30, 2025 at 6:22 AM
    vthoky [OP] A mighty curious fellow
    A while back, with thought of add-on lights and such, I purchased a supplemental fuse panel, thinking it'd be nice to centralize power connections for the the add-on things.
    Sorta like this critter from Bezos World:
    Each time I open the hood and look for a convenient place to mount it (preferably near the main fuse panel), I come up empty-handed. I've put my amateur metalworker head on and thought up a couple of custom brackets, but I'd like to hold those thoughts for last resort.
    Show off what you've done? Thanks!
  2. Jan 30, 2025 at 8:22 AM
    clt_ah4runner
    clt_ah4runner New Member
    aaron
    haha which one? i have 4 different fuse blocks. let me know if ya have any questions on any of em
    1) engine bay auxilary: always hot blue seas 6 circuit hooked up to my aux battery & switch pro
    2) engine bay accessory: ignition controlled blue sea safety hub hooked up to main battery (relay controlled with ign/acc) for my compressor, drls, and anything i want to add so i dont need to keep using add-a-fuse piggybacks in my fuse box
    3) passenger side rear cargo: blue sea 4 circuit fuse block for my fridge, kc cyclone cargo lights, and blue sea below deck power panel
    4) driver side rear cargo: powerwerx 6 circuit fuse/bus for blue sea power panel charging with anderson powerpole & usb c inputs
  3. Jan 30, 2025 at 8:28 AM
    I sometimes take pride in my wiring jobs at work being neat and tidy, but that's impressive, man!
    I'll have questions this evening... I'm supposed to be working right now! ;^)
    clt_ah4runner likes this.
  4. Jan 31, 2025 at 5:56 AM
    PJSnow
    PJSnow Always Learning
    PJ
    New York
    2018 Cavalry Blue TRD Pro
  5. Jan 31, 2025 at 6:01 AM
    andrewtheadventurer
    What happens if you need to check a fuse in the engine bay?
  6. Jan 31, 2025 at 7:03 AM
    UG244RP
    UG244RP New Member
    andrew
    24 T4Pro
    lots
    I got the Yotaxpedition one without holes. Super simple install. In hind sight, should have just got a piece of aluminium and made one myself for 1/10th the price. Nothing to it really.
  7. Jan 31, 2025 at 7:04 AM
  8. Jan 31, 2025 at 7:50 AM
    clt_ah4runner
    aaron
    i start pounding beers. it is a pain to get to the engine bay fuses, basically need to remove the compressor/switch pro mount, thats why i added the ignition controlled fuseblock so i didnt need to take things apart just to add an accessory. it doesnt take too long to just unbolt and lift it up but its not the easiest thing in the world. thankfully, its been 4 years and i havent had a fuse blow inside the factory fuse box so it hasnt been a big deal
  9. Jan 31, 2025 at 9:50 AM
    Coincidentally, I have some thin aluminum plate on order... should be here tomorrow. :cool:
  10. Feb 2, 2025 at 9:53 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    My air compressor is passenger side behind air box, near firewall.
    My add on power panel is driver side to front of brake assembly.
    C4 fab shelfs for both.
    Mock up mounting pics below. I intend to pull power cable into passenger side front seat for GMRS mobile radio. After cable pulled I hope to install everything.
    Spare Parts likes this.
  11. Feb 2, 2025 at 9:56 AM
    Thank you for the pics.
    I'm hoping to get some head-under-the-hood time this afternoon and take another look.
  12. Feb 2, 2025 at 10:07 AM
    scottiezilla
    scottiezilla New Member
    Why I went with the surge plate from Rago
    Put me on the other side
    Plus I have one in the rear 1/4 panel? where jack is(was)…relays for that in the wheel well
  13. Feb 2, 2025 at 11:03 AM
    I did this, all wires routed / tucked to appear as OEM as possible :
    vthoky[OP] and Captain Spalding like this.
  14. Feb 3, 2025 at 12:55 PM
    Shnook718
    Shnook718 New Member
    shaun
    4runner
    Nice setup! I have a very similar setup with a RedArc bcdc1225.
  15. Feb 3, 2025 at 2:26 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    kinda ugly over the battery but solenoid for the winch, breaker for the stereo amps and then fuse for the accessories.
  16. Feb 4, 2025 at 7:25 AM
    I like that plate. Is that a homebrew, or a commercial product?
  17. Feb 4, 2025 at 8:58 AM
    Thanks!
    I made that with a piece of angled aluminum.
    Used the 2 existing bolt locations and made the fastening points slotted so it can be easily removed if necessary as to access anything below it.
