Idler hubs for a straight axle with Toyota hubcentric pattern?
Discussion in 'General 4Runner Talk' started by First4x4Gen5, Jun 10, 2024.
  1. Jun 10, 2024 at 10:39 PM
    First4x4Gen5
    First4x4Gen5 [OP] New Member
    5th gen 4Runner Off Road
    I have a new Gen5 T4R Off Road Premium.
    I want to build a small overland trailer with stock rims and tires to match. Where can I find idler hubs for a straight axle with Toyota hubcentric pattern?
  2. Jun 12, 2024 at 12:23 PM
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    OME 885/895, 265/70R17 Encounter AT
    The solution I've seen is that people will usually add a spacer (like spidertrax) on a lug centric axle hub. Because the spacer can be either lug or hub centric and will hub center the wheel, you're clear to use hub centric wheels. If you must have an axle without a spacer, I'd just commit to lug centric wheels.
    Bob and 1SilverRunner like this.
