I win the award for.....
Discussion in 'Off-Topic Discussion' started by SR5 Limited, Nov 12, 2019.
  1. Nov 12, 2019 at 11:14 AM
    SR5 Limited [OP] New Member
    D8DF99DD-6498-4AA6-ACEB-7BF0026284FD.jpg most corroded battery terminals!!! And there only a few years old!!!
    I guess cause of the Corrola’s proximity sensors and the battery always being used?
  2. Nov 12, 2019 at 11:29 AM
    Some people want over $40 for a simple terminal connection. I’m using two of the same that I got for my 4R. $10!!!FE073DEF-61DF-492B-AFC0-A9ABC621793E.jpg
  3. Nov 12, 2019 at 11:48 AM
    How about spraying some cleaner on it first?
    Terminal could possibly be fine under all that crap.
  4. Nov 12, 2019 at 11:52 AM
    No thanks. I’m not spreading that acid all over the place.....gonna wear gloves for sure....
  5. Nov 12, 2019 at 11:54 AM
    I just changed her oil. My first time dealing with the newer filters. I like it. Good for 10,000 miles!! OMG I can’t believe it!!!
  6. Nov 12, 2019 at 12:15 PM
    jester243
    Dan
    Spokane, WA
    little baking soda and hot water and any acid will be neutralized and not an issue. Grab an old toothbrush and get in there and clean them, I have used Vaseline lightly on the terminals to prevent corrosion going forward.
    jgcaps likes this.
  7. Nov 12, 2019 at 3:06 PM
    I like to scrape it into a salt shaker and sprinkle it on my pancakes.:rolleyes:
  8. Nov 12, 2019 at 3:56 PM
    I keep my battery in that condition so that when I am camping i just scrape a little in my coffee in the mourning.
  9. Nov 12, 2019 at 3:57 PM
    The best part of waking up...:D
    jester243 likes this.
  10. Nov 12, 2019 at 8:04 PM
    WallyT4R
    WallyT4R New Member
    All you need is a can of coke and wire brush to clean those up. Then spray the terminals with metal protector.
  11. Nov 12, 2019 at 8:07 PM
    Rather pay twenty bucks...The ground is rusted bad. There’s no saving these...And I’m not wasting any of my Diet Cokes on it...
  12. Nov 12, 2019 at 11:18 PM
    4X4Runner
    The left coast
    Water and baking soda. Apply liberally and rinse with water. Cleans that shit right up.
    Tama1968 and WallyT4R like this.
  13. Nov 12, 2019 at 11:21 PM
    4X4Runner
    The left coast
    Remember. Baking soda is a base so it reacts with the battery acid to neutralize the acid.
  14. Nov 12, 2019 at 11:22 PM
    4X4Runner
    The left coast
    You could spend literally no money and fix it for what’s in you cupboard for a grand total of $free.99
  15. Nov 13, 2019 at 3:56 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Leave him alone he'd rather spend the money. :ohsnap:
    WallyT4R likes this.
  16. Nov 13, 2019 at 3:58 AM
    Agent_Outside
    Built 2011 T4R Limited
  17. Nov 13, 2019 at 9:55 PM
    WallyT4R
    WallyT4R New Member
    Tama1968 likes this.
  18. Nov 14, 2019 at 8:02 AM
    Texdoc
    Texdoc New Member
    james
    2017 SR5 4X4
    none
    we assume the battery hasn't been replaced? those are nasty.....
  19. Nov 14, 2019 at 10:20 AM
    Around two years old. Terminals were replaced too.
  20. Nov 17, 2019 at 9:02 AM
    After: the terminals were copper so it speeded up the corrosion process. These should last a lot longer...6095E12E-B6C6-4791-94A7-1C6FBC0047E1.jpg
  21. Nov 17, 2019 at 9:35 AM
    So you didn’t get rid of the corrosion?
  22. Nov 17, 2019 at 11:06 AM
    Texdoc
    Texdoc New Member
    james
    2017 SR5 4X4
    none
    hello again. I bought a certified Toyo that came of the east coast which had some rust along the frame, exhaust, muffler, etc; cleaned and took care of that issue. Short of a boat or tractor, I have never seen that extent of rust/corrosion. My dear wife drives a '13 Highlander and the engine compartment is pristine, minus the bugs and dust.
    Yes sir, your won the prize for.....
  23. Nov 17, 2019 at 2:33 PM
    WallyT4R
    WallyT4R New Member
    Not if you don't spray them with some type of dry lube or protectant.
  24. Nov 17, 2019 at 2:35 PM
    WallyT4R
    WallyT4R New Member
    :frustrated:
  25. Nov 17, 2019 at 2:45 PM
    :homer: :sandwich:
  26. Nov 17, 2019 at 2:49 PM
    I used dielectric compound......Can’t you see the terminal eBay pic of the replacement for ten bucks?
