I broke it
Discussion in '4th Gen 4Runners (2003-2009)' started by Yota 4gen Tn, Jan 25, 2019.
  1. Jan 25, 2019 at 9:50 AM
    Yota 4gen Tn
    Yota 4gen Tn [OP] New Member
    Joshua
    04 Toyota 4Runner
    3” lift, front bumper and winch. Light bars.
    So out playing in some deep mud puddles I found a rock, it pushed my factory skid plate back and hit that plastic box. I don’t know what part it is to order a new one. All I know is my 4x4 is flashing at me and does not work. Can someone help.
  2. Jan 25, 2019 at 10:12 AM
    4X4Runner
    The left coast
    Probably your 4x4 actuator. That’s my guess but it’s hard to tell from the picture.
  3. Jan 25, 2019 at 10:15 AM
    4X4Runner
    The left coast
    Or the ADD on the front axle
  4. Jan 25, 2019 at 10:34 AM
    Yota 4gen Tn
    Joshua
    04 Toyota 4Runner
    What is the ADD? And it is on the front differential.
  5. Jan 25, 2019 at 10:58 AM
    4X4Runner
    The left coast
    ADD is automatic differential disconnect.
    “This system is composed of a vacuum-activated shift fork in the front differential driver's side axle tube: when the transfer case lever is moved to the 4Hi position, vacuum is applied to the fork which in turn moves a sleeve to lock the inner stub axle shaft from the carrier to another shaft in the tube. This axle assembly powers the driver's side wheel, while the passenger side is a single shaft from the carrier to the inner CV joint.”
  6. Jan 25, 2019 at 4:53 PM
    Yota 4gen Tn
    Joshua
    04 Toyota 4Runner
    Part number?
  7. Jan 25, 2019 at 5:16 PM
    4X4Runner
    The left coast
    I don’t have the part number off the top of my head.
    Does it look like the circled part in this pic?
  8. Jan 25, 2019 at 5:20 PM
    4X4Runner
    The left coast
  9. Jan 25, 2019 at 5:21 PM
    4X4Runner
    The left coast
    Don’t take my word that it is actually that though cause without seeing more I’m just spitballing and guessing it’s that
    SlvrSlug likes this.
  10. Jan 25, 2019 at 6:00 PM
    Yota 4gen Tn
    Joshua
    04 Toyota 4Runner
    Thank you I have been trying to even find a place to start looking. And yes I will confirm it is the right part before I spend money on anything.
  11. Jan 28, 2019 at 7:10 AM
    blackoutt
    blackoutt New Member
    Southern IN
    2007 4Runner Limited V8
    Adventure Build
    V6 only have the ADD? I don't recall seeing that box on my v8 awd. Also might to check your alignment, looks like one sides all the way out and one sides centered.
