Humming noise at highway speeds
Discussion in 'General 4Runner Talk' started by GDawg, Nov 27, 2023.
  1. Nov 27, 2023 at 7:39 AM
    GDawg
    GDawg [OP] New Member
    2021 Red 4Runner
    Shifter Knob (Black, Red Plates) BugFlector (Black) Canvas Back (Black, red stitching) 17" Method 701 (Black) Wildpeak AT3w P, Stock Size
    I've tried searching the threads but I'm a newbie here and have had no luck.
    2021 4Runner Premium
    Issue:
    On the highway, anywhere from about 55mph and up, when the vehicle is just barely maintaining speed, I hear a slight humming "ooooooooooooo" sound that goes away when I let off the throttle. This noise occurs on both cruise control and with the pedal. Generally only occurs on flat roads as the RPMs hit the magic number to make this noise, around 1700rpms I think.
    Basically I only hear this sound when just enough throttle is being applied to maintain highway speed.
    Thoughts?
  2. Dec 3, 2023 at 3:06 AM
    4R4L_2023
    4R4L_2023 New Member
    24' XP UndGrnd 23' XP Mag Grey
    Staying Stock
    Can you be more specific? Around what area it's coming from (top, bottom, front or back)? You have a roof rack? What type tires?
  3. Dec 3, 2023 at 4:18 AM
    Swampbuggy
    Swampbuggy New Member
    Check to see if you have differential fluid leaking , could be a bad seal/ gasket.
    Technologic80 likes this.
  4. Dec 3, 2023 at 7:15 AM
    4runningMan
    4runningMan New Member
    New Mexico
    Pretty sure it’s a “normal” sound. My 2018 does it too. I think it’s a resonance sound. I can force it to happen in my truck via throttle control at about 60mph. Also, the sound got louder when I got new tires. But the sound isn’t from the tires.
  5. Dec 3, 2023 at 7:18 AM
    4runningMan
    New Mexico
  6. Dec 3, 2023 at 7:38 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Needle bearing
  7. Dec 4, 2023 at 4:38 AM
    GDawg
    2021 Red 4Runner
    No roof rack, happens on two different sets of tires. It is specifically happening when the accelerator is pressed just enough to maintain speed around 1700 RPM on the highway so around 65 -75mph is the only time I can hear it. If I let off accelerator it stops, if I accelerate it stops, it's only when maintaining cruising speed. Happens with pedal or cruise control.
  8. Dec 4, 2023 at 5:04 AM
    My 164k mile 2013 is starting to get kind of growly at speeds over 63, I suspect it may be the needle bearing.
    Either that or tires, mine are at 52K. I know certain tires get louder if they wear, not sure if that's the case with Grabber ATX.
  9. Dec 4, 2023 at 6:56 AM
    4runningMan
    New Mexico
    Needle bearing sound goes away in 4wd (if I remember correctly). It’s different from the sound the OP is talking about.
  10. Dec 4, 2023 at 2:22 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    He said the noise goes away when he lets off the gas pedal. So can not be those things
  11. Dec 4, 2023 at 3:06 PM
    4runningMan
    New Mexico
    I’m 99% sure it’s the “diff howl”. Harmless harmonics, most often. But yeah, it’s kinda weird. You can make it happen intentionally with light throttle control and certain speeds (mine is around 60-63mph). Mine changed a bit when I got new tires. Seemed to get a little more pronounced.
    McSpazatron and Technologic80 like this.
  12. Dec 4, 2023 at 3:07 PM
    4runningMan
    New Mexico
    Google “4runner diff howl” and read all about it.
    ChessGuy and Swampbuggy like this.
  13. Dec 5, 2023 at 3:58 AM
    4R4L_2023
    Staying Stock
    Sounds like harmonics. Change your rear diff fluid and make sure to grease joints every 3k miles. I changed mine at only 10 months old and 3500 miles, from the factory it only had 2.5 quarts in it (1/2 quart low) and magnet full of metal.
  14. Dec 10, 2023 at 4:32 AM
    Swampbuggy
    I’m new on this chat forum, I’m not tech savvy . So learning how to reply on these things, bear with me .
    We had to rebuild the rear end on our truck. It wasn’t a Toyota , but you can hear the howl as you speed up and it decreases when you let off the gas and slow to a much slower speed .
    Armena likes this.
  15. Dec 10, 2023 at 5:46 AM
    plus at only 2 years old these shouldnt go bad
  16. Dec 10, 2023 at 8:34 AM
    Definitely the diff in the back. I have a similar thing after regearing on the Taco and the 4R. For me is fine, and if you are noticing a wear smell, like burnt popcorn which is the gear oil being over the threshold temp, then you are ok.
    You might want to check that the breader at top is still functional and open and not damaged. If water when in and couldn't vent out then there is a chance there for expansion of the water when it gets hot. Good luck and let us know what you find out.
    Armena likes this.
  17. Dec 10, 2023 at 10:54 AM
    Armena
    Armena New Member
    Armen
    2022 Magnetic Grey SR5
    K&N filter TRD matte black Pro wheels Stock size Nitto Terra Grappler G2’s Bilstein 5100’s. .85 setting 20% nano ceramic tint all the way around Pedal Commander. City +3 normally AJT climate and radio knobs AJT chrome door handle covers Carbon fiber interior accents. TRD shift knob LED interior lights/license plate LaSfit mats Exterior black out kit/steering wheel.
    I had the same thing. Researched for weeks and finally took it to the dealer being under warranty and it ended up being my rear end. The replaced all the internals. Power train covered it. $4,300 job. Got it back, all gone. Mine is a 22 2wD but I bought used so no idea what they did prior. He said it did have some metal shavings in the fluid but nothing extreme. Im just glad my power train warranty covered it!
  18. Dec 10, 2023 at 4:36 PM
    4runningMan
    New Mexico
    I’ve now driven three 2018+ 4Runners and I could make the sound happen in all three when I tried. So I’m convinced it’s harmless harmonics.
    ChessGuy likes this.
  19. Dec 10, 2023 at 7:47 PM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    I did that just now, and yep... definitely a well-documented phenomenon!
  20. Dec 26, 2023 at 6:01 AM
    GDawg
    2021 Red 4Runner
    This seems most close to what I've been experiencing. I may take in to the dealer just to see what they say?
  21. Jan 24, 2024 at 8:13 PM
    Nightshade2021
    Nightshade2021 New Member
    Ontario canada
    2021 4runner nightshade
    Ceramic coated
    Hi all I have a 2021 Toyota 4Runner (Full time AWD) also 4WD option
    I have been having the exact same issue, I have taken to the dealer twice. First time he said it’s normal characteristics and second time he felt slight vibration, while talking the entire test drive on purpose so we wouldn’t hear the noise.
    The noise is not extremely loud. I would describe it as a slight pulsation, like not a steady noise, and can feel the noise vibration as well in the gas pedal. (So hard to describe) goes away when I let foot off accelerator. Noise does not go away in 4WD) . I feel like it is on drivers side not the rear or maybe it is the rear vibrating to the front. It is driving me nuts.
    [Gdawg] tell me u found the problem
  22. Jul 16, 2024 at 3:48 AM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Bumping an old thread, but I have had this issue too. At highway speeds its the 'ooooooooooooooo' sound as described by the OP. No idea what it could be from but it drives me crazy. As soon as I let off the throttle, it stops. I use cruise control all the time and it happens when the throttle picks up to maintain speed while in cruise as well.
  23. Jul 16, 2024 at 6:21 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Drive shaft?
    carrier bearing?
    only under throttle application means when load is applied. So something is worn and tolerance is poor.
  24. Jul 16, 2024 at 6:57 AM
    laxman09
    Great, taking the 4R down to Myrtle in less than 2 weeks. There is no vibration that I feel. I also grease the propeller shaft a few weeks ago.
    Its a 2020 and still under CPO warranty. I guess Ill have to risk the $160 diagnostic fee and see if I can get it looked at.
  25. Jul 16, 2024 at 3:09 PM
    4runningMan
    New Mexico
    Did you end up taking it in for the howl? Learn anything?
  26. Aug 2, 2024 at 8:59 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I am very disappointed in dealers doing any kind of diagnostics. First I would look for an independent shop that specializes in the part you suspect. Dealers only follow the SHOP manual for diagnostics. So read a shop manual first and see if that makes sense to you. Sometimes dealers have electronic test equipment needed for completing the assessment -hence a good independent shop might have same or better electronic equipment.
  27. Aug 2, 2024 at 9:59 AM
    laxman09
    I drove from OH to Myrtle this week, the humming only happens between 67-71 mph when I'm giving it gas, any faster/slower or when I let off the gas and it stops. I'm guessing it's just a resonance thing.
  28. Aug 2, 2024 at 11:50 AM
    If it is a howl or some sort of harmonic and a very certain speed, then it could be the diff. There are plenty of tests and things to do to check the diff. Good luck.
  29. Oct 31, 2024 at 12:13 PM
    MJ Law
    MJ Law New Member
    Michael
    2021 Silver 4Runner
    2.5 lift, 285 tires, DR. KDSS kit. BMC
    Just dropped off my 2021 4Runner at the Dealer today for the same issues. They've driven locally and have placed it on the lift with ZERO findings. I authorized them to let a Shop manager drive it home. Hopefully he can hear the issue. Ill keep everyone posted!
  30. Oct 31, 2024 at 2:24 PM
    good luck, they’ll say its fine. Ugh!
