Hub Spacers on 4th Gen
Discussion in '4th Gen 4Runners (2003-2009)' started by Steinweiner, Oct 20, 2020.
  1. Oct 20, 2020 at 11:35 AM
    Steinweiner
    Steinweiner [OP] New Member
    Steve
    2006 Toyota 4runner
    Billstein 5100, Kuhmo A/t's..
    I know there are a lot of threads on this...I have an 06...Purchased some spacers and took it to the tire shop where I bought my tores (Evans Tire) for install (I don't have na impact wrench) They said they can't even touch spacers, or vehicles with spacers on them., They said it would void the warranty on the tires, and once installed, they would no longer be able to even rotate and balance (...against the law here in CA).. So I called around..Discount Tire. America's Tire, Big O, and Pepe Boys all have said the same thing...So, I called over @ Off Road Warehouse (Where I had the Bilsteins installed) and they were like"Yeah..we sell spacers, but we don't recommend putting them on....stresses out all of yoru other componenets..Just buy new wheels with a zero offset..no issues.." But, I have 18's (06 limited wheels), and already purchased the 18" tires (annot exchange)..so...I guess I have to plunk down another $700 for new wheels? Uggg...all so my wheels will stick out an inch or so...thoughts? I don't do ANY offroading....
  2. Oct 20, 2020 at 11:40 AM
    Mtbpsych
    Mtbpsych New Member
    I think the installing the spacers carries too much liability maybe? They have to be checked often, and yes it adds stress and an extra piece that can break somewhere you don’t want it to. Are your tires already on? You should be able to return them within a certain timeframe.
  3. Oct 20, 2020 at 11:48 AM
    Steinweiner
    Steve
    2006 Toyota 4runner
    Thanks for the response..I bought and put on the tires 2 weeks ago..so...too late for exchange, etc...
  4. Nov 17, 2020 at 10:27 PM
    TriaxT4R
    TriaxT4R New Member
    San Diego, CA
    2008 Sport 4x4
    Bilstein 6112/5160 (3/2), Icon 2” rear springs, Fuel Anza, Ridge Grappler 285/70-17
    I have spider trax on all four, discount told me differently as far as rotating. I haven’t heard of any issues with spider trax as long as you install them correctly of course. If your in SD area, Miramar truck rotated mine with spacers.
  5. Nov 18, 2020 at 7:19 AM
    Welcome to the forum.
  6. Nov 18, 2020 at 7:27 AM
    Maybe invest in a floor jack and 4 jack stands instead. You could rotate the tires yourself and it will be cheaper then new wheels.
    Moon Landing likes this.
  7. Nov 18, 2020 at 8:52 AM
    Steinweiner
    Steve
    2006 Toyota 4runner
    I'm going to get the spyder trax (..I think they offer them in black now?). you've inspired me! The rotaion I can do myself, but I'm pretty particular when it comes to balancing (..which I do every rotationhy offer. them n black) .I will reach out to Miramar truck.. I can't believe how much 1.25" makes as far as the look/stance..Did you install them yourself? Other than changing a tire, I've never used a torque wrench...just not sure if installing spacers is the place to try it out for the firist time unsupervised lol... Thanks for the info everyone!
  8. Nov 18, 2020 at 8:57 AM
    Spacers are extremely easy to install. You can do it. It's just turning a wrench.
    Definitely use a torque wrench on them. That's important.
    I think Spidertrax recommends using locktite on the bolts as well.
  9. Nov 18, 2020 at 9:11 AM
    Steinweiner
    Steve
    2006 Toyota 4runner
    I appreciate the confidence. I'll just man-up and just do it..I have a floor jack and wheel blocks, and Youtube, soshould be good to go..
    nimby[QUOTED] likes this.
  10. Nov 18, 2020 at 9:17 AM
    Just follow the instructions Spidertrax gives you.
    People talk a lot of shit on spacers, but they are fine if installed correctly and checked from time to time. I just installed a set on mine.
    I still don't understand the argument that they will increase wheel bearing wear, but lower offset wheels are ok?? Seems like it would be the same difference to me.
  11. Nov 18, 2020 at 9:21 AM
    Steinweiner
    Steve
    2006 Toyota 4runner
    That's what I thought as well...I'm only going 1.25"..99% pavement driving...I'm sure I'll be fine. Thanks!
  12. Nov 18, 2020 at 1:19 PM
    TriaxT4R
    TriaxT4R New Member
    San Diego, CA
    2008 Sport 4x4
    Yes they do come in black, that’s what I got...I did the install, it’s very easy but, you do need a torque wrench. Star pattern and do maybe half the final torque all the way around and then again star pattern at final torque (I did mine in 3 steps, but I was also weary about spacers at first)..and yes you use locktite, it comes with it.
    Also make sure the mating surfaces are clean, I used a wire brush to clean off surface rust....but, that’s just me
    Moon Landing and nimby like this.
