How wide can stock 4Runner go with tires?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Aug 31, 2023.
  1. Aug 31, 2023 at 3:28 PM
    San Angelo
    San Angelo New Member
    Don’t get that model of the KO2 unless you’re ok with a very rough ride and possible balancing issues.
    bassist and Yotaholic[OP] like this.
  2. Aug 31, 2023 at 3:33 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Good catch -- those are the E rated tires. There's a C rated version as well that will be a bit less punishing.
    Personally, I have the C rated ones in the stock size - it's still a firmer ride than stock at the appropriate air pressure.
    Yotaholic[OP] likes this.
  3. Aug 31, 2023 at 3:34 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    They have given me 30 days think lol
  4. Aug 31, 2023 at 3:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @bassist
    Thank-you for this information
    See attached
    Think I should run 40 psi instead of around 37?
    Cheers
    @Yotaholic
  5. Aug 31, 2023 at 4:03 PM
    Are you willing to trim some plastic?
    285's Will almost certainly rub on some plastic. But, with a good alignment, it should be easy to clear.
    Lift does not clear tires anyway. It just hides the rubbing.
    Yotaholic[QUOTED][OP] and Kezin like this.
  6. Aug 31, 2023 at 4:08 PM
    Yotaholic
    Olympia, WA
    Not willing to do any trimming lol
  7. Aug 31, 2023 at 4:10 PM
    Then stick to a 265/70/17.
    Most 275 only come in LT load ranges. If you're going to go with that anyway, then go for it. But, otherwise it's not worth it for the extra quarter inch of clearance.
    Yotaholic[QUOTED][OP] likes this.
  8. Aug 31, 2023 at 4:12 PM
    TCW1184
    TCW1184 New Member
    23’ 4R TRD Pro
    You don’t need new tires, you need new wheels. 17x9s are the widest you can go on 10.50s and have it look decent. Had that same setup on a previous 1st gen Tacoma.
  9. Aug 31, 2023 at 4:15 PM
    Yotaholic
    Olympia, WA
    Which version of KO2 is best offroad?
  10. Aug 31, 2023 at 4:59 PM
    Any version will perform fine. You'll get more puncture resistance with a heavier load range, though. It depends on what kind of terrain you're going to be in.
  11. Aug 31, 2023 at 5:27 PM
    Are you going to get a shop to do the install? If you're having a somewhat offroad shop installing anyways, they'll likely trim it for you quick as part of the install. My shop tested turning, rubbed a bit and they Dremel cut a small sliver under the bumper you don't even see.
    Food for thought if you actually want the look of 285 or perhaps even 275. Depending on the alignment, you might rub while turning in reverse if you move up in size, regardless. Don't be scared of a small trim or fender liner adjustment.
  12. Aug 31, 2023 at 5:35 PM
    Yotaholic
    Olympia, WA
    I got this now
  13. Aug 31, 2023 at 5:37 PM
    Yotaholic
    Olympia, WA
    Going for the best deal and you can't beat Discount Tire
  14. Aug 31, 2023 at 5:45 PM
    Yotaholic
    Olympia, WA
    I think mine is C. Anything over that I fear will change ride quality. I believe they come upto E.
  15. Aug 31, 2023 at 5:50 PM
    bassist
    bassist New Member
    I think that's probably a good idea.
  16. Aug 31, 2023 at 5:51 PM
    bassist
    bassist New Member
    That's what I have.
    You'll definitely need to go up in tire pressure. I'm probably going to end up around 44psi. BFG's help folks will tell you 50 even though that's the cold inflation max.
    The ride is going to be firmer than stock, FYI.
  17. Aug 31, 2023 at 5:56 PM
    Yotaholic
    Olympia, WA
    I am at 39 psi cold right now.
  18. Aug 31, 2023 at 6:02 PM
    Yotaholic
    Olympia, WA
    Who runs 35s here? What did you do to be able to run 35s with zero rubbing?
  19. Aug 31, 2023 at 6:05 PM
    #49
    bassist
    bassist New Member
    That's probably low. If you feel any vibrations, that'll be a telltale sign.
  20. Aug 31, 2023 at 6:07 PM
    #50
    Yotaholic
    Olympia, WA
    I feel vibrations, but not on smooth Highway. What do you recommend, 44 cold? 44 should help mpg too.
  21. Aug 31, 2023 at 6:20 PM
    #51
    Heard. All good buddy
    Dude honestly 35's are lightyears beyond anything you're willing to do
  22. Aug 31, 2023 at 6:46 PM
    #52
    I had those exact tires for around 29K miles.
    44 PSI is the recommended inflation for that size and load range on our 4Runners. However, I ran mine at 35 with good results. They were all at 12/32 when I replaced them, and they were on my buddy's Ford Ranger for 3 years after that.
  23. Aug 31, 2023 at 6:50 PM
    #53
    I have 33.5's, with a BMC, viper cut, and no mud flaps, and they rub on the firewall on a good hump.
    Fitting 35's is a commitment. You're bashing the firewall and pinch welds with a hammer, cutting plastic and metal, and probably still rubbing at full lock and stuffed.
    Aside from that, a re-gear is basically a given if you are going that big with tires.
  24. Aug 31, 2023 at 6:50 PM
    #54
    Yotaholic
    Olympia, WA
    44 cold you mean? Cuz with 39 cold after driving for a while I do get to 42.
  25. Aug 31, 2023 at 6:51 PM
    #55
    Always cold. Tire pressure is never measured warm.
  26. Aug 31, 2023 at 6:52 PM
    #56
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    I run 38 PSI (cold) in 6 ply BFG KO2's but I don't carry any extra weight. (No aftermarket bumpers, winches, sliders or roof racks) I go to a very reputable tire shop that knows how to use a Road Force balancer properly. Absolutely zero vibrations.
    Thatbassguy and Yotaholic[OP] like this.
  27. Aug 31, 2023 at 6:53 PM
    #57
    Yotaholic
    Olympia, WA
    I just wanted to make sure. These are some high numbers, because the sticker on my 4Runner recommends 32.
  28. Aug 31, 2023 at 6:58 PM
    #58
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    The door jamb sticker is for OEM "P" rated tires. You are now using "LT" tires. Totally different.
  29. Aug 31, 2023 at 6:58 PM
    #59
    LT tires are designed to run at higher pressure. Even my 295's call for 35 PSI.
    But, not everyone goes by the charts. If you're getting a rough ride, or uneven wear, a slightly lower pressure is probably fine. My KO2's wore beautifully at 35. This was before I bolted on a few hundred extra lbs, though.
  30. Aug 31, 2023 at 6:59 PM
    #60
    Yotaholic
    Olympia, WA
    But with 44 there is no way I can drive on the trail, I need to be airing down, Chiropractic adjustments are not cheap.
