How to disable seat belt alarm?
Discussion in '5th Gen 4Runners (2010-2024)' started by galeenster, Jul 6, 2017.
  1. Jul 6, 2017 at 3:23 PM
    galeenster
    galeenster [OP] New Member
    Is there a way to deactivate the Seat Belt alarm/dinger?
    Some other vehicles have this option.
    With Dodge and other select vehicles you can silence the BEEP through a series of actions. Just wondering if there was a backdoor cheat code type solution for 4-Runners.
    For example: 'Put on the seatbelt, turn the vehicle to ACC, disengage the seatbelt and then reengage, repeat the last step twice, press the brake then turn the vehicle off'. This is only an example and not the actual disabling sequence for anything.
  2. Jul 6, 2017 at 3:45 PM
    OvrlandNoob
    OvrlandNoob New Member
    Arcadia, CA
    2016 4Runner Trail Premium w/KDSS
    Bilstein 6112 and 5160 with Bilstein rear coils. SPC UCA s, TRD Pro wheels, Shrockworks sliders, Nitto Ridge Grapplers 265/70/17
    I believe you can just by the buckle and plug it in?
  3. Jul 6, 2017 at 3:54 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    There is no simple, reversible way other than using the Techstream software to turn it off. Even if you turn off the beeping, the light on the dash remains illuminated.
  4. Jul 6, 2017 at 4:27 PM
    galeenster
    I'm OK with the dash light staying on. And the dinging eventually goes off but restarts every time you stop and start moving again.
    I'm able to silence the dinger in my Dodge with a series of actions.
  5. Jul 6, 2017 at 6:18 PM
    Kyotii
    Kyotii New Member
    2016 TEP W/KDSS SILVER
    WINDOW TINT!.....
    The way I did it and changed other features without techstream is to get a cheap Bluetooth obd interface on Amazon then use carista app to change the settings. Easy and cost me 20 bucks or less.
    galeenster[OP] likes this.
  6. Jul 7, 2017 at 8:44 AM
    TedRCASC
    TedRCASC New Member
    Ted
    When we go off road we are usually hopping in and out of the truck to take photos. So I simply buckle the belt behind me, That shuts it up. - Ted
  7. Jul 7, 2017 at 9:29 AM
    galeenster
    Thanks Ted,
    That's what I would do in my Jeep. With my Dodge trucks there is a way to silence the beep through a sequence of actions. Was really trying to see if there was a similar way with the 4-Runners.
    Problem with sitting on it to silence the beep is that I found I was sitting on it even when I should have been using it.
  8. Jul 7, 2017 at 9:42 AM
    TedRCASC
    TedRCASC New Member
    Ted
    I don't really sit on it so much as lean back against it. Indeed, I'll probably use the belt on many off roads. But not when we're in very scenic country, or have a chance to photograph some wild critters. Then I like to be out and in quickly. especially in grizzly country! - Ted
  9. Jul 11, 2017 at 12:25 AM
    Sir James
    Sir James New Member
    JT
    '17 TRD Pro
    Just ask your SVS Dept next time you are in. They did it for my no questions asked.
  10. Jul 11, 2017 at 6:03 AM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Lucky, i tried all 4 local dealers and even a lexus dealer, and they would bot do it.
  11. Jul 11, 2017 at 6:08 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    the easy way to do this go to the scrap yard find a toyota buckle . cut off the buckle set scrap yard buckle in seat belt hole all done... make a pattern so it is matching with the size pattern of the one on your vehicle.
    AZ4walker likes this.
  12. Jul 11, 2017 at 12:21 PM
    galeenster
    It's a 'liability' for a dealer to disable the seat belt dinger........If you got a dealer to do this you were very lucky.
  13. Jul 11, 2017 at 2:42 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    They say that but that's bullshit. Mine did it for me on two 4Runners... I gave them a list of the stuff I wanted adjusted via Techstream when I signed the papers, they went back and did them all, and that was that. If it was such a liability, it wouldn't be an option through Toyota.
  14. Jul 26, 2017 at 12:47 AM
    larramo
    larramo 3ed gen faithfully
    larry
    clearlake ca
    4 runner
    3" lift but mostly all stock not a scratch on it it is pristine condition amazing for being 19 years old.
    simple pull the fuze. LARRY B.
  15. Jul 26, 2017 at 5:52 AM
    j cat
    j cat New Member
    massachusetts
    what fuse did you pull out ?
  16. Jul 27, 2017 at 9:40 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    There's no fuse that controls just the seat belt chime. Larry showed up and has been dropping some knowledge bombs on several threads. He's wrong about half the time and the other half of the time he's not right.
  17. Jul 27, 2017 at 9:43 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Is that like a trunk monkey?
  18. Jul 27, 2017 at 9:55 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    :bananadance:
  19. Aug 17, 2017 at 8:16 PM
    4runick
    4runick New Member
    2014 silver 4Runner
    Basically toytec ultimate, tint, lower front valance, rock lights, 20" light bar, 285/70/17 Dueler AT, All Pro UCA's
    I did this too
  20. Aug 17, 2017 at 8:17 PM
    4runick
    4runick New Member
    2014 silver 4Runner
    Easiest way and you can change a lot
  21. Aug 18, 2017 at 7:03 PM
    billnourse
    billnourse New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    Dealer De-activated mine today. No charge.
