How to Disable Daylight Running Lights?
Discussion in '3rd Gen 4Runners (1996-2002)' started by jfrye, Apr 8, 2018.
  1. Apr 8, 2018 at 2:32 PM
    jfrye
    jfrye [OP] New Member
    I just acquired a new 2000 SR5 and the Daylight Running Lights won't shut off unless I unplug the battery. The circuit for them must've been moved because the 7.5A fuse that runs them won't shut them off when I remove it. Is there an individual wire that goes up to the headlights that runs them on low power, or some kind of step-down transformer that I can yank out? I'm okay with completely disabling them, I just can't have them on when the truck is parked.
    Dougy likes this.
  2. Apr 9, 2018 at 7:33 PM
    PCRIDE4RUNNER
    PCRIDE4RUNNER New Member
    SUPER DUPER
    It should be as simple as cutting one of the wires that go into the bulb harness. One wire has a constant power when the vehicle is one. I’d get a meter, test each one until you find the constant
    Just guessing however....
