How To: Coolant Flush - PICTURES!
Discussion in '3rd Gen 4Runners (1996-2002)' started by ramonortiz55, Feb 13, 2018.
  1. Feb 13, 2018 at 2:01 PM
    ramonortiz55
    ramonortiz55 [OP] New Member
    Ramon
    This is my write-up version of doing a coolant flush on my 2001 4runner Limited.
    Picked up 3 gallons of anti-freeze, a radiator funnel perfect for the task, a bucket, and a few gallons of DISTILLED water.
    Some people only do Toyota Red, I really don't care as long as it is Red.
    First thing first, make sure vehicle is cool and parked at a small incline where the front end is higher than the rear. This ensures that the vehicle is burped properly, all water bubbles are out of the coolant system.
    Pop the radiator cap off:
    Remove any skid plates in the way and locate the drain plug at the bottom of the radiator. Keep in mind that the drain plug will back out all the way if turned out enough.
    Drain the coolant. Yes, it was green. That's the reason I decided to convert to red.
    If you have any pets, make sure that they stay away from the vehicle. The radiator fluid smells/tastes sweet to them and if they drink it, they die.
    If any of it spills, immediately rinse it away.
    Remember the specialty funnel?
    This comes with various adapters for the radiator cap, locate the one that fits and put the funnel together. This is pretty much straight-forward:
    Once the radiator has been drained, close the drain plug. Clean up any mess and scare off any wandering pets.
    Fill up the radiator with distilled water:
    You'll see some gurgling action as the water funnels into the radiator:
    Once the radiator is "full", add more water until the funnel is about 3/4 full and turn on the vehicle:
    Ensure the AC/heater is off and watch the temperature climb, on the gauge pictured - 123*
    As the water pump cycles, you will see bubbles rising thru the water in the funnel and the water level start to drop. This is good. All air bubbles must be out. It might help a little to give the engine a bit gas..
    Keep an eye on the water level, if it gets down too low, add more.
    Once the engine starts warming up to about 190*ish..
    Crank the heater to max, this ensures that the distilled water flushes thru the system.
    If you have a rear heater, crank this up to max as well.
    Leave the engine running with heater full blast for a good 15 - 20 minutes, sometimes longer. It all depends if you no longer see air bubbles come up at the funnel.
    Once you believe that all the air bubbles are out, flush the water.
    Depending on how clean you want your coolant system, you may want to repeat this cycle 2 or 3 times. Since I wanted to make sure I removed as much green coolant as possible, I did 4 cycles.
    You will notice the water/coolant come out cleaner and cleaner after each cycle. It will be your call to determine when you are "satisfied"
    Don't forget to drain your reservoir!
    Once you are satisfied with the flushing of the radiator, do the final cycle:
    1. Add red coolant until the radiator is full.
    2. Once full, fill the funnel until it is about 1/2 full.
    3. Start the truck and burp it to remove all the air bubbles as instructed above.
    Once all the air bubbles are out, fill the reservoir to the cold/max level and you are good to go.
    After a few days of driving, check the reservoir and radiator levels. Top off if needed.
    ***Caution, do not open the radiator when it is hot***
  2. Apr 24, 2018 at 11:41 AM
    cashflow50
    cashflow50 New Member
    2001 black runner SR5 with hood scoop
    thank you
  3. Apr 29, 2018 at 6:56 AM
    toyota1986
    toyota1986 New Member
    Well put and great play by play , gonna give it a go this weekend
  4. Jun 5, 2018 at 6:52 PM
    woodman60
    woodman60 New Member
    It looks like you're just draining the radiator fluid, but not the water/coolant in the block. When you fill the radiator only with 50/50 mix, aren't you only achieving about 25%.
    If I'm wrong, please clarify.
  5. Aug 21, 2023 at 11:01 AM
    krravi
    krravi New Member
    2017 Toyota 4Runner 4WD
    You are right. The coolant has been diluted with remnants of distilled water inside. Best way is run the engine again and drain and refill with the coolant.
    But if you had original coolant to begin with the just drain and refill should suffice. If you are anal about it, then do it twice.
  6. Jun 29, 2024 at 8:07 PM
    shanp4806
    shanp4806 New Member
    shana
    4Runner
    quite enjoyed reading your post have a quick question I have a 2005 and don't have the temperature gauge shown in the picture. how do I know when I get to 123
  7. Jun 30, 2024 at 1:58 AM
    roboturner
    roboturner Dead Eyed
    ‘98 NW 3.4L 5MT SR5 | '18 6MT DCSB Tacoma | '00 IJM 3.4L TRD Tacoma
    You don’t need a fancy gauge, the key is to let it idle for a bit then give it some gas for a couple times to warm up. Then crank the heater and let it sit for awhile to circulate
