How sensitive is the pump to running out of fuel?
Discussion in '1st Gen 4Runners (1984-1989)' started by Daved_and_Confuzed, Feb 13, 2020.
  1. Feb 13, 2020 at 1:41 PM
    Daved_and_Confuzed
    Daved_and_Confuzed [OP] New Member
    Ohio Dave
    '85 Solid Axle Fuelie
    Everybody seems to think my problem is bad gas. my plan was to let the truck idle itself out of gas, replace the fuel filter, and fill with 5 gallons of good gas. will running the truck out of gas harm the fuel pump? i know if you ran out of gas in a ford explorer it would likely burn up the pump and not want to start again.
  2. Feb 13, 2020 at 1:50 PM
    If you are low why not just siphon the rest out?
  3. Feb 13, 2020 at 2:02 PM
    Daved_and_Confuzed
    Ohio Dave
    im not terribly low, i have just under a half tank, about 5 gallons i estimate
  4. Feb 13, 2020 at 3:58 PM
    idling on 5 gallons of gas I can't imagine how long that will take.
    I'd personally siphon it out.
  5. Feb 13, 2020 at 5:21 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Honestly it's probably not going to hurt it to do it once or twice but the effort of siphoning will ensure no damage.
  6. Feb 13, 2020 at 11:33 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    I ran my pickup out ONCE. It's got the mechanical fuel pump though. I did it to see exactly how far I could drive it after the FUEL lite came on steady. 13 miles city is what I got. I've never run the 4Runner below a quarter (on the gauge, for what that's worth...), since it has the in-tank electric pump.
    It really IS a bad idea to run the tank dry, especially just idling, as the pump is cooled by the fuel, and sitting there idling with the fuel getting low, it would get pretty hot. Good chance for it to burn out.
    I'm goin to cast my vote for siphoning too. It would be a MUCH safer way to empty the tank. Absolute worst case, drop the tank, and dump the fuel out. You can look inside, with a flashlite, NOT a match, ahem :sorry:, and SEE if there is contamination in there. Whether dirt, water, whatever, and get rid of it. If there ISN'T, you can put the gas back in, thus saving yourself the cost of 5 gallons.
    If there IS dirt, you can probably get about 80-90% of it out by straining it a ladies nylon.They're actually a pretty good filter medium. Double or triple them over, and you have a super tight filter medium.
    Good luck, no matter what you do!
    Pat☺
  7. Feb 14, 2020 at 5:25 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    You do not need to run it totally out just drive it till your REALLY low like hovering on E then go fill up with super or whatever you were going to put in. The amount of a total fill compared to what you will have left in the tank isn't worth talking about.
  8. Feb 14, 2020 at 5:25 AM
    Daved_and_Confuzed
    Ohio Dave
    good advice as idling it for 8 hours only brought it from 1/3 of a tank to 1/4 of a tank. it would probably have to idle for 24 hours, at least, to burn through all its gas.
    it was running really good though before i shut it off. it wasnt missing at all!
  9. Feb 14, 2020 at 7:36 AM
    Daved_and_Confuzed
    Ohio Dave
    it wont drive, it misses and sputters when giving it throttle. it will idle fine once warmed up but is a bitch to keep running when cold. my plan is to move it into my garage and open up the access panel underneith the seat and take a look into the tank. i was having this problem with less severity on the last tank and i filled my 14.4 gallon tank with 12.9 gallons of shell gas so im skeptical that its really bad gas...im just running low on ideas. maybe i have a bad tank, well see once i can get in there
  10. Feb 14, 2020 at 6:13 PM
    NightOwl
    NightOwl 1985 Toyota 4 Runner DLX 22REC
    Amos
    Ballwin, MO
    LCE header, 2.5 inch exhaust, 31x 10.50 BF Goodrich, 15 X 8 aluminum wheels, Bilstein Shocks, 3 inch lift kit, 3M fender flares
    I'm a firm believer in running it low...add some Lucas stabilizer and ethanol neutralizer and of course being me...add 4 ounces per 10 gallon of Marvel Mystery oil...I know...snake oil shit but it works and works well...the Marvel oil will clean and lubricate every thing even the fuel pump and possibly reduce or eliminate some carbon deposits which these older engines are prone to...I have used both Lucas and Marvel in my 85 4 Runner and it runs Great...then fill it up
  11. Feb 14, 2020 at 6:15 PM
    NightOwl
    Amos
    Ballwin, MO
    Additionally...put a screw into the vacuum hose on your EGR...crazy as it sounds it may fix everything...it did mine...
  12. Feb 16, 2020 at 7:28 AM
    Daved_and_Confuzed
    Ohio Dave
    where my egr at? lots of vacuum lines under here
  13. Feb 16, 2020 at 10:45 AM
    NightOwl
    Amos
    Ballwin, MO
  14. Feb 16, 2020 at 10:47 AM
    NightOwl
    Amos
    Ballwin, MO
    Sorry...my reply was only pictures...this is the EGR valve at the back of the intake manifold next to the fire wall...just unplug this hose and put a screw in it and I put a rubber cap over the actual EGR valve port...please let me know if this helps
  15. Feb 17, 2020 at 3:17 PM
    Daved_and_Confuzed
    Ohio Dave
    excellent! ill try it. today when i put a fuel pressure gauge on it it was reading less than 1psi so i ordered a pump. im hoping it was just a pump
  16. Feb 17, 2020 at 3:24 PM
    Daved_and_Confuzed
    Ohio Dave
    looks like we got the same truck, homie
  17. Feb 17, 2020 at 3:37 PM
    NightOwl
    Amos
    Ballwin, MO
    It does...Great trucks that just keep on going!!!
