How often should you change the oil on your 4runner?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Trekker, Aug 6, 2020.
  1. Aug 6, 2020 at 1:06 AM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    Assuming its an daily driver car. I was told 3 months or 3000 miles but that seems excessive.
  2. Aug 6, 2020 at 6:04 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    3000 miles was the rule of thumb back in the carburetor days. It is not necessary for modern engines under normal driving conditions. I change oil when the maintenance reminder tells me too. IIRC, that was around 7k this last time. For a daily driver under normal conditions you will be fine following the vehicle maintenance reminder.
    I also like to send samples to Blackstone Labs for analysis once in a while to check for indications of unusual wear. So far I've never had an issue with Toyota engines.
  3. Aug 6, 2020 at 7:29 AM
    Synthetic or Dino oil? Synthetic goes much farther...even regular oil goes to 5k. You won't hurt anything with 3k oil changes...but 5k is fine. Higher with synthetic.
  4. Aug 6, 2020 at 7:32 AM
    Mine is a daily driver in normal driving conditions that requires synthetic (2018).
    I change every 10,000 miles.
    Trail Runnah and rkwfxd like this.
  5. Aug 6, 2020 at 9:17 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Same
    nimby[QUOTED] likes this.
  6. Aug 6, 2020 at 10:07 AM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    What's the manual say in your 3rd gen? I'd be shocked if it's the same as the 5th gen 10k recommendation.
    For me I always replace it every 6-8 months regardless of milage as I don't even hit 10k a year.....especially this year as I've put 3k miles on since December 2019.
  7. Aug 6, 2020 at 8:01 PM
    Ah, didn't even see this was in the 3rd gen forum until @aroyalsfan mentioned it.
    Disregard my statement OP, as it doesn't pertain to your situation.
    :cheers:
  8. Aug 6, 2020 at 8:14 PM
  9. Aug 6, 2020 at 8:17 PM
  10. Aug 7, 2020 at 11:33 AM
    Starr
    Jonathan
    SouthEast Maui
    I change at 5k and use synthetic. First change goes down around 3k.
    It’s either very dry dusty or tropical wet humid here. Neither is great for oil longevity.
  11. Aug 7, 2020 at 3:00 PM
    tazdale38
    tazdale38 New Member
    Every 5k with Mobil 1 full synthetic, usually in the high 90s to low 100s here in Mississippi, so i like to keep it clean.
    Thatbassguy and Tama1968 like this.
  12. Aug 7, 2020 at 4:04 PM
    Ya, no wonder my engine is running so well. I change it every 3,500 miles. Gonna ride out this next change to 4,500 prob. I’m towing...
  13. Aug 7, 2020 at 4:06 PM
    This may be the first time I’ve every opened this service booklet....
  14. Aug 7, 2020 at 7:03 PM
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    I follow the Toyota recs right now since mine is under warranty...will probably revert to my usual 10k interval. that's about 2x a year for me.
  15. Aug 8, 2020 at 10:05 PM
    Clutchplate
    Clutchplate New Member
    96 4runner 3.4 Liter
    I use Toyota oil and filter. I change it at 5,000 miles.
  16. Aug 16, 2020 at 7:35 PM
    PAUL_MO
    PAUL_MO New Member
    PAUL
    TOYOTA 4RUNNER 2001
    TYRES AN WHELS
    que grado de aceite utilizan para el motor 3.4l ??
  17. Aug 16, 2020 at 8:16 PM
    jack13cool
    jack13cool New Member
    2018 Magnetic Gray Metallic 4Runner
    TRD wheels
    I use full synthetic and change it every 5K
  18. Feb 8, 2021 at 12:05 PM
    gretzky2857
    gretzky2857 New Member
    2002 4Runner
    I put on 12-14K per year so to make it easy, I don't even look at the mileage, just change it in December and then in June using synthetic oil, runs like a champ!
  19. Feb 8, 2021 at 2:37 PM
    jcoon
    jcoon New Member
    Peasleeville NY
    19 4 runner TRD off road
    I use the same stuff in my Silverado.
    Castrol 03060 GTX MAGNATEC 0W-20 Full Synthetic Motor Oil, Green, 5 Quart
  20. Feb 8, 2021 at 3:05 PM
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    whenever it runs out...
    nimby likes this.
  21. Feb 9, 2021 at 2:05 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    I change when it reaches a certain color... Between 5k and 8k typically
