How many wish they had gone w/o KDSS?
Discussion in '5th Gen 4Runners (2010-2024)' started by java, Apr 15, 2024.
  1. May 13, 2024 at 2:03 PM
    #151
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Which was a low volume seller compared to the rest of Toyota's lineup in North America, negating the need for most dealers to stock the SST.
  2. May 24, 2024 at 4:22 PM
    #152
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    lol saw this in a car and driver suspension articulation test..
    what is the point of the TRD pro trim? Oh wait.. the heritage grill and black rims!
    kdss equipped 4r at the top of the list for superior articulation. This IS the definition of PRO
    lol 4r pro articulates worser than the new Land Cruiser
  3. May 24, 2024 at 6:11 PM
    #153
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    and the soccer mom LX 570 has more flex than your 4R KDSS...
    Superdave1.0 and djwantke like this.
  4. May 24, 2024 at 6:14 PM
    #154
    Yobruhitsme
    Denver
    Ineos Grenadier
    ‘Em pecking orders… I respect those moms and their worthy vehicles.
  5. May 24, 2024 at 7:12 PM
    #155
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Ya apples and oranges, we can’t afford any Lexus suv’s plus they’re too posh and nice for a guy like me anyways.
    isn’t it true non KDSS has better rear end droop?
    semprenissart likes this.
  6. May 24, 2024 at 8:48 PM
    #156
    Chozen
    Chozen New Member
    2024 4Runner ORP
    2Toys likes this.
  7. May 24, 2024 at 9:51 PM
    #157
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
  8. May 24, 2024 at 10:53 PM
    #158
    FourBelugas
    FourBelugas New Member
    23 white ORP
    I see LX600 on there.
    In any case, so the only current production Toyota product available in the US that has better flex than a 45k 4R ORP is the LX600 which starts at
    ...check notes...
    $93915.
    Okay then. To quote Boondock Saints, I'm strangely comfortable with it.
    Yobruhitsme likes this.
  9. May 25, 2024 at 4:45 AM
    #159
    Yobruhitsme
    Denver
    Ineos Grenadier
  10. May 25, 2024 at 6:27 AM
    #160
    semprenissart
    semprenissart Mèfi
    Let’s assume the price is 45k for both vehicles. You’d still be better off with a base 4R than the Lexus if you go off roading unless you trim the shit out of the Lexus bumper.
    It reminds me a few months ago I went camping with a friend who has a fancy Mercedes suv with air suspension. Once we got to a rocky part of the trail requiring 4lo, he raised his car to gain a lot of ground clearance. Quite impressive to be honest. Regardless of this feature that gave him more ground clearance I went with my 4R no issue at all and had to wait for him because he was going extremely slow for a few reasons. First, it’s still a luxury vehicle and was scared of damaging it, second raising the air suspensions made the ride super stiff which was not comfortable at all. Lastly his car computer has some sort of atrac and it was doing a lot of “thinking” which made it not smooth at all like the 4R did.
    all that to say, numbers on papers can be impressive but do not necessarily tell the whole story
    Polv-Y likes this.
  11. May 25, 2024 at 12:01 PM
    #161
    FourBelugas
    23 white ORP
    None of this is in any way, shape, or form relevant to the relative merits or drawbacks of KDSS. I don't give a hoot what someone with a POS mercedes does.
  12. May 25, 2024 at 1:15 PM
    #162
    Acesandeights
    Acesandeights #34
    2024 ORP
    I would think the stock 4R with KDSS has more articulation than a lifted 4R without.
  13. Sep 25, 2024 at 1:20 PM
    #163
    Mr.DRZ
    Mr.DRZ Newish member
    2024 ORP
    I have KDSS and after getting to drive an ORP w/o KDSS and an SR5P I prefer the non-kdss ride. The body roll doesn't bother me as much as the jarring one side bumps.
    Klinsman55 and kmeeg like this.
  14. Sep 26, 2024 at 9:47 PM
    #164
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    The kdss did ride more stiff than my XREAS i have now.
  15. Sep 27, 2024 at 1:09 AM
    #165
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Lol. Be glad KDSS even was an option on the 4Runner, it is a Lexus feature. Other Toyota trucks never got it, LC200 was an exception because it cost as much as a house. It is a durable system, you are overthinking.
    LA260 and Mr.DRZ like this.
  16. Oct 4, 2024 at 3:06 PM
    #166
    Polv-Y
    Polv-Y New Member
    Brad
    Oakland CA
    2023 TRD PRO
    Hey guys!
    Newbie here, I thank you all in advance :)
    Can anyone tell by the photo attached (sorry for the poor quality/angle but all I have) if this 2016 4R Trail Prem has (or not) the KDSS???
    Also, when installing the VIN into the Toyota system I have noticed not all "options" are displayed?
    This particular VIN is: JTEBU5JR2G5279421
    Thanks!
  17. Oct 4, 2024 at 3:20 PM
    #167
    Thats KDSS.
    If sway bar has these boots covering the hydraulic ram its KDSS.
    Polv-Y[QUOTED] and Mr.DRZ like this.
  18. Oct 4, 2024 at 8:33 PM
    #168
    You have KDSS. Look under the driver's front door on the frame - there will be an accumulator on the frame with hydraulic lines running to the rear along the frame rails.
