How many are going to trade for a 6th Gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by hutch993, Dec 12, 2024.
  1. Mar 16, 2025 at 4:12 PM
    #631
    Part of me is curious what you mean by this. But, part of me doesn't care.
  2. Mar 17, 2025 at 9:49 PM
    #632
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
    I had a new 280 ZX and liked it, not sure about the new ones. Nissan has had some financial and production problems .... the next gen 86 is supposed to be a junior supra.
  3. Mar 18, 2025 at 12:09 AM
    #633
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I initially took the comment as neutral, parting ways.
    Or
    It’s hostile lol
  4. Mar 18, 2025 at 4:49 AM
    #634
    There was another conversation in another thread that would add context.
  5. Mar 18, 2025 at 10:01 AM
    #635
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    Wonder if that electronic parking brake will randomly refuse to release like the one in my Highlander...
    I liked my past toyotas (2018 & older) but 100% regret getting a 2021 Highlander and certainly not looking at any newer model toyotas because they all have same crap tech and excessive electronics and poor engineering. It's like Toyota got too many fresh out of college engineers to bring "fresh ideas" but failed to blend in experienced people to point out bad practices.
  6. Mar 18, 2025 at 10:42 AM
    #636
    What happened to the parking brake and what was the fix?
    I agree that it seems like these designers have never owned or used the type of vehicle they are designing.
  7. Mar 18, 2025 at 12:06 PM
    #637
    totmacher
    Daniel
    West TN
    No fix. "Normal operation".
    Brake is suppose to release when shift out of Park but sometimes it just doesn't. Screen gives an error message but I forget what exactly it says. So far shifting back to park and back to gear a few times gets it to go.
    Also has a very strange feeling when it engine brakes while coasting. Surprisingly strong which makes me wonder if it is actually engaging the electric brake slightly sometimes on downhill stretches. It's a normal v6 model, no hybrid, no turbo.
  8. Mar 18, 2025 at 12:26 PM
    #638
    FourBelugas
    FourBelugas New Member
    23 white ORP
    If you think about it long enough you will discover the meaning of life.
  9. Mar 18, 2025 at 12:27 PM
    #639
    FourBelugas
    23 white ORP
    That was the best part of the 3rd gen Taco and for that matter, the FJ for me, the hand pulled parking brake.
    I love the pull brakes and the space it takes up is of no consequence to me since I don't have a man purse to put in the center console.
  10. Mar 18, 2025 at 12:32 PM
    #640
    I wonder if you can pull a fuse to disable it?
  11. Mar 18, 2025 at 1:02 PM
    #641
    totmacher
    Daniel
    West TN
    Maybe but then there is no parking brake control at all. They might lock tight if fuse is pulled, like air brakes on a truck lockup when a line blows. Lol.
  12. Mar 18, 2025 at 4:09 PM
    #642
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    I bought my 24 pro in march last year. I think im good until the 7th or 8th gen
    toy33, djwantke and TejasRunner like this.
  13. Mar 18, 2025 at 4:13 PM
    #643
    FourBelugas
    23 white ORP
    Can't wait for the I-3 from the GR Corolla to go into the 7th gen.
  14. Mar 18, 2025 at 6:35 PM
    #644
    Imdav2u
    23 TRD PRO
    A friends Rav4 emergency brake froze, had to have it towed to the dealer.
  15. Mar 18, 2025 at 6:50 PM
    #645
  16. Mar 18, 2025 at 7:25 PM
    #646
    FourBelugas
    23 white ORP
    The electronic parking brakes malfunction far more common than people realize. But no shortage of brand fanboys who will swear up and down that the mechanical brakes are terrible and that the electronic versions are the best thing since sliced bread. I see that trend on every brand forum I read, Ford, Toyota, Ram, whatever. Seems like there is always a subset of buyers whose kryptonite is the foot operated parking brake.
    SOSHeloPilot likes this.
  17. Mar 18, 2025 at 9:25 PM
    #647
    I doubt it.
    Or, maybe I'm just not as delusional as some.
    Don't get me wrong. The mechanical E brake on my 5th gen is definitely shitty. The one on my 4th gen sucked also. But, not in a way that electronics would fix.
    Edit: I'll also add that the E brake on my '94 worked just fine. I'm not sure how Toyota managed to fuck up something that had previously been perfected. I also kinda miss the pull handle coming out of the dash. But, I guess some folks probably found it unsightly. That, and it probably wasn't used nearly as much one the manual transmission option went away.
    Another side note: the E brake on my '15 Taco was fantastic! It saved my ass once when I made a very stupid mistake while launching a boat once.
  18. Mar 19, 2025 at 5:28 PM
    #648
    who agrees that the 4Runner’s consistently continued to get uglier starting only after the 3rd Gen. I love those 3rd gens man
    Imdav2u likes this.
  19. Mar 19, 2025 at 5:35 PM
    #649
    @FourBelugas this sounds like fanboy talk
    JK!!
  20. Mar 19, 2025 at 5:46 PM
    #650
    Imdav2u
    23 TRD PRO
    I loved my 3rd gens, liked the 4th gens alot, had 4, really like the interior and ride of my 5th gen.
    djwantke[QUOTED] likes this.
  21. Mar 19, 2025 at 6:10 PM
    #651
    FourBelugas
    23 white ORP
    @Thatbassguy must be at least a part time attorney because he is slipperier than Carmine Lupertazzi ordering hits.
  22. Mar 19, 2025 at 7:10 PM
    #652
    You sound a bit like a great friend of mine -- he's had two 2nd gen, a 3rd (still a daily driver), three 4th gens (one wrecked, two still going daily), and just got a 5th gen a few days ago.
  23. Mar 19, 2025 at 7:41 PM
    #653
    Imdav2u
    23 TRD PRO
    I have had 8 4runners, 7 Toyota trucks , 1 Sequoia and 4 Rav4s, we currently have the 4runner, 2 Rav4s, a Lexus LX600 and a CLK350 convertible. I sold the Sequoia to a buddy and it is approaching 640k miles. At some point we will probably upgrade the Rav4, it's a 21 Hybrid Limited, great car.
    vthoky[QUOTED] likes this.
  24. Mar 19, 2025 at 8:09 PM
    #654
    I will wait until the dash imbedded TV phase is over before I consider a new vehicle.
    Lucky9924, vthoky and djwantke like this.
  25. Mar 19, 2025 at 8:28 PM
    #655
    :101010:
    thats amazing
  26. Mar 20, 2025 at 8:12 PM
    #656
    TheGreekFreak
    TheGreekFreak New Member
    I had a 3rd gen and really loved the look and smaller profile. Could have bought a newer 4th gen with less miles for the same money but I was dead set on the 3rd gen.
    Great truck, sold it to my brother and he still daily drives it with no issues. I think the 3rd gen was a high mark, not a fan of the 4th gen, but the 5th gen is the all around best for a daily imo.
    Also think certain trims of the 5th gen look awesome, others are ok.
  27. Mar 20, 2025 at 8:49 PM
    #657
    Clay
    Clay 4 RUNNIN
    Clay
    Auburn, Wa
    2018 SR5 Premium
    My 2018 Runner, after 40K Miles is just like the day I bought it ....The only difference is that we love it more! If there was something about it I did not like and was looking for an improvement, but first, I need to find something wrong with what I have. I have a 2016 Taco, Access Cab....found out they dropped making those - Sorry Toyota...at 140,000+ Miles it still runs like the day I got it ...for less than the cost of a new one I can replace every moving part. Oh, one more thing - It's a 6 Speed Manual (Another reason to keep it) Perhaps Toyota is marketing to new-to-the-brand buyers?
  28. Mar 22, 2025 at 3:47 PM
    #658
    chrisb009
    chrisb009 New Member
    Chris
    4Runner
    Not any reasons to change..
    Imdav2u likes this.
  29. Apr 25, 2025 at 1:37 AM
    #659
    Imdav2u
    23 TRD PRO
    $13k for one year newer , $69,874 for a 4Runner. It just seems crazy. I love my 5th gen, drove the new 6th gen, TRD Off Road, I can't justify spending that much.
    Toy4X4 likes this.
  30. Apr 25, 2025 at 3:08 AM
    #660
    I have yet to drive one, I'm thinking the "looks" aren't that bad, but the price.... Damn, I guess we'll stick to the 5th Gen., I still want to drive one though! BTW, do they still have the "needle bearing" in the front diff.?
