How many are going to trade for a 6th Gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by hutch993, Dec 12, 2024.
  1. Mar 11, 2025 at 7:36 PM
    #601
    FourBelugas
    FourBelugas New Member
    23 white ORP
    the base Grenadiers at 75k are just about the same price as a 6th gen TRD Pro and trailhunter with a few options so there is surprisingly an overlap.
    My main concern is its lack of dealer network, if it could be supported by BMW techs I would be more inclined to give one a shot. But I really like the interior and the powertrain when I checked out one.
    R1200Jedi[QUOTED] likes this.
  2. Mar 11, 2025 at 9:22 PM
    #602
    If it's anything like the Tacoma, they put everything you mentioned in one dial.
  3. Mar 11, 2025 at 9:56 PM
    #603
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  4. Mar 11, 2025 at 9:57 PM
    #604
    And a fancy electric parking brake I hear
  5. Mar 11, 2025 at 10:18 PM
    #605
    FourBelugas
    23 white ORP
    Oh thank goodness, the new generation of Toyota buyers cannot be trusted with a hand or foot operated parking brake.
  6. Mar 12, 2025 at 2:59 AM
    #606
    SlvrRnnR
    SlvrRnnR New Member
    18 4R TRD ORP
    Stock Size KO3's - TRD CAI - TRD Exhaust, KC HiLites Hidden 20" Lightbar, Ditch Lights, Back Up Led Pods, ARB Dif Breather, ScanGauge III, OEM Rock Rails
    I stopped to see one yesterday that just hit the lot, TRD ORP and in silver.
    The inside and outside (I know this is subjective) felt and looked extremely cheap. Lots of plastic. Had this odd "could this be 3D printed" feel to me. 18" wheels and a spare that looked like a smaller donut? Electronic parking brake and steering rack.
    Made me love my 18' TRD ORP even more and I hope to get many, many more years with it. And at $62K for this new model I would seriously consider spending a bit more and going with the Grenadier. It would mean learning a new engine but that vehicle is a solidly built vehicle.
    icebear and djwantke like this.
  7. Mar 12, 2025 at 3:14 AM
    #607
    Imdav2u
    23 TRD PRO
    It looks like a mini van from behind.
    hazards280 likes this.
  8. Mar 12, 2025 at 5:02 AM
    #608
    Imdav2u
    23 TRD PRO
    I watched a video on YouTube this morning, they drove the new 4runner 56 miles ,once with the air dam, once without. 22.6 with and 23.4 without. Not bad. I still prefer my 5th gen, it looks like a truck, not a mini van cross over.
    hazards280 and djwantke like this.
  9. Mar 12, 2025 at 5:13 AM
    #609
    ThomasL
    ThomasL New Member
    Florida
    24 TRD Off Road Prem
    Only thing that would make me trade it in is the adaptive cruise control, lane assist and traffic jam assist (Sadly the traffic jam assist is a paid subscription)
    I cannot justify though paying 10k more than my current truck and after seen the interior of a LC250 I really can’t justify it.
    I think I would probably trade it in for the GX550…
    brownersd likes this.
  10. Mar 12, 2025 at 5:52 AM
    #610
    Imdav2u
    23 TRD PRO
    I liked the looks of the LC, until I looked at it in the showroom, not a big fan. We were going to get a GX550, but the LX600 was a better fit, the dealer had a demo with 3200 miles with some really nice discounts.
    brownersd and Thatbassguy like this.
  11. Mar 12, 2025 at 2:08 PM
    #611
    FourBelugas
    23 white ORP
    Huh.
    Is it just me or is it a lot less well put together of a rear end than the 5th gen, design wise? example from the interwebs
  12. Mar 12, 2025 at 2:42 PM
    #612
    I really don’t like the 4Runner lettering on the bottom of the hatch. It looks arbitrarily stuck on there. Also is the black piece that says Toyota the same piece that’s on the new Landcruiser?
  13. Mar 12, 2025 at 3:07 PM
    #613
    FourBelugas
    23 white ORP
    not quite the same piece as the LC250.
    The back of the 250 is very well designed, in my personal opinion. If they offered the LC250 in gas only powetrain, I would be very tempted.
    Compared that to the 6th gen 4R, the 4R looks more chaotic. Maybe that's what they are going for, I have no idea. But it's so odd to see the bumper not at the same level as the corner pieces AND different colors.
    toy33 likes this.
  14. Mar 12, 2025 at 4:16 PM
    #614
    4runningMan
    4runningMan New Member
    New Mexico
    Pretty salty crew in here lol
    (I'm also a little salty to be honest)
  15. Mar 12, 2025 at 4:21 PM
    #615
    FourBelugas
    23 white ORP
    I am of the Hombres Con Ojos crew.
  16. Mar 12, 2025 at 7:30 PM
    #616
    mac1usa
    mac1usa New Member
    Maybe I am biased but I think the 5th Gen back and looks more aggressive.
    Personally the new back end looks like the rear hatch to a minivan (but sport trim minivan)
    Imdav2u and hazards280 like this.
  17. Mar 12, 2025 at 7:46 PM
    #617
    hazards280
    hazards280 New Member
    Midland, MI
    2015 4Runner TRD Pro - Inferno
    Wow, I would have thought Toyota would have at least made an attempt to clean up the wires in the engine bay.
    It acts as a clear representation of how much more complex these engines are. Sure the power figures are comparable, but getting that out of an engine that has 40% less displacement than the 5th Gen requires much more stress on the engine. I (and many others) would prefer an untaxed 4.0L rather than a boosted 2.4L with little man syndrome. Too each their own, but there is nothing about the 6th Gen that appeals to me.
  18. Mar 12, 2025 at 8:29 PM
    #618
    Bag of snakes!
    Pentangler and Imdav2u like this.
  19. Mar 12, 2025 at 8:31 PM
    #619
    I concur.
    Why do all the corners on this thing have to be so bulky, bizarre and hideous. The front is overkill as well.
    mac1usa and FourBelugas[QUOTED] like this.
  20. Mar 12, 2025 at 8:36 PM
    #620
    I’m know I’m salty af, but 6th gen should have broke the mold and switched back to small badge on the truck (and certainly no big ‘4Runner’ across the gate). Right?
    toy33 and Saker like this.
  21. Mar 13, 2025 at 2:57 AM
    #621
    mac1usa
    mac1usa New Member
    I think those circled areas are going for hold a lot of dust and dirt too.
  22. Mar 13, 2025 at 3:11 AM
    #622
    Actually, the turbo 4 has significantly more usable torque.
    A 4 cylinder has more main bearings than a V6. Also, by making full torque at a much lower RPM, there will be less need to rev the engine. It's possible that the bottom end of the 4 cylinder will actually be less stressed than the old V6.
  23. Mar 16, 2025 at 2:29 AM
    #623
    SOSHeloPilot
    SOSHeloPilot New Member
    SouthEast USA & S.E. Asia
    2024 4Runner SR5
    Owned Many Toyotas - Past
    ...^^^... I have been a super loyal Toyota customer and advocate for a long time and have seen and lived through their mistakes. However, to put such shiny fender flares on this vehicle that will possibly go off road is crazy wrong in my thoughts. Even a grocery cart from Walmart or Costco can show a nasty scratch on the shiny plastic material and it looks really cheap too. Not to mention making the wheel opening look too big, thus making the tires look smaller. All of these design/cosmetic mistakes have little to do with mileage, function and dependability. Wake up Toyota, they are getting too gaudy and too big.
  24. Mar 16, 2025 at 1:00 PM
    #624
    Redwood likes this.
  25. Mar 16, 2025 at 1:53 PM
    #625
    Agreed. Don't really care for the black ones altogether, except maybe on a dark gray or black 4Runner.
    My 4th gen had gray cladding and fender flares. But, it was gray, so I didn't mind it. Plus, it had a matte finish, and really hid any scratches and stone chips. If they had a glossy finish, they'd have probably looked like shit after a few years.
    SOSHeloPilot[QUOTED] likes this.
  26. Mar 16, 2025 at 2:43 PM
    #626
    FourBelugas
    23 white ORP
    so when are you trading yours in for a 6th gen?
  27. Mar 16, 2025 at 3:35 PM
    #627
    Probably never. I want to get something sporty in a few years, so buying another 4Runner doesn't make sense. The '19 will become the camping/wheeling/winter vehicle, and I'll probably get a Z or an 86 for fun.
    Maybe if it's (the 6th gen) around long enough, I'll get one eventually and make the 5th gen a dedicated recreational toy.
  28. Mar 16, 2025 at 3:53 PM
    #628
    FourBelugas
    23 white ORP
    That 86 with the Naturally Aspirated FA24D power plant that everyone complains about power and fuel economy? Every owner of one and the preceding FRS I talk to wishes they had more power and a longer top gear for fuel economy.
  29. Mar 16, 2025 at 3:59 PM
    #629
    Well, the Z is my first choice regarding power. And, I'm not really worried about fuel economy with a toy. If I was that hung up about fuel economy, I would be on a different Forum right now.
  30. Mar 16, 2025 at 4:03 PM
    #630
    FourBelugas
    23 white ORP
    LOL okay.
