How loyal are 4 runner owners
Discussion in 'General 4Runner Talk' started by Over the road, Jan 7, 2024.
  1. Jan 9, 2024 at 8:35 AM
    Pavo
    Pavo New Member
    You do realize your 19 still has nanny features that spy on you right
  2. Jan 9, 2024 at 8:39 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Negative, I bought a 5th gen for its reliability and simplicity. The sales manager I know did the same thing and snagged a 2023 T4R.
    gomiami likes this.
  3. Jan 9, 2024 at 9:13 AM
    Maybe they are pushing the turbos pretty hard. Not sure whats the deal there.
    Reminds me GR Corolla's tiny 1.6 3cyl pushing almost same a 2.5 flat4 Subaru Sti.
  4. Jan 9, 2024 at 9:40 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    I’ll have to wait and see if the new engines are good. We swoon over old trucks with the 22r-te (the t stands for turbo), yet bash new vehicles for coming with a turbo.
    It’s simple math that the more parts there are the more there is to fail. The 1GR is more likely to fail than a 3rz because it’s larger and more complex, yet people accept the 1GR with open arms.
    It's been so long since Toyota introduced a new engine to the 4R that people forget the criticisms of the 1GR. For example it isn't rebuildable, the aluminum block means you have iron sleeves which can't be rebored like an old aluminum block. Resurfacing the heads too much can result in timing problems, you can jerry rig the engine by using a thicker head gasket but that is a much more complex job. The VVTI is more sensitive to bad oil because the it uses oil pressure to work. The newer engines (2014+) have secondary air injection, which makes changing the spark plugs a pain in the ass.
    No engine is perfect, and many engines we accept today were once seen as complicated when they debuted. I wont write off the 2.4 turbo immediately, but I wont be buying it either (I'm poor).
  5. Jan 9, 2024 at 11:29 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I’ve got two 4R.
    Nope on the trade until I see long term results on the new ones.
    gomiami likes this.
