How do I adjust the mode door actuator so it works? (Replaced part)
Discussion in '4th Gen 4Runners (2003-2009)' started by DragonClaw, Jun 29, 2024.
  1. Jun 29, 2024 at 5:45 PM
    DragonClaw
    DragonClaw [OP] New Member
    Basically the AC wouldn't come out of the main vents and we couldn't get it to switch from the defrost.
    We replaced the mood door actuator under the glove box side dash.
    But now it won't reliably switch. I'll turn on the heat to max and then it comes out the defrost. But unless it's set to max heat, it will blow out of the main vents a lot.
    I was told this was a timing issue because of the white piece attached to the actuator.
    How do I adjust the timing piece to do this?
  2. Jun 29, 2024 at 9:13 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    There are two actuators on the passenger side, not sure which one does what but maybe you still need to replace the other one?
  3. Jun 30, 2024 at 6:36 AM
    DragonClaw
    I was told yesterday by a Toyota Tech that it was about the timing and placement of the parts I've got. But he just wanted me to buy OEM. Which are like X5 the price
