High Output Alternator
Discussion in '5th Gen 4Runners (2010-2024)' started by Blu4Fun, Feb 10, 2020.
  1. Feb 10, 2020 at 6:14 AM
    Blu4Fun
    Blu4Fun [OP] New Member
    Matthew
    2017 ORP
    RSG Sliders, Slimeline Bumper, Warn 10Ks Platinum, 1.75 Rear Dobinson, 5160 Bilstein rear shocks, 6112 Front Shocks 1.75 lift, 650lbs front springs, JBA Upper Control Arms, Ram-X Phone Mount Mod, Victory 4X4 factory length roof rack, Wrangler Duratracts
    Voltage regulator has failed and my battery is not being fully charged.
    I was thinking about getting a high output alternator, was looking at Power Bastards, Green Machine, and others, but then started reading the threads and paused.
    there appears to be no threds from 2017 on about high power alternators.
    The ones I did find said that you had to upgrade the fuse, otherwise you would blow the 140amp fuse when it delivered over 200amps. Has anyone done this upgrade recently? Do I need to take it to a stereo shop and have them upgrade the wiring and the fuse, before I take it to a mechanic?
    I’m not sure if it’s worth the headache, but I do have a Warn Zeon winch and the idea of giving it better rpms is appealing.
    Thanks for any advice.
  2. Feb 10, 2020 at 8:29 AM
    Well also not sure on what wire size the 4R has but might want to take this into consideration. Not only the fuse.
  3. Feb 10, 2020 at 9:09 AM
    Mtbpsych
    Mtbpsych New Member
    I’m no expert in the 4runners but with the Tacoma’s that have the towing package, they come upgraded with a high output alternator. I would assume maybe the 4runners are like this as well but I am not 100%. Maybe someone else can chime in.
  4. Feb 10, 2020 at 10:57 AM
    Agent_Outside
    Built 2011 T4R Limited
    If you’re going to upgrade keep in the mid the specs loft he alternator. Generally high output alternators are only high output when the engine is at a higher rpm, in fact it’s not uncommon for them to have less than stock output at idle.
