Help with missing piece or part on 1988 4Runner
Discussion in '1st Gen 4Runners (1984-1989)' started by jasonlprince, May 10, 2022.
  1. May 10, 2022 at 11:01 PM
    jasonlprince
    jasonlprince [OP] New Member
    Jason
    1988 Toyota 4Runner 4x4 SR5
    Hello All,
    My son recently purchased a 1988 Toyota 4Runner SR5 4x4, automatic transmission. About 4 days after buying it, it was stolen. We were fortunate enough to get it back, however there was a lot of internal issues as result of then suspects cutting some wires and frying the ECU. We have a ECU purchased and on the way. Hopefully that solves that one.
    But we have one more issue that I was needing help on. There appears to be a hole due to a part missing in what I believe the is the transfer case (please advise if I'm wrong). Can you please tell me what needs to happen or what part I need to purchased in order to plug this hole or fix this. Please see attached picture.
  2. May 11, 2022 at 12:10 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    I might well be wrong, as I had a MT 87 4Runner, but I'm pretty sure that's the drain plug for the transfer case.
    From the looks of it, you might want to make certain the threads are still OK. May need to pull that plate off and chase the threads. Check the FSM for the correct procedure. Watch out for small little ball bearings with springs behind them popping out from behind innocent looking bolts, if you do need to pull it apart.
    You'll need to get a new plug, and a new crush washer, too. The plug is available from pick-n-play type junk yards, or the dealership. The crush washer needs to be new to seal correctly, so the dealership or another decent Toyota parts house is the place to look.
    Avoid cheapo Chinese-made after-market parts at all costs!
    Does all my rambling help any?
    Pat☺
  3. May 11, 2022 at 3:26 PM
    jasonlprince
    Jason
    It does make sense. But after finally finding a picture of another one..I realized that the metal tube off to the left in my picture was actually supposed to go there. It had been broken off and moved to the side. I moved it back and it fits. Just need to weld back in place.
  4. May 11, 2022 at 11:12 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    That looks like cast aluminum. Welding it would be a royal pain in the ass
    PhantomTweak likes this.
  5. May 12, 2022 at 11:37 AM
    Yeah, that will need to come off and go to a welder who knows what he's doing.
    ...or..."JBWeld tank repair" and you may be surprised how long it stays fixed.
    https://www.jbweld.com/product/tankweld
