Help?!?!? Starting issues after water crossing
Discussion in '5th Gen 4Runners (2010-2024)' started by Beer Hounds, Aug 26, 2018.
  1. Aug 26, 2018 at 6:55 PM
    Beer Hounds
    Beer Hounds [OP] New Member
    2018 4Runner TRD PRO
    SSO Bumper, Rocky Road Outfitters sliders, Rigid light bar
    Hello.....so I have an issue. About a week ago I crossed water that was a little higher than I wanted to, but not high enough that I was concerned with having any issues. Well a week went by and nothing....until today. Multiple times today I turned my key to start my rig, all electrical acted normal but the starter did not turn over. I tried it a few times and then it would start as normal. This happened multiple times today.
    I have a 2018 TRD Pro with 19K miles. We have been across water before, and this was nothing to be concerned about. It was well below the hood, maybe the top of the tires if that helps for reference.
    Any ideas out there?
  2. Aug 27, 2018 at 10:00 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    How well did you clean the underside? Some residual junk may be packed in somewhere.
  3. Aug 28, 2018 at 10:12 AM
    Beer Hounds
    No, I didn't clean too much from underneath. What would be down there that would cause this issue? I will check it out, but probably have to remove skid plate to do it.
  4. Aug 28, 2018 at 11:02 AM
    JosephMehta
    JosephMehta New Member
    Zombocalypse
    Shrockworks Front Bumper, CBI Rear Swing Away with dual Jerry Cans and full size spare, Full Shrockworks Armor, Warn 9.5 Synthetic, PIAA Lighting on roof rack and front bumper, Rear lighting wired to vehicle's reverse gear, Dobisons dual slide out rear bay storage with sliding top and refrigerator tie-downs, Limb Risers, Gobi Rack w/mounted Powertank, Fire Extinguisher, Jack, Axe, and Shovel, 33" Nitto Grapplers (295/70/17), Body Mount Chop, Icon Stage 7 Billet w/S2 Stage 3 Secondary adjustable front suspension, 3.5 inch Icon Stage 7 Billet with Billet Upper and Lower Links, Icon Bump Stop, 3.0 inch Icon Overland Rear Coils, ARB Front and Rear Air Locker with ARB Differential Breather (relocated to engine bay), ARB Twin Compressor mounted in engine bay, 360 degree, 4-camera system with DVR with monitor mounted on the dash, Dual Rear Headrest Monitors w/DVD and gaming capability Future mods in 2019: Magnusson Supercharger w/Catback system and possibly an roof mounted, solar heated shower and water storage
    Get a new starter.
    Haha...just being sarcastic; sorry to read about the issue. Given that all electrical turned on (Does the A/C blow, the radio come on, the horn works, blinkers, and brake lights, etc.?) but no turnover with the starter could mean a blown fuse (check that), or the starter just went bad. Another possibility is hydrolocking. Pull out the plugs and turn the key, see what happens: does water come out? Can you see any water; if so, open it up and dry it out.
    cjrunner likes this.
  5. Aug 28, 2018 at 12:32 PM
    DesertCanyons
    DesertCanyons Professional Engineer, Civil/Structural
    Dave
    Pasadena, CA
    2015 MGM Trail Edition w/ KDSS, no sunroof
    ICON tubular Stage 7 lift (+2"), ICON Rebound wheels w/ Falken AT3W LT285/70R17 tires, Baja Rack flat utility rack and ladder, RCI skid plates, Domello rock sliders, Diff breather relocated, Baxter Performance remote oil filter, Weathertech floor mats, side exit exhaust, 2nd rear recovery point
    Well, there might be mud or marmots living in there by now.;)
    Yes, take it to one of those coin operated power wash car wash places. Get a lot of quarters and plan on spending about 10 minutes spraying the engine bay, undercarriage, suspension and exterior. You'll have to get down on your knees in the water to do it, but power spray the entire underside. I do this every time I go off roading. Living in Los Angeles I don't get to go off road often enough, maybe once a month.
    Yes, take the skid plates off if you can. If you have the OEM skid plates it's not that hard. Unless you've had the Toyota dealer do the "free oil change". The dealer is notorious for over-torqueing the bolts of the skid plates when they do the oil change.
  6. Aug 28, 2018 at 12:52 PM
    Beer Hounds
    Its intermittent and it will start. Once its started it runs fine with no issues. I'm leaning towards the solenoid going out. It has full electrical, and will start with no issues about 70% of the time.
    Pushyguy likes this.
  7. Aug 28, 2018 at 1:00 PM
    JosephMehta
    Zombocalypse
    I'd also check the battery, could be weak, and we often think just because the car turns on that the battery is fine and recharges. Not always true. As well, check the alternator, by checking the battery's voltage while running; should be above 13 volts. On the off chance, it could be (and don't laugh, this happens) the key fob. Try using your backup key and/or backup key fob for a while. Good luck on trouble shooting.
  8. Aug 28, 2018 at 1:42 PM
    Richmond Dan
    Richmond Dan New Member
    Richmond, VA
    Yeah, my brother-in-law had his car towed to dealer when it wouldn’t start. Turned out to be bad battery in key fob!
  9. Aug 28, 2018 at 3:52 PM
    Beer Hounds
    I took it to the dealership today and they found the starter has failed. They are replacing it under warranty luckily enough.
    Mack7n, Riding Dirty and CollinJ like this.
  10. Sep 29, 2018 at 2:16 PM
    Pushyguy
    Pushyguy New Member
    2018 TRD Off Road, 3/2 lift, 33s
    Rifle rack, console .357 holster, pine tree air freshener.
    Cool, when I was doing a lot of water crossings for work I die electric greased all the connections. We used to do that on the boats in the north atlantic, seemed to help.
