Help needed, A Hose hanging on passenger side firewall. 4th gen
Discussion in '4th Gen 4Runners (2003-2009)' started by Rcx56, Feb 20, 2021.
  1. Feb 20, 2021 at 7:08 PM
    Rcx56
    Rcx56 [OP] New Member
    Hello, with all the ice and cold that hit us here in texas, we had a few animals come in to the garage to get out of the cold. I found a rat in the engine compartment and I found this hose partially chewed on. But I don't know if it's supposed to go to anything?
    It's on a 2005 toyota 4runner v8 4wd. Any ideas?20210220_201931.jpg 20210220_201840.jpg
  2. Feb 20, 2021 at 7:56 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    Welcome from N Austin!! If you’re local I could stop by and take a look but, the 2003-2005 2uzfe trans are different than the 06-09. I believe the yellow cap is your transmission dip stick? It’s hard to see the exact location but it seems to be near that?
    if you are able to take a more zoomed out picture I might be able to help, unless someone beats me to it.
    Edited: that’s your oil dip stick... this TX winter got my mind hazy
    Rcx56[OP] and Moon Landing like this.
  3. Feb 20, 2021 at 8:13 PM
    milo88
    milo88 New Member
    Looks like condensation drip hose. Pretty sure.
  4. Feb 21, 2021 at 5:09 AM
    Rcx56
    Hello, here is another pic zoomed out a bit. I hope it is just the drip hose.20210220_201652.jpg
  5. Feb 21, 2021 at 5:48 AM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    That’s it, condensation drip hose!
    to compare
    Rcx56[OP] likes this.
  6. Feb 21, 2021 at 6:26 AM
    Rcx56
    That's the one! Thank you appreciate it!
    Hope yall have a great day.
  7. Jun 25, 2024 at 6:23 PM
    shanp4806
    shanp4806 New Member
    shana
    4Runner
    so it wasn't chewed off and is it supposed to look like that? I have the exact same 4runner except its a v6 and was wondering what that hose was for. My 4R is overheating off and on. I have changed water pump thermostat twice and replaced radiator once. it seems to only over heat in intervals now that its over 100 in okiahoma I'm worried that I'm loosing more than normal from that hose.
    2Toys likes this.
  8. Jun 25, 2024 at 6:51 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    The cosmetics of the drain hose don't matter much, although some owners lengthen it to route drips away from the frame for rust prevention. It will drip more when you use the AC more and it will drip more in humid weather. It shouldn't be correlated with overheating unless your radiator and fan aren't up to par, in which case running the AC could boost engine heat a little.
    LOSTR4 likes this.
  9. Jun 25, 2024 at 7:27 PM
    That hose has no connection to the engine cooling system.
    Since you replaced most everything to do with the cooling system, you may have the start of a blown head gasket. You should check for exhaust gases in your coolant.
    You may also want to check your engine fan and fan clutch.
    3JOH22A likes this.
  10. Jun 26, 2024 at 9:47 PM
    Does it overheat at highway speeds? If it overheats only in slow moving traffic, your fan clutch likely went bad.
    LOSTR4 likes this.
  11. Jun 28, 2024 at 12:19 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Extending the condensation tube is a good hedge against frame rust. We’ll never know what Toyota was thinking when they placed that thing where it drips water right onto a frame that’s unfortunately rusted right out from under a lot of owners but it’s an
  12. Jun 28, 2024 at 8:52 AM
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
  13. Jun 28, 2024 at 2:01 PM
    Extending the evaporator drain tube does nothing for frame rust.
  14. Jun 29, 2024 at 7:34 AM
    Bluesky 07
    Russell
    Northern Georgia
    Other than help prevent it by eliminating a constant drip onto the frame?
  15. Jun 29, 2024 at 5:25 PM
    ^Condensate water is cleaner than rain water. Compared to salt, magnesium chloride, and other road deicers, condensate water does no harm to the frame.
    You think condensate water is anything compared to this? The Toyota engineers in Japan lose their minds when they see pictures like this:
    [​IMG] [​IMG]
    whippersnapper02 likes this.
  16. Jun 29, 2024 at 5:42 PM
    Bluesky 07
    Russell
    Northern Georgia
    Perhaps, but in the context of these particular frames that were not properly treated and have a history such that they do, any moisture is bad moisture.
