HELP: King and Camburg UCA install
Discussion in 'Suspension' started by a-double, Nov 22, 2020.
  1. Nov 22, 2020 at 8:14 PM
    a-double
    a-double [OP] New Member
    Hi,
    I'm in the midst of my suspension install with Camburg billet UCA's and King CO's on a non-KDSS 2020 TRD ORP.
    I'm running into an interference issue with the resi brackets and UCA's in standard caster setting. Reaching out on the forum to see if anyone can shed some light on this. Here's a picture:
    Install instructions: https://camburg.com/wp-content/uploads/2019/11/05_Taco_Billet_UCA_310103_112119.pdf
    Camburg sells this as a kit: https://camburg.com/shop/suspension...-toyota-4-runner-10-king-2-5-performance-kit/
    BTW, my resi brackets are PC'd black.
    Thanks in advance!
  2. Nov 22, 2020 at 8:52 PM
    a-double
  3. Nov 24, 2020 at 3:42 AM
    Wcslv
    Wcslv New Member
    19 TRD PRO
    Could have the passenger & drivers side resi bracket switched?
  4. Nov 24, 2020 at 5:09 AM
    Antman
    Antman New Member
    Anthony
    Oops. Wrong pic.
  5. Nov 24, 2020 at 9:42 AM
    Are you positive you have the heim spacers correctly positioned?
  6. Nov 24, 2020 at 2:47 PM
    a-double
    For standard caster, yes.
    nimby[QUOTED] likes this.
  7. Nov 24, 2020 at 4:15 PM
    Can you move the reservoir mount a little further away?
  8. Nov 24, 2020 at 6:23 PM
    a-double
    No. There is barely enough slack in the hose to clear the UCA at full droop.
  9. Nov 24, 2020 at 7:36 PM
    Have you called Camburg?
  10. Dec 1, 2020 at 12:08 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
    So you are confident the reservoir mount is mounted directly under the sway bar mount? Referencing a ton of Tacoma setups, there is plenty of room for that reservoir mount. Have any more photos from further away? Are both sides having issues or just one side?
