Help deciding on a lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Squash87, Feb 26, 2022.
  1. Mar 1, 2022 at 12:10 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Dude IronMan will give you want you want ar a great price, AND you upgrade.
    7B64FAB1-75A9-4BCD-A280-2FB0330B3480.jpg 2D446166-B1AF-466D-990A-DA32F0EAECA5.jpg 7603AEE3-1413-4D45-97B0-92F939537A98.jpg C5A11266-A3BA-43FC-86F4-B61528235841.jpg
  2. Mar 1, 2022 at 12:15 PM
    I’ve got a spacer lift and haven’t experienced any problems other than I think the rear stock shocks bottom out when driving over a curb or obstacle.
    Having said that, if I had the insight and knowledge that the two videos I posted here provide when I purchased my 4Runner in 2018, I would not have gotten the lift.
    I like the look and the additional ground clearance is helpful when I’m under it changing the oil, but I am concerned about the long term effects on the suspension.
  3. Mar 1, 2022 at 12:16 PM
    cablelayer
    cablelayer New Member
    How is the ride?
  4. Mar 1, 2022 at 12:18 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Rides like BEASTMODE on the trails.
    Off the trails there is a stiffer ride, but I really love the body roll limitation. I recommend them every-time I get a moment to.
  5. Mar 1, 2022 at 12:20 PM
    cablelayer
    Wife has back troubles. That is why I went Ironman. She is so comfortable riding with me now. I also tell everyone to go with them. Smooth as silk ride.
    K-Paul[QUOTED] likes this.
  6. Mar 1, 2022 at 12:22 PM
    Squash87
    Squash87 [OP] New Member
    Another question regarding lifting. Looking at the Toytec coil lift, it does say you should only use it if you have added weight in the front. I'm assuming that would entail a steel bumper or winch setup. Is this the case for all lifts?
  7. Mar 1, 2022 at 12:26 PM
    No, not all. Some will have optional spring rates to match your added weight, or no added weight.
  8. Mar 1, 2022 at 12:42 PM
    Squash87
    Ok cool. So I guess what it comes down to is I just want slightly larger/wider tires. Is there a way to do this without a lift that won't cause rubbing? Some trimming around the fender and a negative offset? That may end up being more what I'm looking for.
  9. Mar 1, 2022 at 12:55 PM
    There are ways to fix slight rubbing.
    One option is a 275/70/17 tire. But, there are very few options in this size, and most are LT (load range C or heavier) and can lower your MPG and affect ride quality negatively.
    285's can usually be cleared pretty easily with a good alignment and wheels with a similar offset to stock.
  10. Mar 2, 2022 at 3:17 PM
    Squash87
    If I were to go the westcott route and keep the trd pro fox suspension and add some 33s, would there be any downside? Would it reduce the quality at all from how it is stock?
  11. Mar 2, 2022 at 3:39 PM
    I would assume;
    1. Shocks won't have wheel articulation as a longer shock that is design to be used as a lift.
    2. The 2 spacers that go between the shock and shock mount + 2 spacers compressing the springs on the shock & spring fixing point would effect the ride a little. Maybe 2 spacers go on top of the rear springs would impact the ride.
    3. With a spacer kit or a spring lift kit I'm not sure if it would change the valving zones of the stock shock and would impact the ride quality (Theoretically).
    Again all this is what I assume and I don't have this spacer kit or any other spring lift with TRD Shocks.
  12. Mar 11, 2022 at 11:52 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    And what about the Eibach Springs that just came available for the TRD Pro? How would they differ (performance wise) from the Westcott kit?
  13. Mar 12, 2022 at 11:06 AM
    SkippyRunner
    SkippyRunner New Member
    2020 4Runner TRD
    Do you guys know how the OME Nitro kit compares to 2020 TRD Premium shocks? This is my daily driver but I want to lift for off roading and was looking at the same kit.... @kmeeg @Jynarik
  14. Mar 12, 2022 at 2:07 PM
    Other Limited & TRD Pro all other shocks are same.
    If you are looking to lift stock shocks + spacer lift like ReadyLift kit would be comfortable but OME Nitro shocks are very capable for abuse on trails even for some jumps at the cost of a firm ride. Also OME Nitro shocks will give you better wheel articulation after lift. I wasn't happy with onroad ride quality so would pick something like Bilstien5100. They will ride better but not strong as OME Nitro for abuse.
    That is my personal opinion having stock shocks +lift vs OME Nitro vs Bilstien5100.
    However OME BP51 would be an amazing setup, I guess but no personal experience.
  15. Mar 13, 2022 at 6:43 AM
    SkippyRunner
    2020 4Runner TRD
    Thanks, very helpful - I’ll check out the Bilstiens.
  16. Mar 13, 2022 at 11:27 AM
    sspro
    sspro New Member
    Scott
    2018 TRD ORP
    2 1/2" - 2" Ironman Foam Cell Pro
    I cant say enough great things about my Ironman Pro Cell Foam kit either!!!
