Help! Budget friendly, reliable Timing Belt kit
Discussion in '3rd Gen 4Runners (1996-2002)' started by Lonewolfhobbies, Dec 21, 2020.
  1. Dec 21, 2020 at 8:31 AM
    Lonewolfhobbies
    Lonewolfhobbies [OP] New Member
    Ryan
    2000 3.4 limited
    I'm looking for a reliable Timing Belt kit with water pump, tensioners, seals, gaskets and the work. On a budget. Do I need to shell out big bucks for box store parts or is there cheaper, reliable aftermarket somewhere? Thoughts on Aisin?
  2. Dec 21, 2020 at 9:55 AM
    ONLY use the Aisin water pump.
    You can skip kits with the tensioner. I have a hard time believing that they ever fail.
    Last one I used was "Evergreen" and all but the crank/cam seals were good quality parts. Those seals seemed to not be exactly the same...they may work just fine.
    $129?
    https://www.amazon.com/Evergreen-TB...iming+belt&qid=1608573039&s=automotive&sr=1-3
    Just add a Thermostat.
  3. Dec 21, 2020 at 10:07 AM
    Lonewolfhobbies
    Ryan
    2000 3.4 limited
    This is the kit I was looking at on Amazon. I believe it's evergreen
  4. Dec 21, 2020 at 10:13 AM
    The water pump Aisin sells outside of TOYOTA will have the TOYOTA name ground off the housing. Supposed to be the same pump. Looked identical to me when I compared them. Came in the AISIN blue box.
  5. Dec 21, 2020 at 10:43 AM
    Lonewolfhobbies
    Ryan
    2000 3.4 limited
    Thank you
