Help!! 2003 Toyota 4Runner Ac problems
Discussion in '4th Gen 4Runners (2003-2009)' started by Javi805, Jun 16, 2021.
  1. Jun 16, 2021 at 4:25 PM
    Javi805
    Javi805 [OP] New Member
    Javi
    2003 Toyota 4runner
    I spent over 2k on my ac system and it is still short cycling:/ the only things on the dash are the trac and vsc as well as the airbag light after a coil went bad. I replaced the coil and lights stayed on, really don’t know if that has anything to do with. I took it to Meineke which is probably the worst thing I could of done and they can’t figure out why it’s still not working properly. When I park after a couple of minutes ac pump starts to shut on and off and I hear a plump noise in my dash. Air flow not that great and not as cold as they said it would be when the work was done. Any ideas?
  2. Jun 28, 2021 at 7:11 PM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    Probably the thermistor in the evaporator box that cycles it out to prevent freeze up. It's a common problem. I replaced mine shortly after I bought it. It's aggravating to change but at least it's cheap. You can get one from Toyota for (I think) less than $15.
