Hello everyone, looking for some collective wisdom.
Discussion in 'New Member Introductions' started by PoloZ, Jun 2, 2022.
  1. Jun 2, 2022 at 2:05 PM
    PoloZ
    PoloZ [OP] New Member
    2011 SR5 street use
    I own a 2011 Black SR5 with 20' Bridgestones for street use, works great, and I do my regular maintenance; my wife likes to name our vehicles, so she was christened "Raven".
    Last year I had to replace the alternator, which -as some of you may know- is not an easy feat thanks to a single lone bolt placed in the most unreachable place.
    I come for some advice on the oil filter housing. Due to my ignorance, I broke the original plastic one doing my first oil change a little over 5 years ago. I went and got an aluminum one from Autozone, and it worked well until this weekend when I noticed a slight leakage.
    I inspected around, cleaned, and observed that the big O-ring was a little bitten, so I thought I did not lubed it well before installing. I went ahead replaced the element and made sure the O-rings were well lubed before going back in.
    After a short run I saw a small puddle on the driveway, so I put Raven in the garage, and ordered a new housing (Fokes) and K&N filter element from Amazon. Not knowing how much oil had leaked, I got another 6 quarts of Mobil 1 full synthetic high-mileage. Proceeded to drain, and clean underneath trying to find the source of the leak.
    The engine was clean above the housing, and there was some fresh oil drops hanging from the drain plug.
    So, I replaced the housing, new filter, plugged everything up, and refilled. I ran the engine w/o replacing the skid plate, and "OH caca!", oil dripping from the new housing drain plug.
    I am leery of just tightening the drain plug, as it did not come with torque specs, and I could overtighten causing a hairline break, resulting in it causing it to continue leaking w/o my knowledge.
    I'll leave it here, looking forward to your suggestions. Thanks in advance.
  2. Jun 2, 2022 at 2:17 PM
    GenoBluzGtr
    GenoBluzGtr New Member
    Geno
    Maryland
    '22 TRD Pro - Black
    One question, did you swap out the original filter center-insert from your old original housing into the new Aluminum? The ones that come with the aluminum housing is not the correct size for the 4Runner engine. If you didn't do that, that might be part of your problem.
    If you did do that, then I would begin inspecting the threads for both the housing drain plug and the housing itself.
  3. Jun 2, 2022 at 2:24 PM
    PoloZ
    2011 SR5 street use
    No. I did not. I did notice it was shorter, but it actually looked sturdier that th eone I was replacing. Easy fix to try.
    Out of curiosity; how does the different length cause a leak? Increased pressure perhaps
  4. Jun 2, 2022 at 2:50 PM
    GenoBluzGtr
    Geno
    Maryland
    '22 TRD Pro - Black
    Not sure, but I know those are supposed to be changed. Perhaps it doesn't seat properly without the right center piece.
    https://trail4runner.com/2019/04/17/genuine-oem-toyota-metal-oil-filter-with-motivx-tools-wrench/
    My guess is that the shorter center pipe that comes with the metal housing is for a different element, and if you don't have the longer one, the filter element itself might not seat properly causing the oil to flow through the housing differently. Just a guess. I know that I changed mine and have had zero issues through 3 oil changes. If this doesn't fix it, I would look at threads. If it DOES fix it, let us know! It would be important info.
  5. Jun 2, 2022 at 3:16 PM
    ToyotaRDie
    ToyotaRDie New Member
    That is good advice. Also, whenever possible, use OEM parts.
  6. Jun 2, 2022 at 3:18 PM
    PoloZ
    2011 SR5 street use
    I tend to agree. If it wasn't relevant why the different lengths?
    I removed the Fokes one, and the center piece cannot be removed w/o damaging the one in place. It's going back, and getting a Dorman, which shows several center piece lengths.
  7. Jun 2, 2022 at 3:27 PM
    ToyotaRDie
    There is an OEM metal housing used for lexus that apparently works well for the 4runner.
    Toy4X4 likes this.
  8. Jun 2, 2022 at 3:56 PM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    ToyotaRDie likes this.
  9. Jun 8, 2022 at 2:00 PM
    PoloZ
    2011 SR5 street use
    OK, here is the update and end result.
    From left to right: Elements of the Toyota housing, spring, spring base, housing and centerpiece. Then the old housing, a cheap chinese one, same as the Dorman I returned, which came repackaged with a much different looking drain plug, which probably broke at installation; Old centerpiece, spring-base, spring "cap", spring, housing, and above is the broken center of drain plug.
    In all fairness, the Fokes housing I returned, looked everything as the Toyota one, and it was made in Korea. I asked a mechanic, former client, whether it was relevant the length of the centerpiece, he explained that it is what keeps the spring base pushed against the bottom, otherwise, the oil would push against the oil plug constantly, so yes, it is important.
    I disassembled the toyota housing, and used the old spring "cap" to receive the longer centerpiece. Inserted the filter element, and installed torquing the housing at 25 NM, and the drain plug at 13 NM. No leaks, no runs, no errors.
    Thank you all for your advice and help. Yes to josephp732 for recommending Toyota. Again the Fokes looked everything like Toyota's, bit it was just a few dollars more, peace of mind is worth it.
    SlvrSlug likes this.
  10. Jun 8, 2022 at 2:55 PM
    GenoBluzGtr
    Geno
    Maryland
    '22 TRD Pro - Black
    Good info so we all know that that centerpiece COULD create a problem - Thanks for updating!
